Old 10-05-2013, 10:41 PM   #721
1badgoat's Avatar
Originally Posted by Zspeed36 View Post
I hear 1700 is good for indoors, do you mean a 1900 would be great? because I don't understand 1/8 motor number to power ratios yet could you maybe put that in perspective to 1/10 turns? like a 10.5 in a 2wd buggy compared to a 6.5 in 2wd? Sorry if that sounds stupid.
Go ahead with the 1700. Over the last two years I have been lowering the kv's in both my buggy and truggies. I run both indoors and outdoors on medium to large tracks. 1700 kv motors are plenty, just make sure you get the gearing right.
TLR/Futaba/Hitec/Tekin/Hyperion privateer
1badgoat is offline   Reply With Quote
Old 10-06-2013, 12:27 AM   #722
JasonR/C's Avatar
I run a 1950kv. You can see the new car in my videos. Just look up jason r/c or tlr 8ight-e 3.0 on youtube. Judge your track size to mine for indoor. If your track is smaller I'd go to a 1700kv. Honestly unless its the backstraight I never go above quarter throttle. If you can tame the power go bigger.
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 10-06-2013, 12:38 AM   #723
Your track appears to be slightly bigger then the two I race at, straight is about 100ft. After some reading I did find that one of our local pros also typically uses a 1700kv from tekin. Which also makes me feel a little better. I can't help that I am a typical power hungry American.
what I ended up picking up is a Orion r8 pro and a Mr8 1750. I seriously hope that works out.
are you topping out on that back straight?
Zspeed36 is offline   Reply With Quote
Old 10-06-2013, 08:27 AM   #724
Trader Rating: 38 (100%+)
If the track is smaller a 1700 should be perfect I had a 1900 in my 2.0 last winter and it was almost to much. Woulda bought a 1700 for my new 3.0 but I got the tekin indoor motor which is smoother so I decided to stick with the 1900 since its more "manageable" power.. Either way you'll have fun but in all honesty if your track is small your lap times will prolly be better with the 1700 slow is fast
1000rrstunna is offline   Reply With Quote
Old 10-06-2013, 09:39 AM   #725
Hey Jason, my name is Jack Wolf. I go to leisure hours also, we met earlier in the summer. I just got my 3.0, and was sealing up that novarossi at the track. Well I picked up the 8ight E 3.0 for the indoor track only. I prefer my 8ight 3.0 nitro for outdoor, a lot of fun. I want to get a Tekin power system, I'm leaning toward the T8i models. What do you think? I run a 4s venom pack, 5300 70c. Weighs in at 561g. Do I need to run shorty packs? Does it defeat the purpose of running the T8i with a heavier pack? I'm on the fence, I know some of our fast guys are running the heavier setup with 4s and regular 1900kv. Anyone want to chime in, I can use the help.
old carpet rcr is offline   Reply With Quote
Old 10-06-2013, 10:14 AM   #726
Well then I guess I will stick with the 1700 and see how things go.
any suggestions on gearing? I was guessing a 16t pinion?
Old 10-06-2013, 07:08 PM   #727
The T8i is not made for heavy cars. It is made for lighter cars. Therefore, a heavy pack will likely overwork the T8i and shorten the life or not provide the performance you are looking for. If you want to use big packs, get the big motor T8 Gen 2
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 10-06-2013, 07:39 PM   #728
Ok, thank you for the response. Will this buggy handle better lighter? I was going to set it up per the manual, except 0's in the front. Maybe a change in the rear if it doesn't corner the way I want. Will the manual setup work well with a heavier buggy? The indoor track Jason and I run at, seems like lighter is the way to go. What are good shorty packs? Also, what size kv on the T8i would be best? I really appreciate the help, had an older E buggy last year that I put too much money into trying to get it to do what it wasn't designed to do.
Old 10-06-2013, 09:32 PM   #729
big chris's Avatar
Trader Rating: 50 (100%+)
The Adam Drake outdoor setup is superb! The only change from the setup was I went with 1 degree less anti squat due to the track being rough and bumpy. Incredible the change from running the stock setup I ran on the same track.
I am mad this car came out so late into our season! Now this winter I'll be feigning to run more 1/8th scale!
B6 Carpet
B6 Clay
B6D dirt
SC5M
big chris is offline   Reply With Quote
Old 10-06-2013, 09:52 PM   #730
Krio's Avatar
Trader Rating: 150 (99%+)
Any aftermarket bodies out yet?
www.kriostasis.com
Krio is offline   Reply With Quote
Old 10-07-2013, 05:18 AM   #731
th ank you for the advice, but Im running on indoor clay track, medium sized, high byte. You can see it in Jason R/C videos
Old 10-07-2013, 07:16 AM   #732
ChanMan23's Avatar
Im pretty sure most of these questions have been answered but i just wanna know how this buggy is performance wise overall. Is it better than xray xb9e? Do you have to shim anything or pre-prep something before running the vehicle?
D-alpha / Xray / Vp-Powermaster /
ChanMan23 is offline   Reply With Quote
Old 10-07-2013, 09:10 AM   #733
The reason the light motor exists is to make a light car. The reason for a light car is that indoor tracks tend to be a little smaller and tighter...if yours is that way, the lighter cars will switch directions faster.
-Ryan Dunford
Old 10-07-2013, 10:20 AM   #734
I understand, I will be using the E buggy only indoors. So I want it to be able to perform the best I can make it. What shorty packs and kv T8i do you recommend?
Old 10-07-2013, 10:48 AM   #735
Casper's Avatar
Trader Rating: 33 (100%+)
We are running Venom 3800mah 60C batteries and Tekin T8i 1950KV motor. This combo works great. We are running 10 min mains no problem with this setup as well.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
