4s Batteries or 2s lipos with internal bullets in series >
Old 06-03-2013, 05:27 PM
pekow91's Avatar
Trader Rating: 45 (100%+)
Default 4s Batteries or 2s lipos with internal bullets in series
I was told by a few people that running two 2s lipos with internal bullets in series on an ebuggy with an RX8 1900 combo would get too hot and melt the pack and the connectors.
I have been running this setup on a larger track with pretty good size jumps for a few months now and havent really noticed any issues. The outside temps at the track can get up to 100 at times. So, I was wondering if this is a real issue and if I should make the switch to 4s lipos.
pekow91 is offline
Old 06-03-2013, 05:54 PM
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I see no reason to get 4s packs. If/when I get into ebuggy, I will be running smc dual 7200's 70c.
Wildcat1971 is offline
Old 06-03-2013, 06:03 PM
pekow91's Avatar
Are you going to go deans or internal bullets?
pekow91 is offline
Old 06-03-2013, 06:16 PM
A lot depends on the quality of the connectors being used (and perhaps the soldering). Solid bullet style connectors are much better than spinning cage banana style.
I prefer a single 4S pack for simplicity, fewer connections and wires that might cause issues, perhaps easier to securely mount. Other than a saddle pack car of course, then the question isn't terribly relevant anyways.
Regardless if running 2 packs together it’s best to use identical packs purchased together and kept as a set. If not any capacity differences caused by different use, cycling, age, etc, can increase chances of running one pack too low.
Dave H is offline
Old 06-03-2013, 06:34 PM
I would use bullets most likey. maybe even the promatch packs with 5mm bullets.
http://www.promatchracing.com/prodde...od=CC720080CV8
Old 06-03-2013, 06:59 PM
My serpent buggy, as well as every other serpent Ebuggy that can only run 2 separate 2S batteries in series disagree with them... and yes i run good 4mm bullets, the long split type, not the kind with the crappy spring cage connection.
can't even mount a 4S in the car if you wanted to.
There are many more advantages to doing it that way.
DsWright is offline
Old 06-03-2013, 07:19 PM
Devigili22's Avatar
Trader Rating: 29 (97%+)
I have been running direct (solid, not birdcage) bullets for a while in an 8T and have had no issues.
Devigili22 is offline
Old 06-04-2013, 01:20 PM
pekow91's Avatar
ok. Has anyone had issue then? I guess I will just stick to the internal bullets if not.
pekow91 is offline
Old 06-04-2013, 01:35 PM
Trader Rating: 53 (100%+)
This........
However, I've recently switched over to 2s x 2s shorty packs due to the weight savings and variable weight distribution they offer, which is working out great! Most 4s packs on the market are way over weight(too many maH) and too big/tall for most bodies (with the exception of the newer 3500-4300 protek packs). I don't need 5000 or 6000+ mah batteries, I can run 10 minute mains on 4300mah every time. Now only if they offered 4s 4000-4500maH shorty packs!
nv529 is offline
Old 06-04-2013, 01:50 PM
some places do 15 minute mains....
Old 06-04-2013, 01:54 PM
UrabusDenis's Avatar
I see no reason to buy 4S packs, you can use your 2x2S packs if you race in any form of 1:10th. The only reason would be the price, but they aren't cheaper at all then 2x2S packs. I have always ran 2x2S (with bullets) and I never had overheating or melting issues nor have I ever heard of this. Furthermore, with 4S if one cell is bad the whole pack is gone while with 2x2 setup if one battery is bad you only need to replace that one. So to put is simply, go with 2 packs, especially if you have any 1:10th car
UrabusDenis is offline
Old 06-04-2013, 02:03 PM
kufman's Avatar
This is a really dumb idea. If you have many cycles on a set of 2s packs and one dies, then putting a brand new pack with an older pack is asking for problems. Also, if you are running 2x2s packs in a 1/8th, you shouldn't be using these packs for other applications. You should treat them as a 4S pack and always use them together.
kufman is offline
Old 06-04-2013, 02:07 PM
bigbadbasher's Avatar
In my 1/8 truggy, i run 4S packs only. I did use a couple of 2S packs in series a couple times but i never felt comfortable doing it, not sure why. When you have a single tray, why use two different batteries? Maybe that was my logic behind it lol...
bigbadbasher is offline
Old 06-04-2013, 02:09 PM
kufman's Avatar
That main advantages of a single 4S pack are the weight savings and the convenience of only charging a single pack.
Over time, internal bullets are a hazard because they will wear and they will not make as good of a connection. It is true that Deans will wear, but they are not attached directly to the battery tabs where additional heat can be a problem.
kufman is offline
Old 06-04-2013, 02:53 PM
If you for example buy 2 new packs and one of them is wrong (it can happen), it's better to replace it then to replace the whole new 4S pack. Other than that I agree with you, if one pack is bad I retire the other one for 1:10 training. However I do use one of my 2x2S sets also for 10th scale, I think that is you use them equally (eg. both packs get one 6 minute run in my TC) they will remain the same. I simply don't want to spend that much money for so many packs. I compete at a national level in 1:10 TC and 1:8 ebuggy, that is at least 2x packs for TC an 2x2S for ebuggy, that is 6 packs (plus all of them need to be at a racing level, also know as: NEW) every year which is too much for me. Plus I always balance my LiPOs and take very good care of them.
