Old 02-13-2014, 09:07 AM   #1396
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by akshayp14 View Post
this has happened to me as well casper
Again one shaft or different locations.
I have seen where shock shafts don't get deep enough threads on them and will not properly bite on the ends. Really hard hits something is going to give as well. Better a shock end then a bent shock shaft or something like that.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-13-2014, 12:40 PM   #1397
I've decided to run 1400kv with 6s in my E, I think. But what I can't find is the specs on the battery tray. I want to know what physical size battery will fit in the car nicely. I assume most will based on the video about how versatile the battery box is.
Can anyone give me the width and length in mm of the tray?
Thanks...
Clay Grantham
TLR 8ight 3.0/Futaba 4PLS/WERKS B5 .21/VP Fuels
motoclay is offline   Reply With Quote
Old 02-13-2014, 01:01 PM   #1398
1badgoat's Avatar
Thanks...
155mm x 53mm approximately.
TLR/Futaba/Hitec/Tekin/Hyperion privateer
1badgoat is offline   Reply With Quote
Old 02-13-2014, 01:51 PM   #1399
Awesome!! Thanks
Clay Grantham
Old 02-15-2014, 05:24 AM   #1400
bluegroovelosi's Avatar
Default Front End Upgrade Parts
The UPS man brought me a nice $70 box from A Main Hobbies yesterday - containing the TLR3510 Front Overdrive Gear Set and the TLR341000 Brass Weight System.
Looks like a simple enough upgrade to get some more front end grip from my Losi 8ight 3.0! Every little bit helps!
Robert Conner
Omaha, Nebraska
Team Losi 22 / 22-4
Fusion Batteries / Orion Chargers
Viper VTX10R ESC's & Viper VST motors
Spektrum DX3R Control / S6040 Servos / SR3001 Receivers
AKA 2WD and 4WD Tires
bluegroovelosi is offline   Reply With Quote
Old 02-15-2014, 07:04 AM   #1401
C.Capelo's Avatar
Trader Rating: 113 (100%+)
Robert Conner
Omaha, Nebraska
On a smooth track I ran and liked the overdrive gear on my 3.0 nitro buggy. I know many others like the overdrive gear on their 3.0E especially on tight indoor tracks.
C.Capelo is offline   Reply With Quote
Old 02-15-2014, 09:42 AM   #1402
doesn't having a different ratio diff in front than rear mess with center diff?
chuckb is offline   Reply With Quote
Old 02-15-2014, 01:20 PM   #1403
just makes the center diff work a bit more i guess, but nothing it can't handle.
akshayp14 is offline   Reply With Quote
Old 02-15-2014, 04:46 PM   #1404
Default Overdrive Ratios
The overdrive gear ratio is 3.230, while the stock gear ration is 3.307 - a difference of only .077.
The center diff can handle all sorts of power differences from the constantly changing loads of the front and rear diffs. That's what it's supposed to do. A .077 near-constant difference shouldn't even be detectable.
Robert Conner
Omaha, Nebraska
Team Losi 22 / 22-4
Old 02-16-2014, 07:30 AM   #1405
What C rating do most of you guys use? I have no idea where to start....I plan on 6s 1400kv but I would also like to know what u run on 4s 1900kv....thanks
Clay Grantham
Old 02-16-2014, 07:46 AM   #1406
XXXDad's Avatar
Trader Rating: 195 (100%+)
Lightbulb 50 C and up
Not sure if your just a basher... but 6's are not legal for most racing. I recommend 2- Shorty packs that way one one goes bad you can just replace one LiPo rater than an expensive 4 or 6 cell
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 02-16-2014, 09:07 AM   #1407
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
I've got nothing but luv for the EcoPower 4S at $54 a piece, plenty of punch, light, and enough juice to make 10 minutes with a 1900kv ya can't beat it.
Matt Reinders
8ight E 3.0
Elite Performance
GMS_Racing is offline   Reply With Quote
Old 02-16-2014, 01:52 PM   #1408
Default 3.0 Manual
Hey Does anyone know if the 8 3.0 manual that comes with the kit has a setup guide like the old kits did? I bought a used kit and printed off the manual on the tlr site and it did not have any set up guide...
BenG477 is offline   Reply With Quote
Old 02-16-2014, 03:10 PM   #1409
It's on the TLR site!
Basic setup: http://www.tlracing.com/ProdInfo/Fil...dard_Setup.pdf
Blank sheets: http://www.tlracing.com/ProdInfo/Fil...lank_Setup.pdf
Got-R/C? is offline   Reply With Quote
Old 02-16-2014, 03:19 PM   #1410
Anyone have any pics of their car ready to run?
I was looking at my wiring last night and routing, just curious how a few of you have set yours up? Forgot to order a longer sensor wire so looks like another week before I can get out and run it. Also, where are you mounting your transponder with the radio box? Anyone running a HOTWIRE?
Other than soldering and painting the body, I'm about ready to practice and start racing again..
Tags
e-buggy, eight 3.0, losi, spur gear
