Old 07-18-2016, 09:27 PM   #3976
platgof's Avatar
Anyone else having problems with the plastic shock ends pulling out? It happened twice to me. Is there a stronger part that I can order?
DESC10 Tekin RX8 G2 & T8I 2700
Losi 8 E 3.0 Tekin RX8 G3 & T8 1900
DESC210R & Tekin RS G2
Sanwa M12S
If your not spitten clay,you ain't racing either
platgof is offline   Reply With Quote
Old 07-18-2016, 09:29 PM   #3977
Originally Posted by ta_man View Post
Well, if you've build that many with no problems, one would begin to suspect a bad case.
I see no reason 5K Mugen oil would be too thin - I run 2K in my truggy rear diff and it is the same diff case.
I meant I've changed that many diffs not kits to be clear lol
But I used that blue gasket stuff and that fixed the problem so thanks again to you guys who suggested it!
Slashn77 is offline   Reply With Quote
Old 07-18-2016, 11:17 PM   #3978
Originally Posted by superjoe5000 View Post
Sick of destroying the stock wing. Maybe this will hold up better. I know, it's heavier, I don't care.
I used a kyosho wing once and lasted almost an entire season. Had to dremel off a bit to make it fit and it worked well
sponsored by : Stashko Speed Shop
Everingham Electronics Emporium
Webster RC Parts Warehouse
Anderson Zap Ties
- overkill is a good thing -
buster8787 is offline   Reply With Quote
Old 07-19-2016, 03:38 AM   #3979
damang999's Avatar
Trader Rating: 15 (100%+)
Yep sure have..i have pulled 2 on my e buggy and half a dozen on my nitro. .others i know have had issues aswell.even on the lightest of crashes.droop set correctly and shock ends installed correctly. .i have given up and CA glued mine on ..probably not ideal but they haven't come off again. I thought i had read somewhere that mugen ends work better?
damang999 is offline   Reply With Quote
Old 07-19-2016, 03:19 PM   #3980
dtr
dtr's Avatar
Try to find TLR5435 aluminum shock ends
dtr is offline   Reply With Quote
Old 07-19-2016, 04:13 PM   #3981
Originally Posted by dtr View Post
$20 plus shipping is a rip off I would look around im sure u can find them cheaper. My LHS had them for $13.99
Old 07-19-2016, 07:38 PM   #3982
platgof's Avatar
amain discontinued those, super glue sounds good!
Sanwa M12S
Old 07-20-2016, 07:58 AM   #3983
My LHS is 13.99 also
LTR450 is offline   Reply With Quote
Old 07-22-2016, 06:08 PM   #3984
platgof's Avatar
The front screws on the bottom kept coming loose on both my DESC10 and Losi 8 E. So I got some 4 x 16 mm screws from AMain, part # PTK-H-2306. Needless to say it is not going to easily come loose again. The original screws are 1/2 long, and these are 5/8 inch long. They snugged up nicely.
Sanwa M12S
Old 08-02-2016, 01:20 PM   #3985
CrawJac's Avatar
Hey gang, I just picked up a 8ight E 3.0 and wanted to know what type or maintenance do you do and when?
I am new to RC and this ride, so any and all help is appreciated.
Edit: I race on an outdoor clay track
CrawJac is offline   Reply With Quote
Old 08-02-2016, 08:27 PM   #3986
platgof's Avatar
Use Loctite on everything. I am getting all new electronics for mine, and will finally be running 4s. I was running 3s but it got too warm, it was very fast though. Can't wait to try 4s.
Sanwa M12S
Old 08-06-2016, 07:59 PM   #3987
platgof's Avatar
Starting my battery mod. What a pain it is trying to find a 5-40 tap! I had to order it off ebay to get one. I drove all over town trying to find one, forget that.
Sanwa M12S
Old 08-07-2016, 08:54 PM   #3988
platgof's Avatar
I finished the battery mod. I modified one of the screws into a tap with a Dremel cutting wheel. I was able to use the last four screw holes to mount it. I had to drill three holes, and used one existing hole. It is very sturdy and I am not afraid of the battery coming loose at all. I thought it would be harder, but everything went smoothly. I was able to use the existing center outboard hole. My RX8 Gen2 esc will be here this week and I should be able to finish it. I am using a T8 1900 motor and need help with the proper pinion for it. I put a 16 on it for now, but just guessing. I am using the 45 tooth steel spur gear.
Sanwa M12S
Old 08-08-2016, 10:55 AM   #3989
slick78's Avatar
platgof I have same setup in mine and go back and forth between a 15 and 16 pinion depending on our current track layout
slick78 is offline   Reply With Quote
Old 08-08-2016, 01:12 PM   #3990
I did the battery mod. after breaking a bunch of battery trays, I gave up and put it back. I put 30 grams beside the esc and push the battery forward as far as it will go. Not quite the same but close.
I just drilled and tapped a bigger hole.
Anderson Zap Ties
Tags
e-buggy, eight 3.0, losi, spur gear
