Old 01-12-2014, 10:09 AM   #1231
GMS_Racing's Avatar
Trader Rating: 65 (100%+)
It's an apple thing I can't view the sheets on my iPad, but can on my PC.
Matt Reinders
8ight E 3.0
Elite Performance
GMS_Racing is offline   Reply With Quote
Old 01-12-2014, 10:21 AM   #1232
I have all apple stuff so I guess I can't view it
Losi8ightfanty is offline   Reply With Quote
Old 01-12-2014, 10:55 AM   #1233
drepus's Avatar
I have a free app on my ipad that let's me see them.
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 01-12-2014, 11:09 AM   #1234
urluzn's Avatar
Trader Rating: 28 (100%+)
You can download the adobe app reader and it will work for apple.
Team Associated~ Reedy~ Proline~ EZcustoms~ FDJ
urluzn is offline   Reply With Quote
Old 01-12-2014, 11:41 AM   #1235
Just tried that. Unless I did something wrong, it didn't work
Old 01-12-2014, 12:46 PM   #1236
urluzn's Avatar
Using the ipad/iphone after you download that app, when you click on the setup download on the tlr page at the top of your browser it will ask if you want to open in adobe.... just click that icon at the top and it should open.
Old 01-12-2014, 02:18 PM   #1237
dtr
dtr's Avatar
Hope this will be readable; rctech has automatically converted my upload.
dtr is offline   Reply With Quote
Old 01-12-2014, 05:53 PM   #1238
That worked. Thank you very much
Old 01-12-2014, 05:54 PM   #1239
I can read it and thank you too.
Old 01-12-2014, 06:44 PM   #1240
urluzn's Avatar
Good to go! Your welcome losieightfanty.
Old 01-14-2014, 09:28 AM   #1241
Default wickerbill
can someone explain to me what the wicker bill does? also in adam drake's setup sheets when he says wing forward I am assuming that mean no spacer at all, bolt it right to shock tower. also if he doesn't specify which wicker bill I assume he isn't running one.
thanks.
Tekno SCT 410.3 rx8gen2/pro 4 4300HD 1267 savox servo
Tekno EB 48.3 rx8gen2/t8 1900kv 1267 savox servo
Tekno NB 48.3 Novarossi 5PXLT 1267 savox servos
all controlled with spektrum dX4R
skyler hays is offline   Reply With Quote
Old 01-14-2014, 10:20 AM   #1242
Casper's Avatar
Trader Rating: 33 (100%+)
thanks.
Wicker bill adds drag to the wing for additional downforce.
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-14-2014, 07:17 PM   #1243
So I'm looking to get back into racing R/C again and finally finished reading the entire thread. I just wanted to confirm some CLIFFS on the thread and see if anything has changed since the start 4-months+ ago...
Building the kit:
1: Squeeze the ball ends to eliminate any issues with suspension binding or not being smooth
2: Ditch the plastic motor spacer
3: Kit shock oil is junk- use TLR oil (get 27.5/30/32.5/35/37 to start?)
4: Stock pistons are okay?
5: Stick with the kit setup to start- 10deg kick for indoor and 0 inserts - 5/5/3 (Should I go ahead and get Green/Silver springs since lots are using them?)
6: Don't use the receiver box
Aftermarket parts to start:
1: Use the TLR244005 Steering rack set
2: Use the LOSA9903x steering arm
3: Gearing- start with 14, 15, 16, 17, 43, 45
4: 250mm+ sensor wire is needed
Motor/ESC:
For a large track Tekin RX8 Gen 2 / T8 1900kv
For indoor small tracks T8i 1900kv
Spare parts to have:
1: Extra front/rear arms
2: Aluminum rear hubs from 2.0 (but not necessary)
3: Front dog pins - use MUGC0270
Has anything changed from that since the thread started? Anything else I should know or do before I order? Anything I should add?
What servo are most of you using?
Got-R/C? is offline   Reply With Quote
Old 01-15-2014, 06:23 AM   #1244
Matt :-)'s Avatar
I like the HITEC HS- 7945TH
Titanium gears
6v .12/250
7.4v .10/319
Matt :-) is offline   Reply With Quote
Old 01-15-2014, 10:32 AM   #1245
easy e's Avatar
For me, I like the receiver box and 14t pinion/stock spur with 1900kv
easy e is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
