    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree9Likes
Old 07-15-2015, 12:48 PM   #1531
Stevomatik's Avatar
Originally Posted by B4TravSC10 View Post
My JC body
Looks good!... About to get one for myself an see the handling differences
Stevomatik is offline   Reply With Quote
Old 07-15-2015, 12:49 PM   #1532
Teufel Racing's Avatar
Trader Rating: 28 (100%+)
Originally Posted by K_King View Post
Almost like a truggy lol
K I think I got ya,
I haven't had that that I've noticed, but you could try to maybe gear up a tooth or two on the pinion so you don't have a ton of bottom end acceleration. I've been running a 13.5 so I'm already geared pretty high. Lol.
I did some work on one of the guys wheeler here and after putting in the gear diffs and on slicks, you could almost pull wheelies from a dead stop. I did t think to check his gearing.
Loosen the slipper a little? That could help
J.Mikoliczyk
RB6 - MBX7R Eco
Fantom Racing, Cheater Racing
Houston's Engine Service
Teufel Racing is offline   Reply With Quote
Old 07-15-2015, 01:44 PM   #1533
Originally Posted by Stevomatik View Post
Use AE or TLR or drill your own... I currently use the AE 1.7
gearit is offline   Reply With Quote
Old 07-16-2015, 07:08 PM   #1534
fathead's Avatar
1-piece top deck currently being tested, for astro.
Slavich Design
fathead is offline   Reply With Quote
Old 07-16-2015, 07:34 PM   #1535
Trader Rating: 54 (100%+)
Who's running the new chassis, what's the verdict so far
Speedychris22 is online now   Reply With Quote
Old 07-17-2015, 05:05 AM   #1536
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Finally have a ZX6 on the way! Are there any essential spares (aside from arms, towers and tuning parts) I should get? Does the Exotek diff nut from the RB6 fit?
Kyosho RB6 * Kyosho ZX6 * Kyosho RT6
TLR 22SCT * TLR SCTE 2.0
Tekno NB48.3 * Tekno EB48.4 * Tekno EB48.3 * Tekno ET48.3
rpboggs1 is offline   Reply With Quote
Old 07-17-2015, 01:56 PM   #1537
The exotek diff nut should fit.
Arms and towers never hurt to have, mostly front arms. Get some rb6 rear arms (713 or the new 713b ones), 1.4mm rear sway bar, 3mm grub screws (put them in all unused ball stud holes, helps a ton on the durability) 12 I think should cover it. Not a whole lot else unless you want to add the rear alum hubs and Ti camber links or some Ti screws. Maybe at some point the gear diffs. I like them in my car, but some others don't.
J.Mikoliczyk
RB6 - MBX7R Eco
Old 07-18-2015, 08:23 PM   #1538
brocsizzle's Avatar
Made the car quite a bit stiffer, and a little edgy to be honest. I couldn't drive it as hard as before. That being said, we ran last wknd on a huge outdoor track, dry packed blue groove with low to med grip. I wished I had remembered the stock chassis, but switching it would've been a bit of work too. I can see how this chassis might be better indoors on higher grip surfaces, however i thought the extra 15g would've helped with adding more traction. I just ordered LAW52 and 53, the front and rear carbon composite stiffiners. Im gonna try those with with the stock chassis and see what that does.
brocsizzle is offline   Reply With Quote
Old 07-19-2015, 05:06 AM   #1539
Thanks for the response, I run on a low-md traction track so this really helps.
Old 07-19-2015, 11:56 AM   #1540
K_King's Avatar
Trader Rating: 39 (100%+)
Send a message via AIM to K_King
http://youtu.be/Pm0wFBXSH6Q
Here's my car from yesterday. Super easy to drive for me. Finally got rid of the snappy feeling on exit for me.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 07-19-2015, 12:12 PM   #1541
Regional Moderator
RobsRacin's Avatar
Car looked dialed! Sucks the battery dumped on ya. Setup sheet?
RobsRacin is offline   Reply With Quote
Old 07-19-2015, 12:46 PM   #1542
K_King's Avatar
Old 07-28-2015, 10:21 AM   #1543
Hi.
I reside in the U.K but I am over here on holiday at Oceanside, California
Can this top deck be bought online or from a shop and how much including shipping?
Cheers
James
jpmatrix is offline   Reply With Quote
Old 07-28-2015, 04:28 PM   #1544
fathead's Avatar
Originally Posted by jpmatrix View Post
Hi.
Cheers
James
James,
Yes they are available, sent you a PM
Slavich Design
Old 08-02-2015, 09:39 AM   #1545
Hey guys. Just starting to run my zx6 . at the track yesterday I did have a problem with the ball stud caps coming undone. Is there a way to get upgraded ones that clip tighter? And where is the best place to get gear diffs. I think that would make it a little less maintenance that the ball difs right? Thank you all for your help. I am running a shorty and the stock a arms as well.
katoom007 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
sho yoshida
