Old 02-05-2014, 05:53 AM   #1336
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Tlr242001 is the front center dog bone for the nitro car.
TLR242002 is the front center dog bone for the E car, which is the same length bone as the nitro rear.
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 02-05-2014, 07:50 AM   #1337
1buzz1's Avatar
Thanks, just confused me because i found 242001 in the instruction portion of E 3.0 manual, but then in the exploded has correct part#
1buzz1 is offline   Reply With Quote
Old 02-05-2014, 08:02 AM   #1338
Rxfisher's Avatar
Trader Rating: 18 (100%+)
Default shock issue
Love the buggy, but I've been having some issues with the shocks,
The screw holding the nylon piston comes loose, I might have it figured out.
I use nitro spray cleaner to clean threads on piston shaft and red lock tight on screw now, but only run a few times. A lock wash would be great if I could find one small enough. The Scte-ten from losi has treaded lock nut on the shock shafts, I wonder way they went with just a screw for the buggy shock.
Any other ideas that have worked for you guys...
22 Losi Buggy, HPI BLitz, ECX Torment, Duratrax Element, ten-SCTE 2.0, tekin gen1, pro4 4600, losi 8ight 3.0, orion r8 pro
Rxfisher is offline   Reply With Quote
Old 02-05-2014, 10:10 AM   #1339
Brian Miskolczi's Avatar
Trader Rating: 156 (100%+)
Make sure you clean the screw and shock shaft with a parts degrease r, Denatured alcohol etc., apply locktite and make sure to get the screw nice and snug, don't be afraid to torque down on it to make sure it is nice and tight.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 02-05-2014, 10:26 AM   #1340
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Also make sure you let the loctite dry in the air. It will never dry when drenched in oil!
pimpedaccord is offline   Reply With Quote
Old 02-05-2014, 10:35 AM   #1341
MasiisaM's Avatar
Originally Posted by Casper View Post
We typcially don't feel the need to shim the front diff but you can if you want. Don't make it too tight but it can be done. The rear ring and pinion gear get a lot more load and more attention is paid to that mesh in general. The buggy tends not to have many problems with this compared to a truggy
Thanks Casper for the reply...I will leave it if its not a concern.
For whatever reason though im having a huge issue with the front end attaching to the chassis (page 21) It will not slide down in the back to have it flush to screw in. It's almost like part#LOSA1754 is to small. I would not think i have to file it..i mean its a solid 1-2 mil i would have to take off.
Then where does part # TRL241003 go? its the last in the sequence to bolt up, but the instructions doesn't show where it goes.
Anyone on what i'm doing wrong?
MasiisaM is offline   Reply With Quote
Old 02-05-2014, 12:25 PM   #1342
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
I had to purswade mine pretty good to get it to fit when I built my kit 2 weeks ago. It'll go trust me
Matt Reinders
8ight E 3.0
Elite Performance
GMS_Racing is offline   Reply With Quote
Old 02-05-2014, 12:31 PM   #1343
slakr's Avatar
Trader Rating: 28 (100%+)
I put mine together a few weeks ago and I don't have the car in front of me to look at right now... but I believe that part goes under the front of the top plate and is also secured with the two screws that go through the front of said top plate.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 02-05-2014, 12:43 PM   #1344
Default camber links tight.
just finished building mine and getting ready to wire it up.
front end is not free. I know it is the camber links. I thought I read on here to squeeze with a pair of pliers and it frees up.
sounds stupid, but I squeezed them and not freeing up. can someone post a pic of how they do this or do I need to just do with a lot more pressure?
vic0280 is offline   Reply With Quote
Old 02-05-2014, 01:09 PM   #1345
Casper's Avatar
Trader Rating: 34 (100%+)
Yeah it takes a hard sqeeze to deform plastic a little around the ball a little.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-05-2014, 01:45 PM   #1346
rcgod's Avatar
Trader Rating: 27 (100%+)
What is the small plastic piece that screws into the chassis right behind the front diff case? Don't know what it's for.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 02-05-2014, 01:47 PM   #1347
Casper's Avatar
It is not easy but it will go. It is meant to be tight so when you take hard hits you take it through the chassis and don't break the front bulkhead instead. Once you do it once or twice it gets easier.
You talking about the little piece? It goes between the front diff case and the front of the triangle upper deck.
Old 02-05-2014, 02:16 PM   #1348
That is basically a hole cover. It covers the holes used for the brass weight that is available for the car.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 02-05-2014, 02:36 PM   #1349
rcgod's Avatar
Thanks!
Dialed RC Hobbies
Old 02-05-2014, 03:26 PM   #1350
drepus's Avatar
Here's what has worked well for me over the years racing losi/tlr 1/8's.
1 Thread the screw (with washers installed) through the piston. Brake clean the screw/piston well and wipe off the screw threads with a clean towel.
2 Brake clean out the hole in the shock shaft. This hole is very deep (1/2" at least) and will hold quite a bit of brake clean wayyy down inside. This must be removed or it may negate the threadlock!!! You can leave the shaft for awhile till the brake clean evaporates (it takes awhile) or do as i do. Roll up a torn corner of paper towel into a long point and use it to wick out the brake clean. You will know when you get it!
3 Set both aside for a few minutes to make sure they are totally dry.
4 I use very well shaken "blue" threadlock and coat the screw (still installed in the piston) and run some down the hole in the shaft. I use a small allen key or a pin to make sure the inside of the hole is well coated.
5 Install tightly and wipe off the excess.
6 Wait 10 minutes or so before you fill the shocks with oil just incase it interferes with the curing of the threadlock.
I have not lost a piston since the original 8ight came out using this method. If you want to change pistons and the screw doesnt want to budge for you, heat the screw head with a solderring iron for 15 seconds and try again. The heat breaks the threadlock down just enough to remove it without damaging the pistons. I usually have other shock shafts all set up with other pistons for when i want to try something different instead of changing pistons on the same shafts.
Dave Henry
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
