Old 10-16-2013, 01:20 PM   #826
I've been using both Adam Drake's set ups for both indoor and outdoor. For outdoor I do like the shock setup(8 hole pistons with 37.5 and 30). For indoor I tried the 5 holes pistons and 35wt oil and I'm not sure I like it. I did not like the way the buggy landed, it seems to slap the ground and bounce on flat landings.
Can someone please explain to me why Adam went with 5 hole pistons for indoor and 8 hole pistons for outdoor.
slow is offline   Reply With Quote
Old 10-16-2013, 01:26 PM   #827
typically, indoor races are shorter and thus you can run thinner oil and it will remain consistent and also, most indoor tracks are smoother and thus the 5 hole pistons should have more speed.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 10-16-2013, 01:49 PM   #828
Thanks, that makes sense. What are some ways to get the car to stick flat landings better? I build my shocks with zero rebound. Most indoor tracks have shorter distances between take off and landing ramps that I tend to over jump and land on the flat section.
Old 10-16-2013, 01:49 PM   #829
BSC-- no i used TLR oils and are you talking about the front pin hinge adjuster inserts?
offroadjack is offline   Reply With Quote
Old 10-16-2013, 03:27 PM   #830
maddog9's Avatar
Trader Rating: 29 (100%+)
Yes he is talking about kickup inserts. Run 0s up front for indoors. This is the only adjustment we made for indoors.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 10-20-2013, 08:57 AM   #831
Originally Posted by BSCFlash View Post
Make sure you do NOT use the shock oil that came with the kit--it is very unreliable, and could greatly influence your setup for the worse. Use TLR shock oil.
As an FYI, we tried that setup, and took Casper and Ryan's advice and came back to the kit setup with 0s in the front--MUCH better. We look forward to your feedback on that setup, though.
well i ran that setup at the track friday and it was perfect had one of the racers up there give me a few pointers. i did move the front camber arm to the inside bottom hole. and 26mm ride hight and it was on rails he drives a mugen gas buggy and he loved mine so much he going to get one lol
Old 10-20-2013, 07:08 PM   #832
I run 50% rebound in the from and 25% in the back. Granted I'm on the 2.0 but I love how my handled. Good running with ya too.
http://www.fiercercsolutions.com/ Parts Kits & more
TEKNO---Serpent---Hobbywing---Speed Passion
slimgravy is offline   Reply With Quote
Old 10-20-2013, 08:16 PM   #833
Did you use 26mm all around? What about the rear link, still in the middle?
old carpet rcr is offline   Reply With Quote
Old 10-21-2013, 05:34 AM   #834
JasonR/C's Avatar
26fr 28Rr is what I use for inside. 27/29 outside
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 10-21-2013, 05:43 AM   #835
Thanks Jason, hopefully I'll get to make it out in November. Are you still using stock set up? I set mine up per basic setup except 0's in the front. I noticed the basic setup sheet and the manual have different front shock tower mounting suggestions. What is everyone going by?
Old 10-21-2013, 10:12 AM   #836
JasonR/C's Avatar
My setup is different. Pm me tonight and ill tell you what I'm doing. Dont have my car in front of me right now
Old 10-21-2013, 11:13 AM   #837
Ok, will do.
Old 10-21-2013, 01:07 PM   #838
Questions??
BUMP, still looking for verification on my first question. I'm really *not interested in buying multiple servo saver arms to test with....many thanks.
Potential products I've identified already:
http://www.amainhobbies.com/product_...ervo-Saver-Arm
http://www.amainhobbies.com/product_...um-8B-8T-10-20
Originally Posted by RC-Rick View Post
Woohoo! Just expanded my TLR arsenal with a new 8ight-E 3.0! Going over the setup sheets and forums and looking for verification on product compatibility:
Which aluminum servo saver arm fits the E3?
Has the differential parts for the E3 changed? - More research indicates it has not.
Will the Aluminum Rear hubs and CV axles fit as well?
Looking forward to the build but going to take my time (it's so hard not to jump right in haha) as I'm already waiting on some hopups to arrive. Maybe I'll just start with the shocks. And who has the rear green springs in stock lol. My goto shops are out, not even eBay!
| TLR SCTE 2.0 | TLR 8ight-E 3.0 | Associated TC5R |
RC-Rick is offline   Reply With Quote
Old 10-21-2013, 01:17 PM   #839
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
You need arm #2 or #3. #1 was for the first batch of 2.0's but they went back to the old style.
All the old diff parts fit. They changed the cut on the internal gears to make them smoother but the old ones still work if that's all u got.
Aluminum rear hubs and the axles fit. Also get the aluminum diff cross pins if u are going for lightweight. I heard they don't wear.
pimpedaccord is offline   Reply With Quote
Old 10-21-2013, 01:17 PM   #840
The regular one for the 8ight 2.0, the last link you put.
-Ryan Dunford
Tags
e-buggy, eight 3.0, losi, spur gear
