Old 10-01-2013, 03:24 PM   #691
sunco1's Avatar
Trader Rating: 27 (100%+)
Almost done with my build. Just gotta do the shocks and wire everythig up. This was a great build! The way the the side gaurds mount to the chassis as well as the battery tray was a great touch. No more stripping plastic The rod ends are pretty tight like everyone says but it will break in.
The only thing I had to adjust were the rear diff shims. Doing it per the manual made the aluminum inserts almost impossible for me to install into the gear box. I went with one .25 shim on the left and one .10 on the right. Went together good after that and felt smooth.
I also didn't realize the esc mounted straight to the chassis. I will mount it on a thin piece of foam for some cushion. I usually just use shoe goo to mount my speedos.
TJ Eller
Team Associated - Reedy - Jconcepts - Stickit1
sunco1 is offline   Reply With Quote
Old 10-01-2013, 04:53 PM   #692
jhautz's Avatar
Trader Rating: 85 (100%+)
what's the right way to loosen up the ball ends on this buggy when it's new?
jhautz is offline   Reply With Quote
Old 10-01-2013, 05:25 PM   #693
sunco1's Avatar
Originally Posted by hacker07 View Post
You squeeze the plastic end with the ball inside of it so that the plastic takes more of the shape of the ball.
TJ Eller
Old 10-02-2013, 06:40 AM   #694
Brian Miskolczi's Avatar
Trader Rating: 154 (100%+)
The car needs to be run for 45 minutes to break in and handle well.
l TLR l OS SPEED l RADIOPOST l PROLINE l NITROTANE l HORIZON HOBBY l HOBBYWING/FALCON SEKIDO l VENOM l UPGRADE RC l SMC BATTERIES l PCDRC GRAFFIX l GMK SUPPLY l OGIO l 4C HOBBY SUPPLY l
Brian Miskolczi is offline   Reply With Quote
Old 10-02-2013, 07:00 AM   #695
jhautz's Avatar
What exactly needs to break in?
Old 10-02-2013, 07:13 AM   #696
maddog9's Avatar
Trader Rating: 29 (100%+)
Pretty much any moving part.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 10-02-2013, 11:16 AM   #697
jhautz's Avatar
Originally Posted by sunco1 View Post
Thanks. Worked like a charm.
So reaming the arm holes for the hinge pins to open and free them up and squeezing the ball end on the links to get everything super smooth and free isnt enough to get this car the handle well without breaking in? Just went thru the car last night and loosened everything up and the suspension and steering and everything is super free and smooth now. I plan on breaking in the diffs on the bench once I finish wiring. Really hope it doesn't take 45 minutes of track time for the car to start driving well. Thats almost 2 race days of track time for me.
Old 10-02-2013, 11:18 AM   #698
It should not take that long to break the car in. If you squeezed the ends, that is the main thing on the front end of this car, the rest is good. Sometimes, the bearings will free up some after a certain amount of runtime due to the grease they are packed with.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 10-02-2013, 11:58 AM   #699
jhautz's Avatar
Thanks Ryan. After going through the car last night I actually found the rear suspension was less free than the front. Before loosening everything up the rear arms wouldn't even move under their own weight. (shocks off) I reamed the arms and squeezed the link ends and it freed up quite a bit, but was still binding a little. What I found was the outer hing pins through the hub uprights were binding. By just loosening the nuts 1/4 turn that totally freed it up and everything was silky smooth. Maybe the bearing surface on the outer hinge pin could be a half mm longer so if you bottom out the nut on the shoulder of the pin it doesn't squeeze the arm and make it bind. No issue with turning the nut out a little. It works and shouldn't come loose.
Old 10-02-2013, 12:31 PM   #700
Yes, the nutted outer hinge pin has to be able to spin by hand. If the nuts are too tight, it will severely bind the suspension. We have since fixed the outer hinge pins so in time, that wont be an issue.
-Ryan Dunford
Old 10-02-2013, 03:32 PM   #701
Trader Rating: 20 (100%+)
Are you guys cutting out any of the vent areas in the body?
Randy
RandyJones is offline   Reply With Quote
Old 10-02-2013, 03:33 PM   #702
I cut the one for the motor and I also use a reamer to put some in the flat behind the motor that is facing the rear of the vehicle.
-Ryan Dunford
Old 10-02-2013, 03:37 PM   #703
Thanks Ryan!! Appreciate quick response!! Tyler is gonna run his for first time this weekend and just got body back from painter and getting mounted.
Randy
Old 10-02-2013, 04:02 PM   #704
Make sure you shoe goo the front nose area and around the body pin area in the back and it should last long with the Velcro on the sides like its made to be.
-Ryan Dunford
Old 10-02-2013, 06:49 PM   #705
i to had a hell of time getting the receminded shems in the rear diff. but finally got it very smooth. ryan any other combo thats easier to install.thanks
ScottZ is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
