Old 02-02-2014, 07:32 PM   #1321
Rxfisher's Avatar
Trader Rating: 18 (100%+)
Default Thanks
That will work. Very good
22 Losi Buggy, HPI BLitz, ECX Torment, Duratrax Element, ten-SCTE 2.0, tekin gen1, pro4 4600, losi 8ight 3.0, orion r8 pro
Rxfisher is offline   Reply With Quote
Old 02-02-2014, 10:15 PM   #1322
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
Originally Posted by Rxfisher View Post
I run a large out door track has anyone found mud guards that work on the 3.0
The DE ones from the 2.0 work
Matt Reinders
8ight E 3.0
Elite Performance
GMS_Racing is offline   Reply With Quote
Old 02-03-2014, 12:17 AM   #1323
Salkin's Avatar
I use mudguards and skid plates from DE Racing. And I use the same for the 8ight 2.0 and 3.0. They are interchangable.
Salkin is offline   Reply With Quote
Old 02-03-2014, 06:15 AM   #1324
Originally Posted by slakr View Post
TIP OF THE DAY ...
As an FYI, I use these, but I also used these as a template to make more of them out of a small black Rubbermaid garbage can (with the durable/flexible rubber/plastic material). The black ones look better, and are esentially unbreakable!
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 02-03-2014, 03:49 PM   #1325
Rxfisher's Avatar
Default Great idea
Very neat idea, I'll make a template before I mount
Old 02-03-2014, 05:06 PM   #1326
F3ckLand's Avatar
Anyone know of a good rear skid plate, also i seen a video that showed an 8ight with a 3M like clear protective sticker on the bottom of his chassis to reduce scratching. You think he just made it himself or have you seen anywhere you can buy them pre cut? I'ved looked around online but couldn't find much. TIA
**TLR 8ight E 3.0**
Losi Mini 8ight
Rustler
MT2
F3ckLand is offline   Reply With Quote
Old 02-04-2014, 12:08 AM   #1327
Salkin's Avatar
DE Racing makes front and rear skid plates for the 2.0 (3.0).
I have previously used skid plates, but I do not do that anymore. If you are into finetuning and adjusting your car, skid plates have a negative impact on the ride height adjustment, as the car will have a tendency to more often bottom out and bounce back (especially on jumps), than if skid plates are not used.
I don't think the very thin sticker like skid plates will protect the chassis plate much on a real dirt track. Maybe on an astro turf/carpet track.
Guess no serious racer uses skid plates. The chassis plate wears more quickly, but if you can afford buying a new one every second season or so, I would not use skid plates.
Old 02-04-2014, 12:19 AM   #1328
Salkin's Avatar
Originally Posted by GMS_Racing View Post
So if I'm at like 3450 ready to race I probably need to fatten her up a little?
I do not think you need to add more weight, if you are in the 3400g region.
Im not a pro racer, but total weight is more a tuning option. Ligther for some tracks, and heavier for other tracks. Guess for smaller technical indoor smooth tracks a lighter car setup is prefered, and on a large bumby outdoor track a little more weight adds stability.
In the example I provided on the weight I included the weight of 2x2s 6000mah lipos.
I often also use 2x2s 4200mah shorty sticks, that shaves approx. 250g off the total weight, and the total weight is then more or less the same as yours.
I like the lighter setup better, but use the heavier setup in finals, as I'm not totally sure that I can get 10 min. out of my shorties.
Old 02-04-2014, 02:48 AM   #1329
Texco's Avatar
Hey lads!
Getting a TLR 8ight-E 3.0 soon and this will be my first Offroad kit! yay me!
Apart from the electrics what will I need to get this up and going?
I know I know i could just google or go through all the pages but i know you boys are pretty cool and wont mind another Noob question like this! haha
So thanks in advance!
Texco is offline   Reply With Quote
Old 02-04-2014, 03:08 AM   #1330
Salkin's Avatar
Originally Posted by Texco View Post
Hey lads!
I started with the car, a lipo and a small charger and ended up with more or less double of everything. 4-7 packs of lipos. 2 chargers. Lots of tools, oils (diff., shocks etc.), multiple sets of tires.
Some have a complete spare car, some just buy the parts that brakes the most, which roughly is all the parts in the front clip from the diff and out, rear arms and hub carriers.
A set of bearings, screws and washers are also good to have.
Camber and ride height gauges. Good to have even if not a pro driver. Help to set up the car (basic) and help to check the car "alignment" after heavy crash and use.
Phew The car itself is one thing, to keep it running through practice and races is another
Your local TLR hobbyshop is gonna love you
Old 02-04-2014, 04:11 AM   #1331
Hey lads!
I'll sell you my race-ready spare for $600 shipped. It is a multi race winner, and has the best of everything. Over $1,100 invested! It is set up to KILL--we'll help you with everything. PM me on this. See post:
TLR 8ight e 3.0 - multi race winner!
Old 02-04-2014, 07:20 AM   #1332
Car already sold!
Old 02-04-2014, 10:48 AM   #1333
MasiisaM's Avatar
Hey all..
Did anyone else need to shim the front diff mesh? I just started my 3.0 e build last night and the mesh seemed pretty loose. I used to having it tighter, but the last car i built was over 5 years ago.
MasiisaM is offline   Reply With Quote
Old 02-04-2014, 12:08 PM   #1334
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by MasiisaM View Post
Hey all..
We typcially don't feel the need to shim the front diff but you can if you want. Don't make it too tight but it can be done. The rear ring and pinion gear get a lot more load and more attention is paid to that mesh in general. The buggy tends not to have many problems with this compared to a truggy
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-04-2014, 07:48 PM   #1335
1buzz1's Avatar
Can anyone tell me the difference between part #tlr242001 and 242002, both numbers are listed in the manual but tlr242001 seems to be to short thanks
1buzz1 is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
