Old 05-02-2016, 11:11 PM   #3931
Tcrox's Avatar
this one?
http://www.hobbyking.com/hobbyking/s...arehouse_.html
it claims to be the same length as my 5600mah, 164mm.
Thank you for the measurements!
I am trying to get past the 20-30C discharge, it's heating up my motor like a mother f'er. I'm guessing i get to spend more money to get the 60-120C that fits.
Mugen MBX7R Eco - Tekin 1900 - Tekin RX8 Gen2 ESC
Losi 8ight 3.0 E - Mountain Basher
R.I.P. Losi 8ight 1.0/2.0 E - Spare Parts for Mountain Basher
Go Pack Go!
Tcrox is offline   Reply With Quote
Old 05-02-2016, 11:11 PM   #3932
Originally Posted by Tommygun1 View Post
As near as I can tell (my calipers only go to 153mm) the dimensions for the 3.0 E buggy tray are 155mm length, 52.8mm width. I know what you mean about those batteries. They fit good in my converted TLR truggy though. The 5000mah Turnigy will fit and works pretty well in the 3.0 ebuggy.
Yes all the same issues here. I too am running the Turnigy 5000mah in my 3.0. My 2.0 is using a longer Turnigy 5000mah in a hard case.
I'm really considering getting a saddle pack setup for the 3.0 but again $$$.
BoostCreep is offline   Reply With Quote
Old 05-08-2016, 10:29 AM   #3933
I know this has been asked, but I don't recall seeing a definitive answer.
I just picked up the 8ight 3.0 kit from amain, along with the e-kit.
Sadly the body doesn't fit.
What are my options at this point? I thought of just saying screw it and buying either a nitro engine and just building it up as a nitro buggy, or, buying the appropriate e-chassis and whatever e-specific parts I need to make that work.
Any advice, and or recommendations on what to do? I bought the 3.0 trying to save some money but I kinda wish I would've just bought the e-4.0 instead.
Oh well.
Thanks in advance.
B.Miracle is offline   Reply With Quote
Old 05-08-2016, 11:17 AM   #3934
superjoe5000's Avatar
Uh Whut?
superjoe5000 is offline   Reply With Quote
Old 05-08-2016, 11:39 AM   #3935
Heh, sorry. Lost my train of thought as I typed that out.
I meant to ask which bodies fit the 8ight 3.0 with the electronic conversion.
The nitro body hits the solder tabs for the motor, sits right on top of the esc, and my batteries hold it about 1/2" too high.
I thought I read that an e-2.0 body would fit, but it wasn't confirmed.
Then I started rambling about other options, such as just going nitro with it or purchasing the appropriate e-3.0 parts so that the e-3.0 body that I purchased will fit.
Make sense this time?
Old 05-08-2016, 02:40 PM   #3936
I ended up saying screw it.
Scoured the exploded diagrams of both the 8ight 3.0 and 8ight E 3.0.
Ordered the parts that looked like what I'd need to basically convert my 8 to an 8-E.
Will report back with a few pics of how it works out. I initially bought the 8 3.0 to save some money vs the new 4.0.
I spent, 300 on the kit and 80 on the E-conv. I spent another 80 on the parts I think I need to finish the conversion.
So I figure I'm 460 into it. Not bad, still saved money I guess.
Old 05-08-2016, 02:56 PM   #3937
dtr
dtr's Avatar
I am running a converted 3.0 with the e 2.0 body, fits perfectly. No body clips, just velcro around the side.
dtr is offline   Reply With Quote
Old 05-08-2016, 06:05 PM   #3938
A couple months ago I bought a 3.0e roller for $200. Is the 4.0e that big of an unproven and if so what are the biggest benefits of the 4.0 over the 3.0.
In a vacuuming if I were to race my clone with the same exact setup same driving skill level etc. would the 4.0e win in a vacuum?
They reason I'm asking is because I came from a AE 8.2e and this 3.0 is much better IMO where If it was possible to race my clone again in a vacuum lol I have no doubt my 3.0e would beat my 8.2e with same setup electronics and everything.
Or should I just keep racing my 3.0e for a couple more years or until the 5.0e(or whatever they'll call it) comes out then buy that brand new.
P.S- besides doing the battery forward mod... What aftermarket items should I get? Are there better shocks? Is it worth it to get carbon fiber shock towers, a certain kind of wing etc. I have money to spend but don't feel like wasting it either..
Any advice is appreciated
Slashn77 is offline   Reply With Quote
Old 05-08-2016, 06:35 PM   #3939
Trader Rating: 15 (100%+)
Did TLR ever make aluminum rear hubs for this car? Part number?
Tommygun1 is offline   Reply With Quote
Old 05-08-2016, 09:41 PM   #3940
I don't think there is much difference at all performance-wise, comparing a 3.0 with battery mod and a 4.0 Personally, I think the 4.0 is a waste of money. Many racers aren't running the boots because they bind and my spindles bound real bad so I used the 3.0 ones. I should have just got the 4.0 chassis, body and center diff plates really. Not really knocking the 4.0, just think the 3.0 was good, REAL good!
Old 05-08-2016, 11:14 PM   #3941
Ok thank u I am going to wait a couple years for the 5.0.
Old 05-09-2016, 12:29 PM   #3942
ta_man's Avatar
Trader Rating: 151 (100%+)
Yes they did (I have some). I don't know the part number.
King Heads also makes aluminum rear hubs (I have these too) and they have the larger diameter (8X16) outer bearing.
ta_man is offline   Reply With Quote
Old 05-09-2016, 12:55 PM   #3943
Question for you guys, What are you running for tires on an outdoor track? Our track is a little dusty during the day and will start to get a more wet one as the night goes on. Sometimes they even wet the track down.
Bh1989 is offline   Reply With Quote
Old 05-09-2016, 01:08 PM   #3944
maddog9's Avatar
Trader Rating: 29 (100%+)
best thing would be to look at what the guys who are winning are running.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 05-10-2016, 04:56 AM   #3945
At my medium grip dusty dirt I run the aka Impacts. When they water it the impacts have awesome grip but when it gets dried up from the sun I am thinking about getting the other aka's with bigger spikes for more grip when the dirt dries I between watering
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
