Casper-rc Upgrade Thrust bearing for AE and TLR 22 Diffs
#31
Nope. Just slightly smaller. That those would fit the K car diff but it was hard enough finding the size I got. I think you can use the AE diff screw and nut with the "K" diff but then you have to adjust the diff with a wrench in the end and not be able to use the hole in the outdrive.
#33
That truck uses a 2.5mm all thread screw from what I see in the manual. My thrust bearing should fit on that just fine. It would be important to look close at the thrust washers though and put the bigger hole washer on second (away from the bolt head) to make sure it works properly but if that diff screw is an all thread this bearing would fit.
#34
Hey Casper, I'm gonna rebuild my diff with your bearing kit, should I use the thrust washer with the larger hole on the inside or outside? I remember you mentioned it a long time ago back in the 22sct thread that it'll work fine both ways, but preferably one way vs. the other but I don't remember. I looked on your first post but didn't see any mention of it. I'll also make a notation about it on the front page of the 22sct thread. Also does the big hole washer placement differ from AE to TLR cars or the same either way?
#35
The small hole goes against the head of the screw.
Thanks for updating the other pages Scott.
#36
I will be at Round #4 of the JBRL this weekend at Controlled Chaos Raceway in Palmdale Ca. One of my sponsors will be giving out new Radix car stands to all paid entries to this event.
http://www.rcidcustom.com/upgraderc/...t/UPG1876.html
www.jimmybabcock.com for more details on the upcoming event.
or latest news:
http://www.rctech.net/forum/californ...ad-series.html
or latest news:
#37
Update from this weekend...
Casper-rc thrust bearings took top two positions at round #4 of the JBRL in Modified 2wd SC.
Took the top spot in Modified ST truck. I did not podium with some electrical issues but did set fast lap for the main.
Super high bite track and diffs lasted great!
Ran Mid motor setups due to extreme traction level. We will be posting setups soon.....
#38
Giving these a shot..lord knows I hate dropping the stock ones and spending 30 minutes looking for the dirty little grit magnets lol
#40
#41
All right Casper, just got two of them...
Thanks a ton for all you do...
Canada Dave
Canada Dave
