Old 09-09-2013, 08:33 AM   #526
Team Tekin
TY@TEAMTEKIN's Avatar
Originally Posted by pegger View Post
Hi guys just looking for some input as to what pinion you guys recommend with the stock 43t plastic spur gear. i am running a 1900kv on 4s my track is medium with some tight sections low grip. I am using a 15t pinion a the moment and i am getting quite high motor temps.
Cheers
Pegger
I geared mine 14/43, temps seem to be fine on our outdoor track.
Ty Campbell
TEKIN / TLR / SOR GRAPHICS / MIP / PROTEK / KALGARD / AVID
TY@TEAMTEKIN is offline   Reply With Quote
Old 09-09-2013, 09:28 AM   #527
Originally Posted by JoeC View Post
Hey Jason were you running box setup or did you tweak?
If you are running outdoor, you want to go down 5-7.5 wt front and rear with the car. You will also want to play with droop some and of course camber.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 09-09-2013, 11:32 AM   #528
Trader Rating: 120 (100%+)
I run on larger outdoor tracks that tend to get blown out and are a little loose so any and all setup suggestions are welcome.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
JoeC is offline   Reply With Quote
Old 09-09-2013, 11:53 AM   #529
You will likely want to go more towards the adam drake nitro setup or use dakotah's setup from nats then for a track of that nature.
-Ryan Dunford
Old 09-09-2013, 10:25 PM   #530
symmetricon's Avatar
Trader Rating: 27 (100%+)
are the dimensions of the 8ight e 3.0 body similar to the 2.0?
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 09-09-2013, 10:29 PM   #531
Guest
Send a message via Yahoo to kyoshoracer77
Originally Posted by ironzgti35 View Post
Need some new 4s packs...at a somewhat reasonable price, recommendations?
Smc lipos
kyoshoracer77 is offline   Reply With Quote
Old 09-10-2013, 05:39 AM   #532
JasonR/C's Avatar
Smc lipos if they had the 4s in stock. They don't. I use the trinity titanium 4s gray packs. They are $99 on stormerhobbies I believe
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 09-10-2013, 05:39 AM   #533
ironzgti35's Avatar
Trader Rating: 20 (100%+)
Originally Posted by kyoshoracer77 View Post
Smc lipos
I run SMC 2s packs currently. Looking at their 4s packs however, I don't need the big 6500, the 5100 is only 40c (looking for a little more c rating), and the new shorty pack coming out would be perfect if not $90. I'm looking for 4000 to 5000mah tops
ironzgti35 is offline   Reply With Quote
Old 09-10-2013, 08:33 AM   #534
The dimensions are completely different. Its much narrower and a bit taller to allow more clearance for the battery.
-Ryan Dunford
Old 09-10-2013, 08:34 AM   #535
Also, if you like your nitro 3.0, you should consider trying that setup adjusted for the weight difference on your E 3.0 on your particular track.
-Ryan Dunford
Old 09-10-2013, 10:04 AM   #536
Hey Guys,
Also a new owner of a shiny new TLR 8IGHT-E 3.0 this past weekend, unfortunately I was shorted an outdrive in the kit (but an extra outdrive with the set screw) so hopefully can finish the build this weekend. Definitely a sweet bit of kit!
Regards,
Mike
MikeMAN987 is offline   Reply With Quote
Old 09-10-2013, 10:28 AM   #537
much appreciated.
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 09-10-2013, 11:03 AM   #538
When you say adjust for weight difference I assume you are talking about shock setup?
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
Old 09-10-2013, 11:56 AM   #539
Yes...and I don't mention anything specific as some run the lighter electronics setup like Casper and myself with the T8i and 2 shorty packs and some run a heavier setup with the T8 gen2 and a full sized pack.
-Ryan Dunford
Old 09-10-2013, 12:07 PM   #540
I have a rx8 gen2 and the 1900 T8i coming and am not set on having to run a brick pack so I am open to running shorties. What do you see different in the handling characteristics running the shorty packs compared to the 4s brick pack and also is there a ideal place to place them in the tray. I will be running on high bite indoor clay here in the next month and a half so your setups should be close. Thanks again for the info.
22-4
MBX7R Eco, RC8B3E
MBX7R. RC8B3
Tags
e-buggy, eight 3.0, losi, spur gear
