Old 10-10-2013, 11:46 AM   #766
84 GT 5.0's Avatar
Trader Rating: 26 (96%+)
if i wanted the 3.0 layout thought i would need the chassis? or i could just bolt on a 2.0 conversion?
JQ THE Car YE teknoV4/xerun150/t81400/savox1256tg
Tamiya TRF-416/s6040/vipervtx10R/ killshot 17.5
kyosho scr-sp/sanwa94770/hobbwing 90a/atomik 13.5
futaba 4pl
84 GT 5.0 is offline   Reply With Quote
Old 10-10-2013, 11:49 AM   #767
Hey Guys,
Long time lurker but I have recently built an 8IGHT E 3.0 and raced it the past few weekends (after being out of the hobby for 10+ years) and its a sweeet ride!
Any thoughts on my suspension? It doesn't really have any rebound when i push the chassis down...it just stays there. I'm thinking I didn't fill up the shocks all the way or I have some air in them?
Regards,
Mike
MikeMAN987 is offline   Reply With Quote
Old 10-10-2013, 12:18 PM   #768
pballer2777's Avatar
Trader Rating: 27 (100%+)
can someone tell me how long of a sensor wire is needed for this car?
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 10-10-2013, 01:19 PM   #769
Originally Posted by Casper View Post
I don't remember I think Ryan may have that data. I understand the clean look but again if going this route lighter is better! If you go with the T8 setup no problem at all. Power for days! The T8i setup give the car a more nimble feel though which is why we are going through the effort
Casper,
Are you running the T8i on a larger track? Or a small track?
I was advised not to run on a larger track with them. I really don't need all the power of the regular units.
Ben Burtle is offline   Reply With Quote
Old 10-10-2013, 01:21 PM   #770
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by 84 GT 5.0 View Post
what would it take to convert a 3.0 nitro car to a 3.0 electric?
chassis
motor mount
center dog bones
am i missing something?
Servo mount. Battery tray, The center diff mounts are different. Front and rear towers are different but you can use the nitro ones. Side guards. Body
I am sure I missed a few details that go with things like the battery try straps, chassis pads different screws ect.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 10-10-2013, 01:27 PM   #771
Casper's Avatar
Originally Posted by MikeMAN987 View Post
Hey Guys,
Regards,
Mike
Check that your sway bars are free and you did not over tighten the upper shock mounts. Also are your shock collars set for proper ride height. Take the shocks off and make sure the arms fall freely and then install the shocks making sure the upper shock cap wiggles on the bushing.
Long! 250mm+ is safe.
Originally Posted by Ben Burtle View Post
Casper,
We primarily run on 10th scale tracks. OCRC is 130X64 (or close to that) so not a "small" track but not 8th scale large as well. We ran it out at palm desert which is an 8th scale size track and although I am not sure I would actually recommend it due to the layout not having any really long straights it worked quite good. Key here is light car. If you run on a large track and don't want all the power you can always go for the T8 Gen2 1700 and have something better for a large track but a little more tame. The T8i is for a light weight more nimble setup. If you are running big batteries on a large track a little extra weight on the car for a bumpy track may not be a bad thing. The T8i was not to take away power but it is a little smoother but weighs less got get a more agile car for tighter indoor tracks.
Old 10-10-2013, 03:43 PM   #772
chassis
motor mount
center dog bones
I just finished making my own conversion to a true E 3.0. The E chassis comes with the battery foam, so dont buy extra. Battery tray comes with the extra foam for shifting the battery around, the radio box set comes with the center diff plate and wire holder, motor mount, chassis brace set, shock pistons for the five hole. The bigger sway bars came in your nitro kit. Shock towers if you didnt already modify the nitro ones. Side guards, body, E rear center drive shaft. Use the rear nitro for the front on the E buggy. Get the dedicated screws for the battery tray and the side guards, also you'll need the metric screws for mounting the motor to the motor mount. I think that should do it.
old carpet rcr is offline   Reply With Quote
Old 10-10-2013, 05:13 PM   #773
Can anyone suggest a sensor cable. It's new to me, never ran sensored before. I plan on running a Tekin setup, if it matters.
Old 10-10-2013, 05:33 PM   #774
aaron_buran's Avatar
Casper and Hacker,
Where are you get the lightweight hardware from?
Also when your running the lighter package what oil and spring are you running?
Horizon Hobby, JR Propo, Spektrum, Parma PSE, Faskolor, Tornado Racing Fuel, Calandra Racing Concepts, Murnan Modified Motors, Kyosho America
aaron_buran is offline   Reply With Quote
Old 10-10-2013, 08:09 PM   #775
Deacon_8T's Avatar
chassis
motor mount
center dog bones
U mean converting from a 8 3.0 over to a true 8 3.0e?
TLR 8 3.0 - TLR 8T 3.0 - TLR 8E 3.0 - TLR 22T 1.5 -
TLR - Spektrum - Alpha - Tekin - Savox - AKA - BCE - JConcepts - Tonys Screws - Dialed Inc - Buku - SMC - St.Louis RC - Red Rock Hobby - Amain Hobbies -
Deacon_8T is offline   Reply With Quote
Old 10-10-2013, 08:28 PM   #776
Casper's Avatar
Originally Posted by aaron_buran View Post
Casper and Hacker,
TLR makes alum nuts.
http://www.tlracing.com/Products/Def...ProdID=TLR6311
You can also use some of the screws from the SCTE titanium hardware kit although not all of them will work.
8ight E-3.0 vs using the 2.0 electric conversion kit to convert an 8ight 3.0.
Old 10-10-2013, 10:41 PM   #777
Trader Rating: 39 (100%+)
Ill have my kit tomorrow my friend Gary picked it up at horizon today and overnighted it to me I'm pumped also picked up a t8i 1900 and a gen2 esc
1000rrstunna is online now   Reply With Quote
Old 10-11-2013, 06:44 AM   #778
chicky03's Avatar
Send a message via AIM to chicky03
Hey Guys,
Regards,
Mike
Check and make sure where your front shock tower mounts isn't broken. It makes the shock angle back and they don't move freely anymore.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 10-11-2013, 08:13 AM   #779
jhautz's Avatar
Trader Rating: 85 (100%+)
Originally Posted by pimpedaccord View Post
I noticed that a while back that either the manual or exploded diagram had the wrong p/n. Can't remember which. The exploded diagram also has some nitro stuff left on it.
Originally Posted by hacker07 View Post
Yeah, that is my bad. The part number on the step in the instructions is wrong...it is however correct in the exploded view.
Thanks for posting this. You guys just saved me a lot of head scratching. My 8e 3.0 kit had a bent dog bone for the front center. I called customer support and they had a replacement out to me in a matter of 2 days, so two thumbs up for customer support!! But the bone they sent me was the 242001 as it was listed in the manual. Its about a half inch shorter than the one that came in the kit. I was going to ask this question on here, but you guys already answered my question!! Just called customer support again and they are getting the right 242002 bone sent out for me now.
Ryan, make sure you get whatever the customer service guys use for reference updated with the correct part number. Even they are confused. LOL.
jhautz is offline   Reply With Quote
Old 10-11-2013, 09:25 AM   #780
Thanks and yeah, we are getting what is online updated already as well.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
