Old 12-16-2013, 08:23 PM   #1126
bluegroovelosi's Avatar
Default Viper VTX8
Originally Posted by vic0280 View Post
anyone running the viper esc in their 8? if so, how do u like it, pic of it installed? I know its slightly bigger, just wanted to see installed and how do you like performance?
debating between the tekin and viper
Yes, I use the Viper VTX8. It fits fine without any modifications, but after running it for a week or so, I decided to dremel off the front loop of the 8ight's battery tray to slide the ESC back a little bit from the front of the chassis.
I never use the long front to back battery strap, so I'd never need that loop for the velcro strap anyway.
The VTX provides problem-free operation, has never gotten even close to overheating and is super easy to program with the ProGauge or PC V-Link.
I'm currently programming the VTX8's Smart Brake System completely different than the suggested setup from the factory, which should produce a much more pronounced and smooth 'off trigger' two stage braking profile.
I'll be testing three different profiles this upcoming weekend along with the new VF8 21 motor.
Robert Conner
Omaha, Nebraska
Team Losi 22 / 22-4
Fusion Batteries / Orion Chargers
Viper VTX10R ESC's & Viper VST motors
Spektrum DX3R Control / S6040 Servos / SR3001 Receivers
AKA 2WD and 4WD Tires
bluegroovelosi is offline   Reply With Quote
Old 12-16-2013, 08:30 PM   #1127
Originally Posted by aaron_buran View Post
Hi all,
I bought some Spec Point Concepts 4S shorty packs, they are great. ~420 grams, 4500mAh, 70C.
Great for racing your 3.0E Indoor's.
Check em out on their website if your interested.
I bought 2 of the three remaining packs and will try them out this weekend. As I'm learning to drive the 8ight, I don't spend nearly as much time 'practicing' as I did a couple months ago.
If I can a) get 12 minutes out of the 4500's; b) save six ounces of weight c) change the setup to accommodate the lower weight, it sounds like a great combination.
Robert Conner
Omaha, Nebraska
Team Losi 22 / 22-4
Old 12-16-2013, 09:07 PM   #1128
vr6cj's Avatar
Trader Rating: 124 (100%+)
Robert Conner
Omaha, Nebraska
Check that esc wire in the front so its not rubbing on the steering rack post. Looks like its touching there.
vr6cj is offline   Reply With Quote
Old 12-16-2013, 10:39 PM   #1129
i should have taken pics when it was still new, but oh well here she is..
akshayp14 is offline   Reply With Quote
Old 12-17-2013, 03:13 AM   #1130
a few more
Old 12-18-2013, 10:07 PM   #1131
vr6cj's Avatar
Are there any other bodys that are made for this 3.0 other then the stock body?
Old 12-18-2013, 10:09 PM   #1132
JasonR/C's Avatar
jconcepts has the silencer body out
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 12-18-2013, 10:14 PM   #1133
vr6cj's Avatar
Thought that is only for the nitro version. Isnt it to wide? I also saw the bittydesign and Sweep but they too are nitro versions
Anyone try the Proline Bulldog 2.0 ebuggy body? Does it fit?
Edit: Found the Jconcpts body, thanks...... Part # - 0245
Old 12-19-2013, 07:06 AM   #1134
TimMo846's Avatar
2.0 bodies won't fit either, just same the as the nitro they are to wide.
Mugen MBX7R -MBX7TR
-JCP RC Raceway-Dialed Hobbies-Rex Engines-Novarossi-Bones Brew-#TRUGLIFE
#IndianaRcDesigns
Indiana RC Racing -> www.facebook.com/groups/318194191597049/
TimMo846 is offline   Reply With Quote
Old 12-19-2013, 11:14 AM   #1135
Originally Posted by 1badgoat View Post
Any chance we might see blank 16mm machined pistons in the future?
That is a good idea. I will add that to my list of components I am making for Impact Performance Products. That would be an easy one. I may put dots on the piston for easy layout. Maybe 10 of them.
Ben Burtle is offline   Reply With Quote
Old 12-19-2013, 11:42 AM   #1136
Casper's Avatar
Trader Rating: 33 (100%+)
2.0 bodies fit they just don't hug the chassis tight. You do not need to modify them to run them though. If you want a body that fits snug to the chassis then you would need a 3.0 specific body as meationed more then a few times this car is much more narrow then the 2.0.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-20-2013, 12:58 PM   #1137
JasonR/C's Avatar
With very few options if any available body wise I'd still say the stock is the best choice. It does what its meant to do airflow wise.
Old 12-20-2013, 02:43 PM   #1138
TimMo846's Avatar
If you velcro the sides of the 2.0's bodies they will fit, but I think it's about a inch gap on each side of the chassis.
Mugen MBX7R -MBX7TR
#IndianaRcDesigns
Old 12-22-2013, 06:09 AM   #1139
Kaw1000's Avatar
Going with a metal spur as mine was wasted yesterday. Should I set the mesh the same way as a nylon spur? Does it need to be lubed?
Kaw1000 is offline   Reply With Quote
Old 12-22-2013, 07:36 AM   #1140
You should be able to set it a little looser with the metal gear.
dynamiteracer is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
