Old 01-09-2014, 01:10 PM   #1216
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by JoeW View Post
Thanks!
So should I start with the same weight fluids, just buy the TLR fluid in the bottles?
I hope the kit diff fluids are ok to use? I hate breaking the cars down to change diff fluids...shocks are easy
Also...the TLR site does not list optional parts for the E version. Should I just look at the nitro version parts list for hop ups?
Looking at the online setup sheets...where are these 8 hole pistons (1.3 and "splits") from the Drake setup and the "up tapered" pistons from the Phend setup?
Going to use 5/7/3 diff fluids, 2.3 sway bars, kit springs and recommended shock fluid weights. And the basic Drake/Phend starting camber/shock locations etc.
Generally a hard packed outdoor rough track with some loose sand on top and in corners.
The diff fluids are fine. Yes for shock parts the 8ight 3.0 nitro parts are all interchangable. Just about anything not on the chassis. Front and rear clips are the same.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-09-2014, 09:00 PM   #1217
bluegroovelosi's Avatar
I was hoping to get some TLR assistance real quick.
I just built my 3e last night. I put the kit springs and shock fluids in it. The stock front fluid is 37.5 and rear is 35 as you guys know. With no electrics or anything the rears feel a little stiff but probably about right. The fronts are a problem...they seem way too stiff. If you drop the front from 3-4 inches it just stops like there are no shocks....no soaking at all. When you press the fronts down it takes a decent effort and they don't spring back like they should.
Is there any instance of faulty shock fluid or will this break in?
Also, what servo horn are you guys using? I used the 22 alum TLR horn on my SCTE but it looks too short for the 8.
I had this problem for weeks and thought it was just part of the break in process. Several guys at the track commented on how STIFF the front end was...how it wouldn't drop as fast as the rear end...not even close!
the first thing to check is whether it's the shocks at all. Take the shocks and sway bar off and see how loose everything is. Do the pivots have the correct number pivot in the correct position? Everything should slide up and down nice and easy...with virtually no resistance.
If the front end is tight (mine was), then crimping the plastic ends of the turnbuckles with pliers should mold the plastic to the ball studs. My front end got WAY looser after a simple squeeze of both turnbuckle ends.
Then I added the sway bar back into the mix. Tight. Again. The plastic '8' shaped connector got a squeeze with the pliers...nice and loose again.
THEN I put the shock back into their correct positions. Suh-mooooooth, baby!
Lesson learned: strip it down to the absolute basic moving parts, check for tightness or restrictions. Make sure the pivot points are the same number, in the correct position. Then add each moving part while checking for tightness until everything is back together and silky.
Robert Conner
Omaha, Nebraska
Team Losi 22 / 22-4
Fusion Batteries / Orion Chargers
Viper VTX10R ESC's & Viper VST motors
Spektrum DX3R Control / S6040 Servos / SR3001 Receivers
AKA 2WD and 4WD Tires
bluegroovelosi is offline   Reply With Quote
Old 01-09-2014, 09:23 PM   #1218
drepus's Avatar
Robert Conner
Omaha, Nebraska
Excellent description Robert!
Dave Henry
TLR/Losi Team Driver,Team Horizon,Spektrum,Dynamite,JR,Nitrotane,AKA,CRC,Pinnacle Hobby, racing since '86 (at least trying!)
drepus???? it's "superd" backwards since it was taken!
drepus is offline   Reply With Quote
Old 01-09-2014, 10:16 PM   #1219
JasonR/C's Avatar
lol i remember the release day of this car and there had to be 2-3 pages of people freaking out about the tightness. i was one of em lol.... love this car!
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 01-10-2014, 04:22 AM   #1220
lol
+1
akshayp14 is offline   Reply With Quote
Old 01-10-2014, 07:57 AM   #1221
Robert Conner
Omaha, Nebraska
It is critical that you do NOT use the oil that comes with the kit (it simply doesn't have the quality control and tolerances). Use TLR oil and you will see that the front (and rear) is where it is supposed to be. This is a very common problem, and happened to my team. This advice came from Ryan himself (and supported by all the local pros)!
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 01-10-2014, 11:44 AM   #1222
JoeW's Avatar
Thanks guys. Once I get the electrics in I will change shock fluids immediately.
JoeW is offline   Reply With Quote
Old 01-10-2014, 11:42 PM   #1223
JasonR/C's Avatar
Click on my youtube page in my signature for quite a few 3.0 videos!
Old 01-11-2014, 07:39 PM   #1224
Does this apply go diff fluids?
Tekno SCT 410.3 rx8gen2/pro 4 4300HD 1267 savox servo
Tekno EB 48.3 rx8gen2/t8 1900kv 1267 savox servo
Tekno NB 48.3 Novarossi 5PXLT 1267 savox servos
all controlled with spektrum dX4R
skyler hays is offline   Reply With Quote
Old 01-11-2014, 07:39 PM   #1225
Subscribed
Old 01-11-2014, 09:11 PM   #1226
rcgod's Avatar
Trader Rating: 27 (100%+)
Finally got a chance to race my 3.0 today and get used to it. It took me some time to figure out how it likes to be driven. First impression was it's super stable and easy to drive but not a lot of steering. Then I noticed that if I drove it easy into the corner it was really docile and stable, but if I was aggressive and threw it into the corner it handled more aggressive. Some cars change like that depending on speed, but this is the first one I've felt like the car will turn as hard as I want it to depending on how hard I drive it. What a great car! Does everything well, no complaints, no need to tweak it to make it better. Great job Losi.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 01-12-2014, 04:13 AM   #1227
Not nearly as much, but if you have the option, eventually have all TLR oils for consistency in setups. Oils are so cheap, it's one variable we shouldn't overlook!
Old 01-12-2014, 09:37 AM   #1228
Robert Conner
Omaha, Nebraska
Thank you very much for posting this. VERY helpful. Sorry if this has been covered but can some one please post a picture or a different link to Adam drakes indoor setup. Everytime I open it, the setup sheet is blank. Tried it on my phone, iPad, and computer and it was still blank. Thanks in advance. Absolutely LOVE this buggy
Losi8ightfanty is offline   Reply With Quote
Old 01-12-2014, 09:59 AM   #1229
dtr
dtr's Avatar
It works for me from the car's page on TLR website.
What pdf reader do you use? Getting the latest version is generally a good idea.
dtr is offline   Reply With Quote
Old 01-12-2014, 10:05 AM   #1230
I use the latest version. I tried the link you posted and still the same. Posting a picture of it would probably work.
Tags
e-buggy, eight 3.0, losi, spur gear
