    Hide Wikipost
Old 03-01-2017, 06:23 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: tobamiester
Kyosho ZX6.6 New Parts
LA359B Center Mount Set (ZX6.6)
LA375 Center Diff. Gear Set(ZX6.6)
LA375-01 Center Diff. Gear Case Set(ZX6.6)
LA375-78 Spur Gear(48P-78T/ZX6.6)
LA376 Center Drive Shaft (71.5/ZX6.6)
LA377 Center Drive Shaft (79.5/ZX6.6)
LA378 Center Drive Shaft (88/ZX6.6)
LA379 Joint Cup Cover (ZX6/ZX6.6)
UM713B Rear Arms (from RB6)
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals:
Lazer ZX6.6 http://www.kyosho.com/jpn/support/in...20ZX6.6_IM.pdf
Lazer ZX6 http://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdfhttp://www.kyosho.com/jpn/support/in...ZER_ZX6_IM.pdf
After Market Bodies
http://www.jconcepts.net/shop/silencer-kyosho-zx6-body
Print Wikipost
Like Tree6Likes
Old 06-25-2015, 12:45 PM   #1501
Originally Posted by Schonded View Post
How much do one of these cost?
I think $25 for front shock tower, or rear or top deck parts
Dmitri Tech is offline   Reply With Quote
Old 06-25-2015, 03:14 PM   #1502
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Teufel Racing View Post
Which King setup did you go with? Cody or Kevin?
I've been using one of Kevin's setups and it's pretty good for me. A couple slight differences that I went with, gear diffs and the 7 front hub carrier vs the 10 that most seem to run. The 10 degree ones alway seem a bit too twitchy for me.
I've let a few guys drive mine and they say it's easy to drive, which is one thing that I like to have. Might not be the fastest on the track, but if it's a predictable and easy car to drive, then it's a couple less things I have to worry about. Just put most of that setup on one of the guys car that had drove mine and he was happy with it. Before he had been struggling with it being inconsistent felling to him. One day it'd be good and on another it wouldn't be.
Side note on the gear diffs,
Make sure you do the bearing mod, it really helps. After having ran mine for a good while, it seems that they like to be driven just slightly more on power than the ball diffs did. Not sure of its a good thing or bad thing, just one difference I felt between the two.
Kevins. It feels like there is something wrong with the car. I rebuilt it and made sure everything was good.... The car had way too much steering, and I'm coming from a bmax4 III which has mad steering.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 06-26-2015, 03:06 PM   #1503
Originally Posted by vikingen View Post
anyone with some feedback regarding running the Bezerk top deck for the ZX6 ?
Here are a couple pics, light i had was not very good and i rotated one with white back ground
Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-img_2837-small.jpg   Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-img_2836-smakk.jpg   Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread-img_2831-small.jpg
Old 06-26-2015, 04:00 PM   #1504
great news, I got some more tuning done with the car and got it really good. Just needed to change the front track width, lengthen the wheelbase and the biggest thing was getting the springs right.... oh and also the gear diffs are beautiful, just like all kyosho parts... car is as good as my yokomo bmax4 III....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 06-26-2015, 04:37 PM   #1505
Stevomatik's Avatar
how big of a difference will I feel putting the clear x rings in the shocks compared to the stock o rings
Stevomatik is offline   Reply With Quote
Old 06-28-2015, 09:48 AM   #1506
K_King's Avatar
Trader Rating: 38 (100%+)
Send a message via AIM to K_King
I've really liked my car, except on exit of corners lately. I tried running the shocks laid down a little bit, but decided to keep that angle and bring it in. It definitely helped the car for me, as it settled the front end down quite a bit on exit. I probably lost a tick of turn in, but I actually ran faster laps with this because I was able to be so aggressive with it on exit where I couldn't be before.
TLR - Spektrum - Pro-Line - Team Orion - Stickit1 - Schelle
K_King is offline   Reply With Quote
Old 06-28-2015, 07:48 PM   #1507
vikingen's Avatar
they do look nice.
I installed mine on the weekend before racing. I didn't get the flex version, but just by holding and flexing the chassis by hand, the standard setup is a fair bit more rigid than with the normal bezerk top deck
car was easier to drive and had more rear grip. ended up making the modified Amain, so a decent result. 9th off the grid with an 8th in leg 1, a 3rd in leg2 and a dnf in leg 3 (esc switch) for 7th overall
vikingen is offline   Reply With Quote
Old 07-01-2015, 02:23 PM   #1508
ProfessorX's Avatar
Trader Rating: 17 (100%+)
Is everyone running the 713b rb6 rear arms on zx6 ?????
ProfessorX is offline   Reply With Quote
Old 07-02-2015, 05:50 AM   #1509
Yup, I believe its quite common to do so....
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 07-03-2015, 04:01 PM   #1510
chriso138's Avatar
Default zx6 body
does anyone know if the body for a zx5 sp fit a zx6? thanks
Kyosho lazer zx6
kyosho Ultima rb6
Kyosho inferno mp9 tki3 with tekno v4 conversion kit
chriso138 is offline   Reply With Quote
Old 07-03-2015, 04:07 PM   #1511
Default Reply
It's a little longer.
Hurt'n4SomeDirt is offline   Reply With Quote
Old 07-03-2015, 06:44 PM   #1512
chriso138's Avatar
Can it be trimmed shorter or is it just too different ?
When is someone gonna make a body for the zx6 ?
Old 07-03-2015, 06:49 PM   #1513
Regional Moderator
RobsRacin's Avatar
No the zx6 is longer than the zx5. You can make the body fit but its not the best It will be short up front
RobsRacin is offline   Reply With Quote
Old 07-04-2015, 10:21 AM   #1514
Is it possible to just buy the front brace pills without having to buy the braces, like you can for the rear? The fronts are smaller,also does anyone have some gear diffs they want to sell?
sealander is offline   Reply With Quote
Old 07-04-2015, 11:06 AM   #1515
Jconcepts released a silencer body for the ZX6 a few weeks ago and it is available on their website.
Rotten is offline   Reply With Quote
