Old 08-30-2013, 07:24 PM   #406
1badgoat's Avatar
10 and half hour marathon. Assembled, setup, wired, esc calibrated and radio trimmed. The only thing left to do is paint the body. Somebody is going racing tomorrow!
TLR/Futaba/Hitec/Tekin/Hyperion privateer
1badgoat is offline   Reply With Quote
Old 08-30-2013, 07:36 PM   #407
sleek's Avatar
Jasonr/c I found that also, this car seems to be very tight, hopfully it breaks in nice.....front done center half way......some spots in the instructions seemed a little vague in my opinion
Boca Bearings
Royal Rc hobbies of Peru Il. (815) 223-3744
reminder to self....it's all about having FUN !!
sleek is offline   Reply With Quote
Old 08-30-2013, 07:51 PM   #408
I have not bought this kit... yet. So I do not have the pleasure of knowing first hand just how 'tight' this car is.
But I am the only person who drops bearing oil on all joints? I put a single drop of bearing lube on every single hinge, joint, ball end, etc. If it moves, I put a drop of bearing oil on it. The ONLY exception to this rule is the shock shaft and the steering rack on the 22.
I know... it would seem that the oil would simply attract massive amounts of dirt and oil, but this hasn't been the case. In fact, I have never experienced any of this rumored slop that Losi cars seem to develop. With the exception of my 22's steering, all my rides have about the same slop as they did when they were first built!
BTW, I blow off my cars with compressed air (except wheel bearings) after every run and re-apply a drop of oil to all joints every other run. And to specifically illustrate just how little oil I'm using, I bought a 2oz bottle of Team Epic bearing oil in February and it is still over half full.
JK47 is offline   Reply With Quote
Old 08-30-2013, 07:55 PM   #409
1badgoat's Avatar
Old 08-30-2013, 08:01 PM   #410
XXXDad's Avatar
Trader Rating: 195 (100%+)
Exclamation WOW
Congradulation's, your build came out Awsome! Now... RX8-Blue, must be paint or did you dye it? Nice Blue Hardwhere looking good. I see some Yellow Paint... will it be all yellow? Again nice going! Are you going to Space Coast to run?
Originally Posted by 1badgoat View Post
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 08-30-2013, 08:24 PM   #411
1badgoat's Avatar
I'm going to just spray a temporary body yellow till I get one done bye my painter. The colored case came about by accident. I tried dying it, but it did not work. I painted it with a spray enamel till I get a black case in at my lhs. When are they racing at space coast, I've never been there.
Old 08-30-2013, 08:59 PM   #412
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by JasonR/C View Post
So far only issue I've found and actually was wondering if anyone had a fixable solution, the turnbuckles are snug at each end causing binding. Arm inner hinge pins also. I don't have a reamer for the arms. I know it will slop alittle.
Drive it... It will loosen up! You can put the pin's in a dremel and reem it that way. But I say," Drive it!"
+1. Run it a few times and they should loosen up.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 08-30-2013, 09:13 PM   #413
XXXDad's Avatar
Tomorow at space coast 1 year doubble header.
Old 08-30-2013, 09:44 PM   #414
1badgoat
Which Tekin motor are you running?
sam1950 is offline   Reply With Quote
Old 08-31-2013, 01:10 AM   #415
JasonR/C's Avatar
Default Build Pictures
First off im gonna say this. well done TLR this is a nice kit! as always of course...
my wiring will get done tomorrow.
my only complaint is those battery straps. man... they have got to go lol
kit is tight thats for sure. even using bearing oil its still tight. so we shall see after a few batteries.
heres some photos. Had to paint one color, my painter is getting married this weekend so he wont have time before next weeks big race.
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 08-31-2013, 01:15 AM   #416
JasonR/C's Avatar
Default e 3.0
for some reason my pictures wont upload... hate it when it does that. anyways heres the box and the finished product ill try and repost the chassis stuff later.
TLR 8IGHT E 3.0 THREAD-20130830_161352.jpg   TLR 8IGHT E 3.0 THREAD-20130831_022853.jpg
Old 08-31-2013, 03:15 AM   #417
1badgoat's Avatar
Originally Posted by sam1950 View Post
1badgoat
1900 gen 2. I ordered a 1600 T8i, just waiting for the lhs to get it.
Old 08-31-2013, 03:23 AM   #418
1badgoat's Avatar
My kit was a little tighter than usual, I used a reamer in the hinge pins and the diff gears. It should be great after a battery or two. I did have to file the edges of the chassis where the front hinge pin braces are, but only a little.
Old 08-31-2013, 10:26 AM   #419
Originally Posted by Integra View Post
So the Servo Tray is the same as the 2.0 SCTE, Does that mean the RX box might work on the 2.0 SC as well ?
We can check it out next week Nick. my 3.0 E should be here Wednesday.
polarismaster is offline   Reply With Quote
Old 08-31-2013, 02:05 PM   #420
Suspended
has anyone run theres yet. I wanna buy one so bad but I wanna know how it runs. please make a video or give feedback.
funkymunky1212 is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
