Old 09-18-2013, 12:41 PM   #631
Originally Posted by sam1950 View Post
I used the oil & pistons that came in the kit, but my front shocks feel extremely stiff compared to the rear. Any thoughts?
the front are a little stiffer. You may want to rebuild with TLR oil.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 09-18-2013, 12:48 PM   #632
big chris's Avatar
Trader Rating: 50 (100%+)
Thanks for getting those outdoor setup starting points.
I think the 8 hole pistons should absorb some of the rough better and keep the buggy planted.
B6 Carpet
B6 Clay
B6D dirt
SC5M
big chris is offline   Reply With Quote
Old 09-18-2013, 02:03 PM   #633
Hellbound's Avatar
Trader Rating: 37 (100%+)
Does the new e3.0 body shell fit on the e2.0 ?
Really starting to like the new shell
Kyosho MP9e TKI3 - Tekin - Hobbywing - Savox - Futaba
Hellbound is offline   Reply With Quote
Old 09-18-2013, 02:19 PM   #634
Sorry but the new car is much narrower than the old and thus the body will not fit.
-Ryan Dunford
Old 09-18-2013, 09:18 PM   #635
big chris's Avatar
That body is uglier than two dudes! I'm patiently awaiting any companies aftermarket body.
B6 Carpet
B6 Clay
B6D dirt
SC5M
Old 09-18-2013, 09:23 PM   #636
How will the car do “heavy” indoors? Would a 3S compensate for the weight from a T8i and shorty packs? Or too much performance lost with a 1950kv? The spline on Spectrum is the same as JR, correct? Thanks!
Starting my build tonight!
LAGuy is offline   Reply With Quote
Old 09-19-2013, 03:36 PM   #637
ta_man's Avatar
Trader Rating: 151 (100%+)
I've got a Neu 1512 Finned motor which is 44MM in diameter.
Will this fit in the 3.0E or am I limited to 42MM diameter motors like the Castle and Tekin?
If it fits, do I still have the same flexibility in spur/pinion sizes as with the 42MM motors or do I have to use the 45T spur?
ta_man is offline   Reply With Quote
Old 09-19-2013, 04:24 PM   #638
That did the trick. The 37.5 wt. oil from the kit looked more like 60 wt.
sam1950 is offline   Reply With Quote
Old 09-19-2013, 06:51 PM   #639
ryan how do you get the 10 degree kick in the front for indoor racing just started my build .kit looks amazing.
ScottZ is offline   Reply With Quote
Old 09-19-2013, 10:18 PM   #640
There are specific ones coming. I will get Adam to put one together for outdoor as well.
The stock one works great on indoor or on outdoor blue groove type setups.
Thanks Ryan
ZeGerman is offline   Reply With Quote
Old 09-20-2013, 03:45 AM   #641
maddog9's Avatar
Trader Rating: 29 (100%+)
Put 0 inserts(instead of the stock 1) in both blocks for the front end.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 09-20-2013, 12:05 PM   #642
You need to put 0 inserts in the front inner and front outer blocks and those inserts are in the bag of extras.
-Ryan Dunford
Old 09-21-2013, 05:53 AM   #643
thanks guys doing it now
Old 09-21-2013, 02:15 PM   #644
Ran my buggy for the first time last night. Compared to my SCTE 2.0, it has a bad push, but did get a little better by the end of the night. I'm running the box setup, but, with 0 inserts in the front of the car. I need, either, to tighten up the front or loosen up the rear. What would you suggest I do to accomplish this?
Old 09-21-2013, 09:21 PM   #645
maddog9's Avatar
Try 3k in the rear
Tags
e-buggy, eight 3.0, losi, spur gear
