Old 10-24-2016, 05:11 PM   #4051
platgof's Avatar
I did the camber links movement that someone suggested, and it really helped a lot. I also had a shock end come off(rear of course,) so I super glued it with the black super glue, nasty stuff, and also adjusted the droop as also recommended to stop the shock ends from coming loose. It all worked, and I finished the race in one piece. Plus the car handled great. I was having a nightmare with the esc coming loose, rough track, but finally fixed it. When I got home, I shoegooed them in place, problem solved. At the end of the race I was getting faster and could really tell it. I have never drove this car to it's full potential, a shame really. The Tekin RX8 G2 and T8 1900 are a beast together.
DESC10 Tekin RX8 G2
Losi 8 E 3.0 Tekin RX8 G3 w/ T8 1900
DESC210R Tekin RS G2
Sanwa M12S
If your not spitten clay,you ain't racing either
platgof is offline   Reply With Quote
Old 10-25-2016, 02:44 PM   #4052
platgof's Avatar
I forgot to add that I was told to go with the smallest sway bars up front and the largest in the rear. I don't know why, but it works.
DESC10 Tekin RX8 G2
Sanwa M12S
Old 10-25-2016, 07:23 PM   #4053
KOULLIT's Avatar
Default Why you should not use the Long Ackerman Plate ?
Hi,
I lost many time to find why I can't place the steering servo on my prototype, and why I have always bad results :
The answer is : there is a problem why the Losi 8ight Long Ackerman Plate.
I let you some 2d draws, then every designer can try this.
This is a first draw with the servo saver parts, and the 69mm ( long ) ackerman plate.
The 21mm dimension is the LOSA4406, so we want to test with, for example, 30 in clockwise , and too, in anti clockwise, to compare.
This is the draw you can copy for testing :
So, I can test now with 30 clockwise, to turn at the left :
The same thing, but anti clokwise, to turn at the right :
You have seen different results, and it's normal.
If you want the same result with the wheels when you turn at the right or at the left, you will need to "travel" 30 and 24,347.
These are two draws with an optional LOSA4406, on the left servo saver side, here you can see the differences :
So, if you use the long Ackerman plate, your wheels will not turn at the same angle on each side.
With the long Ackerman plate, the Losi turns better in the left turns compare to right turns !
A big error from Losi, like the problem with the short ackerman plate, because you need a dremel to use it in a reliable way for you steering servo !
Of course, the problem is exactly the same with Agama, Serpent, JQ, RB, Durango... all the systems with different measures between the Akcerman plate holes, and the servo saver posts.
Bye !
(Excuse me for my poor English)
The French designer
SYLVERIS RC - Option Racing Parts
LOSI 8IGHT-E 3.0 - Tekin RX8 GEN2 - Tekin T8 - Futaba 3GR 2.4Ghz
1/8 Off-Road Electric - Belt drive conversion : http://www.rctech.net/forum/electric-off-road/665377-1-8-offroad-electric-belt-drive-conversion-6.html
The French forum : RCMAG.COM
KOULLIT is offline   Reply With Quote
Old 10-26-2016, 05:16 AM   #4054
TRF415boy's Avatar
Hi Koullit,
You are correct in the fact that if your servo provides the same angle to your steering bellcrank left and right, your wheels will not turn the same.
However as long as you set the end points on your radio correctly, this will not be the case.
I'd like to point out that on your design the position of the servo is also altering the curves of your steering so if your servo provides the same throw left and right, the resulting angle to the steering bellcrank will not be equal left and right.
Originally Posted by KOULLIT View Post
Hi,
Bye !
The French designer
TRF415boy is offline   Reply With Quote
Old 10-26-2016, 09:17 AM   #4055
KOULLIT's Avatar
Hello TRF415boy,
You think EPA is a solution, it's your opinion, this will not change the difference between right and left before to reach this end point. And it's impossible to set up exponential on each servo side.
So, even from the knowed designers, it's not an answer, or not a right one.
you said : "I'd like to point out that on your design the position of the servo is also altering the curves of your steering so if your servo provides the same throw left and right, the resulting angle to the steering bellcrank will not be equal left and right."
You are all false, it appears you didn't create simulation !
In my way to place the steering servo, results are excactly the same on each side, there is not any altered curve.
Bye !
Old 10-26-2016, 04:05 PM   #4056
Just bought my first 1/8th Losi Electric car to start racing I used to race 1/8th Nitro.
Now i'm joining back to racing and bought a used Losi 8 3.0 really good condition.
On the list for shopping ( hope this is a good setup )
Tekin RX8 Motor & ESC combo 2050kv Going to be running 4s4000's.
Looking at either the Spektrum DX6r OR the futaba 4PX.
dashpuppy is offline   Reply With Quote
Old 10-27-2016, 06:40 PM   #4057
platgof's Avatar
Get the Tekin 1900 motor, it is plenty! DX6R has a bad rap right now.
DESC10 Tekin RX8 G2
Sanwa M12S
Old 11-04-2016, 06:08 AM   #4058
Anybody have any suggestions as to what body I can run on my Losi 8ight converted to E 3.0? I bought an eight-e 3.0 body and it is way too narrow. And the stock nitro body that came with my car hits my 6500mah batteries
cloead is offline   Reply With Quote
Old 11-06-2016, 05:33 PM   #4059
I am wondering the same thing. Nitro losi 3.0 converted and i need to find a body thats going to fit
Leo moreno is offline   Reply With Quote
Old 11-08-2016, 07:47 AM   #4060
I ordered a JConcepts Illuzion Finnisher Clear Body: TLR 8ight 2.0
Hopefully it works out
Old 11-09-2016, 05:11 PM   #4061
I have a LOSI 3.0 Nitro I converted to an electric I can't seem to find a body the has enough room for my batteries.
sunnyE is offline   Reply With Quote
Old 11-09-2016, 05:13 PM   #4062
I have a LOSI 3.0 Nitro I converted to an electric I can't seem to find a body the has enough room for my batteries. anyone have any thoughts or have had this problem.
Old 11-10-2016, 01:54 AM   #4063
dtr
dtr's Avatar
LOSA8097, or an FTW Exabyte if you can find one.
dtr is offline   Reply With Quote
Old 11-10-2016, 04:47 AM   #4064
waffleNchicken's Avatar
The post directly above yours answers your question.... The 2.0 body fits converted 3.0
waffleNchicken is offline   Reply With Quote
Old 11-10-2016, 01:53 PM   #4065
Welp same as my old body, 4500mah fits, 6500 does not
Is that for a 3.0 nitro?
Tags
e-buggy, eight 3.0, losi, spur gear
