Old 10-14-2013, 09:37 PM   #811
Trader Rating: 42 (100%+)
Hey guys I am with RCGOD on this one I just picked up a 8ight 2.0 and want to update it so what do I need as far as part #'s so I can get this thing up to speed... thanks in advance...
Team Radiopost-SMC Racing-R1wurks-Savox-AKA
XB2ce
BIGTRUX is offline   Reply With Quote
Old 10-15-2013, 08:58 AM   #812
We posted stuff earlier in this thread but it is cheaper to get a new kit than to convert.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 10-15-2013, 09:18 AM   #813
sunco1's Avatar
Trader Rating: 27 (100%+)
Got to give mine a go this past Sunday at my local track. Coming the the 2.0 electric car I was pretty excited to see how this car handled.
For the most part I started with the Drake outdoor setup (shocks and linkage positions), but I left the stock 2.7 sway bar in the front and 5-5-5 for the diffs. The car handled pretty well with this setup but I ended up changing the front sway bar to a 2.5. I'm not ready for finer tuning yet because the camber link ends are still SUPER tight. After cleaning the car, the ends seem to be even tighter. I am gonna take them apart and maybe hit them with a bit of fine sandpaper.
I managed to get some video too. New car on a new layout! Enjoy
http://youtu.be/JK7WyhZjmDU
TJ Eller
Team Associated - Reedy - Jconcepts - Stickit1
sunco1 is offline   Reply With Quote
Old 10-15-2013, 09:27 AM   #814
rcgod's Avatar
Thanks.
Dialed RC Hobbies
rcgod is offline   Reply With Quote
Old 10-15-2013, 10:16 AM   #815
Casper's Avatar
Trader Rating: 33 (100%+)
Don't sand them. Use a pair of pliers and squeeze them. This is the fastest easiest way.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 10-15-2013, 04:19 PM   #816
sunco1's Avatar
I've tried. Worked alright on some of them but not all. I ended up switching ends from my nitro car since it's retired for the season and the ebuggy isnt
TJ Eller
Old 10-15-2013, 06:21 PM   #817
Hacker07 or Casper,
What brand tapered pistons would be a good fit in the 3.0e? Im looking for something close to Phends national winning setup. What would be the piston hole size? Thanks...
Whitey_Wangster is offline   Reply With Quote
Old 10-15-2013, 07:56 PM   #818
Hacker it will seriously cost over $700 to bring my 2.0 up to the 3.0 standard.. I wonder why non of the "big" names make upgrade kits... I honestly thought losi would set the example on this one but I guess not.. its not about making a better product it is just about selling more cars..
thanks in advance for all you do...
XB2ce
Old 10-16-2013, 07:23 AM   #819
Is anyone running the tekno traktion drive system? I fail to see how you can use electric brakes with a clutch. I'm interested in trying it. I just don't understand how Adam runs it and has brakes. Maybe that is why there is two sets of springs? I am uncertain.
Ben Burtle is offline   Reply With Quote
Old 10-16-2013, 08:32 AM   #820
Well, you essentially need everything except the 3 diffs and that's if you already have good HD lightened outdrives, and the rear hubs, and some minor odds and ends.
The arms, chassis, spindles, carriers, center drive bones, battery system, wheels, shocks, towers, servo mount, side guards, hinge pins...etc...when you add them up separately, they cost similar to the new kit. The new kit isn't 700 and you can sometimes find it for a bit of a deal online or by talking to your local shop.
-Ryan Dunford
Old 10-16-2013, 08:34 AM   #821
The traction drive system is an engaged clutch that allows some slip off the bottom end which is adjustable but when braking is locked up giving you motor brakes. He only runs it on outdoor blown out tracks.
-Ryan Dunford
Old 10-16-2013, 08:36 AM   #822
Thanks Ryan. I was thinking that was the reason for the two different style springs.
Old 10-16-2013, 12:28 PM   #823
Just got my Losi 8ight 3.0. took 7 hours to be put together but it was fun
i did put too much thred-loc on the center diff mout now cant get them loose.
Running Tekin 1900 with a RX8
5-5-3 diffs
shocks 37.5 front and 30 rear with adam drake set-up
offroadjack is offline   Reply With Quote
Old 10-16-2013, 01:07 PM   #824
Oops
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 10-16-2013, 01:08 PM   #825
5-5-3 diffs
Make sure you do NOT use the shock oil that came with the kit--it is very unreliable, and could greatly influence your setup for the worse. Use TLR shock oil.
As an FYI, we tried that setup, and took Casper and Ryan's advice and came back to the kit setup with 0s in the front--MUCH better. We look forward to your feedback on that setup, though.
Tags
e-buggy, eight 3.0, losi, spur gear
