Brown-outs with HV servo directly on 2s Lipo ? Or something else ?
I'm running a HW Sct Pro Esc and 2s battery. I recently installed a Savox 1268 HV servo connected to my Esc (so not running high voltage) and noticed brown-outs, so I figured I'd hook up the servo directly to my lipo to
a) prevent brown-outs and
b) run it on 7.4v.
Tried that, seemed to work fine, now I was running my car again yesterday and I noticed after running for a while sometimes the steering wouldn't react properly again. The battery *was* running kind of low, but it still had enough oomph to power the motor...
To the best of my knowledge (which admittedly isn't very good) a 7000mAh 50C battery should be able to cough up 350 ampere, so to me it seems unlikely to be a brown out.. (?) The throttle was still working fine so the Esc hadn't even gone into LVC yet so I figure there should be enough power left to power the servo and RX as well.
So if it's not a brown out, what else could it be ?
b) run it on 7.4v.
b) run it on 7.4v.
b) run it on 7.4v.
b) run it on 7.4v.
b) run it on 7.4v.
Put a glitch buster capacitor on it before you try to hunt down the electrical gremlins. UFO is on the money though with his very detailed chart on how the system behaves under load! Also, what receiver are you using?
My setup :
Losi Ten SCTE
Hobbywing 3656SD 4-pole sensored motor (4700kv)
Hobbywing SCT Pro Esc
LRP C3 Rx receiver
Gens Ace 7000mAh 50c batteries
I already ordered the Novak glitch buster (#5626) for the receiver side, and the Timing Esc powercap (#5689) for the Esc side with the idea "Overkill! Better safe than sorry !" before realizing I really don't know whether the powercap would be of any use...
So with regards to the Esc-side power-cap :
- would it actually be of any use in my setup ?
- am I correct it should be soldered with red & black wires directly on the esc's battery connectors ?
- does it actually help if I install it this way on my Esc, or would the Novak power cap only work when replacing another cap (instead of just adding it like I'm planning to do) ?
Yes, I do realize normally the proper order would be to do my research first and the buying second, I was caught in the heat of the "must fix! must buy new stuff!" moment
Losi Ten SCTE
LRP C3 Rx receiver
- It will help some
- Yes, to the ESC battery posts/connections.
- More capacitance is good, Speed Passion which at least used to be HobbyWing based sells upgraded larger caps, Novak too for some models. Should be OK.
Is it primarily a servo issue, or is the radio not responding, weird throttle too? If the throttle is having issues putting the glitch buster in the receiver as normal makes sense. But if the throttle is fine and it’s just steering weirdness it might be better I think to put the buster closer to the servo, of course that likely means splicing into the servo wire.
P.S. Am I right in assuming the receiver is also connected direct to lipo?
Sorry, no the receiver is powered by the ESC since it only goes up to 6v. I figured no longer powering the servo from the Esc would mean the receiver should be fine.
As far as I could tell it was just a steering issue, but I thought it would be impossible for the servo to brown-out when connected straight to the lipo...
IMO, putting a capacitor one the battery posts won't do much (unless it's pretty large). When the voltage drops, the capacitor is going to dump to help maintain voltage. The power that it contained is going to flow towards the path of least resistance, which in this case would be the battery. If you're trying to save the steering with a capacitor, I'd splice it like Dave H recommended into the servo wires. The thing that I would add to that is that you'd need to include a diode to keep the power from flowing back to the battery when the voltage sags. This way the servo is sure to get all it can from the cap.
The other option, since you're setup to run HV, would be just to run a separate battery such as the one of the one's in the following links. They weigh the same to just over what the cap(s) weigh, and you're guaranteed no issues.
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
http://www.hobbyking.com/hobbyking/s...ade_130X_.html
According to what I read on the novak website the power cap is supposed to be soldered to the battery connectors..?
Since the servo is wired to the same battery connectors on the ESC, wouldn't that be the same thing ?
Since my electronics knowledge is fairly non-existent, can you draw me a simple schematic on how to connect the diode(s) ? (Should I use a Schottky diode ? I'm trying to read up on this as we speak)
My LRP C-3 RX is powered by the Esc's 6v BEC, which only has to power this RX since my servo is powered straight from the lipo. I figured that would take load off my ESC so the RX would be fine and the Servo would be fine..
