TLR 8IGHT E 3.0 THREAD
#4126
can one of you guys that has been running this buggy say what body gives a little more room underneath?
The RTR body mine came with is hitting my Lipo wires.
#4127
I sanded all the areas hitting and was able to use the stock body with the battery mod.
#4128
My shock came apart again and cost me the 1st race, bummer. Then after that I was flying. I was able to place 4th in the B main, my best ever. I was 1 lap off the leader. These cars are still very good, especially with the battery mod.
#4129
How can I protect the front tower? Has anyone made something that helps, or are there some plastic protectors out there? I hate seeing the grinding on the tower and wear on the shock hardware.
#4130
I took out one corner of the battery box( forward, right) and slid it forward. Some of the original holes lined up. I drilled the rest and bought the tap required(5-40) from Ebay. The battery tray is 3/8" from the steering post. I put the battery all the way back. It jumps very good.
#4131
Can someone tell me if the newer version 3.0 & 4.0 wing-mounts will fit the older 8ight-e 2.0 version chassis and shock mount without modification (?)
#4132
Raced my car yesterday and it was so awesome. Indoor clay track. I was one second off the bump, bummer! My car is still set up for outdoors, so I need to go over it and set up for indoor. I did break a part in the 3rd race. Nice thing about the 3.0, everyone has parts! This is easily the best r/c car I have ever owned. I am using a 206 charger and it charges at 16 amps in a few minutes. The other guys run slicks so I guess I need to get them.
#4133
I removed the fwd r/h screw and sanded that area down to fit the tray forward. I was able to line up on a few holes, and drilled/tapped the rest. I had to order the tap from eBay. I put the battery all the way back in the tray, really nice balance.
#4134
hello people I looked & I'm getting tried of reading can someone tell me where to find the set ups for my 8ight T 3.0 E mostly looking for shock oils & diff numbers thanks
#4135
Did any of you who moved the battery tray forward try the optional front brass weight first? If so is there a benefit of the mod over the weight?
#4136
losi 8ight 3.0 electric conversion body search
did the 3.0 to electric conversion does anybody know for sure what body will fit i think that losa8097 will but would like to know for sure already wasted my money on jconcepts sillencer any help would be great thanks
#4137
Yes, the old electric body fits perfectly, I had been running that way for two years. Loved the looks of it, Sadly there's nothing similar for the 4.0.
#4138
thank you very much will it fit with 4s lipo 6700 mah
#4139
it is smc 67131-4s2p
#4140
that battery is just under 2 inches tall
