Best tires for loose dirt/gravel?
I was planning on taking my RC10B4.1 with me to my in-laws in northern Nevada and run it. The property is two acres of loose dirt with some small gravel. So, I was wondering what would be the best tires to run?
Suspended
I think Proline Badlands or HoBao Angle spikes are best tire for loose fine gravel.
For my all around tire of choice, Proline dirt hawgs all around.
Lugs are flat and work on asphalt
Low wear
Medium compound
Available for fronts as well.
I've had a set for just about every vehicle I've owned specifically for testing and bashing.
Momo
Low wear
Medium compound
Momo
Bow tie at the rear and hot shot at the front, soft compound will do the job.
R/C Tech Elite Member
Pro-Line Badlands all around
I thought it was a T4 not a B4... LOL
Then you could go with Step pin type tires on the rear or PL Dirt Hawg all around.... Forget the Badlands
