Motor ? Plz help
All of those are good motors, just a hugh amount of power!!! Depends on what u are runnin them in will have alot to do with what one u need!!
Are those motors from the 4pole 1406 series or the 2pole cms36 series?
Anyway the 3800kv is a strongest of all castle 540 size motors, the 4600 4pole would be more easily tamed in 2wd. The 2poles need to be geared lower or they heat up more.
u don't want to much power in a 2wd because control becomes an issue then:
Well acceleration is needed on a track that has short burst, but if there are long straits and just mild turns and so forth then u can get higher gearing, u wanna watch your temps tho as u gear higher, don't wanna toast nuttin lol
