Old 09-21-2013, 11:05 PM   #646
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by sam1950 View Post
Ran my buggy for the first time last night. Compared to my SCTE 2.0, it has a bad push, but did get a little better by the end of the night. I'm running the box setup, but, with 0 inserts in the front of the car. I need, either, to tighten up the front or loosen up the rear. What would you suggest I do to accomplish this?
Two setups to try here.
http://www.casper-rc.com/TLR_Ten-SCTE.htm
The first is a little more aggressive the second has quite a bit more steering but still stable in the rear end.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-22-2013, 05:42 AM   #647
bubbafrc's Avatar
Trader Rating: 14 (100%+)
Default TLR E Buggy
I did not think anything could be better than the 3.0 converted to Electric. We held the Clash at FRC starting on Thursday. My new 3.0 Kit arrived that day, but I did not get a chance to build it. However, JR Mitch and Tylor Weaver were running theirs. Tylor built his on the drive from Atlanta to Flowood. I have had mine a week now and it is an amazing electric buggy. I have been able to run the back to back and the new E Buggy is so much easier to drive than anything I have driven. We club raced yesterday and kid from New Orleans won the Ebuggy class with a 2.0 EBuggy, I let him drive mine after the race. He agreed, it is just so much easier to handle and the only change I made was the rear sway bar. I went to the heavier sway bar and it really helped in cornering on our track. This is a winner for sure and I really appreciate all the help from TLR guys, there is a lot of helpful information out there for anyone from TLR. If you want the best EBuggy out there, get one of these.
bubbafrc is offline   Reply With Quote
Old 09-22-2013, 11:51 AM   #648
I only see setups for the scte 2.0 not the 8ight e 3.0. I must not be looking in the right place
sam1950 is offline   Reply With Quote
Old 09-22-2013, 02:32 PM   #649
XXXDad's Avatar
Trader Rating: 195 (100%+)
Had a good day with my 3.0E started 6th on the Grid in the A and finished 3rd. Good day of racing. At Coral Springs RC
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 09-22-2013, 05:27 PM   #650
Diff Balls's Avatar
Trader Rating: 38 (100%+)
anyone using a steel spur gear? Which one?
Diff Balls is offline   Reply With Quote
Old 09-22-2013, 05:30 PM   #651
Trader Rating: 120 (100%+)
Dakota's setup had the 45t steel spur for the roar nat's he just won.
B6D
B64D
Tekno EB410
JoeC is offline   Reply With Quote
Old 09-22-2013, 10:27 PM   #652
Casper's Avatar
Sorry I got mixed up on the wrong thread. I saw SCTE 2.0 and did not realize I was in the 8ight side.
try going to 0's all around for front kick up. this gives more steering and less rear traction. Start there and there are other things to change like 3K rear diff. Is it pushing into the corner or on power?
give the kick up change a try first and report back.
Old 09-23-2013, 06:28 AM   #653
Diff Balls's Avatar
http://www.amainhobbies.com/product_...-Spur-Gear-45T
This is the only one I can find...will this work?
Its different form the stock...
Old 09-23-2013, 07:37 AM   #654
I already have the 0 inserts in the front. It pushes all the way through the turn. If I tap the brakes, I can get the rear to rotate but that kills my speed. I saw Adam Drake's set up, should I try that?
Old 09-23-2013, 07:53 AM   #655
maddog9's Avatar
Trader Rating: 29 (100%+)
Try 3k in the rear, i ran 553 this past week and the it was pretty rear loose.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 09-23-2013, 09:18 AM   #656
Casper's Avatar
You can. Ryan and I have not tried Adam's setup yet but I know from past experience I tend to like Adam's setups.
3K rear end will give you some more steering. Take the wicker off the wing. Move the wing forward. 2.5 rear toe in. I would look at freeing up the rear end some if you are looking for more all around steering.
Stiffer rear spring could help as well.
Old 09-23-2013, 09:23 AM   #657
Did you build your car with kit oil or with TLR oil? If kit oil, change that out to TLR oil and give it a try...it will be much better.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 09-23-2013, 09:23 AM   #658
JasonR/C's Avatar
I had the same issues with push. I went from 5/7/3 to 5/7/5 to 5/5/3. I'm stayin with 5/7/3. Seems to be the most balanced for me. I did put a stiffer swaybar in the rear. Also using 30/30 for oils. Took out droop in the front and left full droop in the rear car is pretty hooked up now. You can check out my videos on youtube. Just look up jason r/c
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 09-23-2013, 10:45 AM   #659
Switching from Kit oil to TLR oil made a HUGE difference both front and rear, especially the front as it seemed to be more like a 60-80 up there.
Ryan and Casper, why is the kit oil junk? Should we trust the kit diff oil?
TLR 8IGHT-E 4.0 -Tekin RX8 Gen2 / Tekin T8 Gen2 1900
TLR 22 3.0s -Tekin electronics--one for mod and one for stock!
BSCFlash is offline   Reply With Quote
Old 09-23-2013, 11:36 AM   #660
The kit diff oil is good. The shock oils cannot be our normal matched and spec'd oil that we place in the TLR bottles as that process happens here in CA.
-Ryan Dunford
Tags
e-buggy, eight 3.0, losi, spur gear
