Old 09-26-2013, 02:53 PM   #676
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up Yes Kick up
On bumpy track I like the 1's in the front , the car can handle the bump's really well.
Originally Posted by ZeGerman View Post
Thanks for the answers.
Concerning the differentials, I think i will keep the 5-7-2 setup this fits my driving style most. Im running a 4S 6500 mAh Tekin RX8 Gen2 and T8 1900 kv.
I think you would consider this as a heavy setup.
Unfortunately we don`t have any indoor tracks near by so its all about outdoor.
Yes in addition to the pistons recomended in Adam Drake`s standard
outdoor setup i ordered all TLR oils from 40WT to 30WT.
I still don`t have an idea what "splits" pistons are ?
I understand that there are tapered pistons and pistons
which have holes with different diameters but i never heard of "splits".
@XXXDAD: My english skills are limited what exactly is 1`s ?
Im reading it on the setup sheet too ? "1's up and 1's down front pivot"
Are we talking about the Kickup inserts ?
Regards
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 09-26-2013, 07:17 PM   #677
djbclk430's Avatar
Trader Rating: 59 (100%+)
Send a message via AIM to djbclk430
Any suggestions on what weight oil to run with stock pistons, large outdoor track, med bite,some large jumps, outdoor temps between 65-75 range? Thanks for any feedback!
Bruno
djbclk430 is offline   Reply With Quote
Old 09-26-2013, 07:44 PM   #678
big chris's Avatar
Trader Rating: 50 (100%+)
Originally Posted by C.Capelo View Post
I have tried the 5 hole pistons and the nitro shock setup with the 8 hole pistons back to back and find that for the outdoor track I was at the 8 hole shock setup (Adam Drake's setup) worked best. The buggy handled the bumps better and jumped better. There seemed to be a little too much "pack" with the 5 hole pistons on the outdoor track I was at.
I even tried the silver rear spring vs. the green rear springs and definitely the green rear springs suit the ebuggy.
What were the track conditions you tried this setup on? Also what tire did you run so I can compare?
B6 Carpet
B6 Clay
B6D dirt
SC5M
big chris is offline   Reply With Quote
Old 09-26-2013, 10:29 PM   #679
Originally Posted by pimpedaccord View Post
Split = 4 holes are 1.2mm and the other 4 holes are 1.3mm
1's = yes, those are the kickup inserts.
Thanks a lot. I will give feedback asap
ZeGerman is offline   Reply With Quote
Old 09-27-2013, 04:47 PM   #680
Diff Balls's Avatar
Trader Rating: 38 (100%+)
does anyone know if the kyosho shock pistons will work? I have some laying around...
Diff Balls is offline   Reply With Quote
Old 09-27-2013, 06:23 PM   #681
Diff Balls's Avatar
Nevermind, I just measured them. If anyone else cares to know, the mounting hole is slightly smaller so they would have to be drilled out. The diameter of the piston is slightly larger, .03-.05 larger.
Old 09-30-2013, 01:18 AM   #682
Has anybody of you tried a Smart diff in the 3.0 E ?
Old 09-30-2013, 09:46 AM   #683
Casper's Avatar
Trader Rating: 33 (100%+)
We have tried them in the past. They don't work well with electric. It has to do with how the SD engages and how eletric motors are instant power. With a nitro motor and the clutch and everything they work better for nitro. You can try them but the work kind of funky in an electric application.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-30-2013, 10:24 AM   #684
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Any plans to come out with lower degree castor blocks? Like 10 or 12?
pimpedaccord is offline   Reply With Quote
Old 09-30-2013, 11:26 AM   #685
Not to my knowledge at this time.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 09-30-2013, 04:23 PM   #686
Trader Rating: 73 (100%+)
Default Advice
Can anyone tell me what rx8gen 2 settings should be.built the 3.0 stock set up out of the box.only pinion I had is a 14t.
ROCCK RACING
DALTON RC
RCADDICTIONS.COM
jay13111 is offline   Reply With Quote
Old 09-30-2013, 07:40 PM   #687
sunco1's Avatar
Trader Rating: 27 (100%+)
Just starting my build..Just finished the front end and I have one question. I'm building the car with Phends national setup on it and im confused about the pivot inserts. It says "1's up and 1's down front pivot" Does that mean 1's up in the front most hinge pin brace by the bumper, and 1's down on the other end? Or the other way around?
TJ Eller
Team Associated - Reedy - Jconcepts - Stickit1
sunco1 is offline   Reply With Quote
Old 09-30-2013, 10:26 PM   #688
You are correct, 1`s up in the front most insert and 1`s down in the rear facing (inboard) insert. This will give you +2 Kickup.
Old 09-30-2013, 10:42 PM   #689
This depends on your track and your Motor.
I will have to switch to a 16/43 (Gen2 T8 1900kv). Using the 15/43 i got up to 180F on the Motor housing (outside) and the RX8 Gen2 was completely cold. On my local track we have a straight with approx. 57 yds (53 meters).
I hope that i still have enough acceleration in the infield and that i can lower the Motor temperature down to about 160F by switching to the 16t pinion.
Old 10-01-2013, 07:24 AM   #690
Casper's Avatar
180 is still safe. Hot but safe.
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
