Old 09-23-2013, 04:12 PM   #661
Have any of you driven a kyosho to compare it to?
Previous username: Racer591
McGuire is offline   Reply With Quote
Old 09-23-2013, 04:17 PM   #662
Purdue Engineer's Avatar
Purdue Engineer is offline   Reply With Quote
Old 09-25-2013, 09:15 AM   #663
JasonR/C's Avatar
I've driven the kyosho. It is a nice ride however. I don't like fat cars (associated). I like mine skinny
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 09-25-2013, 02:10 PM   #664
Trader Rating: 17 (100%+)
Hey fellas I have a brand new built 8e 3.0 for sale
bkuff-losi is offline   Reply With Quote
Old 09-25-2013, 02:21 PM   #665
will you ship to south africa?
akshayp14 is offline   Reply With Quote
Old 09-26-2013, 03:36 AM   #666
Hello Guys,
yesterday i was able to take my brand new 3.0E for a ride on our local track.
I was amlost as quick as i am with my current car (6 ECO) and i feel that
there is potential and more to come.
I changed the diff setup to 5k-10k-2k and im pretty satisfied with that.
Quite good acceleration with good on- and off-power steering.
I will try 7k in center diff to make it a bit calmer on acceleration.
The problem i have is the suspension. The car tends to become quite nervous
during the rougher track sections even on straits, and it gets a bit "bitchy" or
instable during landing after mid to big jumps.
As i understood the current kit comes more or less with a indoor type of setup regarding pistons and oils.
I took a look on the outdoor standard setup from Adam Drake posted on TLR HP.
He uses 8 hole 1,3 mm in the front and "splits" at the rear.
I ordered these pistons by the way.
#1 Do you guys think the new pistons + the oils will solve my problems mentioned above.
#2 How does a "split" piston look like ? is it with conical holes or different diameter on one piston ?
Thanks for your help
ZeGerman is offline   Reply With Quote
Old 09-26-2013, 04:07 AM   #667
maddog9's Avatar
Trader Rating: 29 (100%+)
Originally Posted by ZeGerman View Post
Hello Guys,
If you have not tried it, i would try the box stock setup with TLR oils not the kit oils as they are a bit off. If your going indoors put 0-0 blocks up front, if your going outdoors stick with what the build says to use. Also, if you are running a heavier car (with a standard 4s lipo os or 2-standard 2s batteries and a normal T8) try 40 shock oil in front and 37.5 oil in the rear as this was suggested by Ryan Dunford to me.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 09-26-2013, 04:14 AM   #668
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up Use the Nitro setup Pistons
Tlr oils and the Nitro Pistons work great also 1' s in the front camber block. I run 555 in my difs
Hello Guys,
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 09-26-2013, 06:04 AM   #669
C.Capelo's Avatar
Trader Rating: 113 (100%+)
I have tried the 5 hole pistons and the nitro shock setup with the 8 hole pistons back to back and find that for the outdoor track I was at the 8 hole shock setup (Adam Drake's setup) worked best. The buggy handled the bumps better and jumped better. There seemed to be a little too much "pack" with the 5 hole pistons on the outdoor track I was at.
I even tried the silver rear spring vs. the green rear springs and definitely the green rear springs suit the ebuggy.
Hello Guys,
C.Capelo is offline   Reply With Quote
Old 09-26-2013, 06:24 AM   #670
Myself and my teammate spent about five hours testing (a total of 10 track hours as we have identical cars). We tried 3,000 rear diff and tons of bar and ride height changes, as well as 0s and 1s inserts in front. Taking Ryans advice, we came back to the exact kit setup (with 5,000 rear), with the ONLY change being 0s in the front for a tighter indoor track. Car was MUCH better than anything we tried. Surely the kit setup is there for a reason. We found that a higher rear ride height provided more grip in the slick so we ended up at 26/28 ride height on a slick track, but started at 26/26 or 27/27 on the high-grip tacky track (still testing ride heights, but great thus far). MAKE SURE TO USE TLR OIL AND NOT KIT OIL--CRITICAL!!!
Just our two cents worth of input after a great deal of testing.
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 09-26-2013, 12:49 PM   #671
Thanks for the answers.
Concerning the differentials, I think i will keep the 5-7-2 setup this fits my driving style most. Im running a 4S 6500 mAh Tekin RX8 Gen2 and T8 1900 kv.
I think you would consider this as a heavy setup.
Unfortunately we don`t have any indoor tracks near by so its all about outdoor.
Yes in addition to the pistons recomended in Adam Drake`s standard
outdoor setup i ordered all TLR oils from 40WT to 30WT.
I still don`t have an idea what "splits" pistons are ?
I understand that there are tapered pistons and pistons
which have holes with different diameters but i never heard of "splits".
@XXXDAD: My english skills are limited what exactly is 1`s ?
Im reading it on the setup sheet too ? "1's up and 1's down front pivot"
Are we talking about the Kickup inserts ?
Regards
Old 09-26-2013, 12:52 PM   #672
Regards
You may want to consider going to a higher rear diff oil. Sometimes with such a light diff oil like 2k in an 8th scale, the rear end can unload in sweeping turns and cause very strange behavior.
Splits simply means that half the holes are one size and the other half are another size. It is a piston we sell.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 09-26-2013, 01:03 PM   #673
Alright thanks to everybody. I will wait until the pistons arrive rebuild with TLR oil and may increase the rear diff back to 5k again.
Old 09-26-2013, 01:08 PM   #674
If you used kit oil, that is certainly a big change right there. rebuild with tlr oils, change the diff oil, maybe to 3 at first and then try 5 as well...
-Ryan Dunford
Old 09-26-2013, 01:08 PM   #675
pimpedaccord's Avatar
Trader Rating: 24 (100%+)
Regards
Split = 4 holes are 1.2mm and the other 4 holes are 1.3mm
1's = yes, those are the kickup inserts.
pimpedaccord is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
