Old 04-01-2016, 01:42 PM   #3766
superjoe5000's Avatar
Ordered this one up. Having it built
Lazy SOB I am, yep. Built enough of the damn things and I'm just plain lazy these days.
superjoe5000 is offline   Reply With Quote
Old 04-01-2016, 03:37 PM   #3767
platgof's Avatar
Wow! You did it right! That would tear through sand easily.
DESC10 Tekin RX8 w/ T8 1900
Losi 8 E 3.0 Tekin RX8 w/ T8 1900
DESC210R Tekin RS G2
If your not spitten clay,
you ain't racing either
platgof is offline   Reply With Quote
Old 04-01-2016, 05:04 PM   #3768
Dude building it said to go with a Castle 2650kv. I thought 2650 would be too much for it?
Old 04-01-2016, 09:08 PM   #3769
I have a Tekin 2050 in mine. Way more power than needed, but I race I do not bash
Bh1989 is offline   Reply With Quote
Old 04-02-2016, 03:09 AM   #3770
I think the tekin 1900 on 4s is beyond perfect..
rotor head33 is offline   Reply With Quote
Old 04-02-2016, 07:56 AM   #3771
Am I correct, the higher the Kv, the more powerful the motor?
Old 04-02-2016, 10:09 AM   #3772
rc_noob3's Avatar
Anyone got one of these for sale ??
rc_noob3 is offline   Reply With Quote
Old 04-02-2016, 11:02 AM   #3773
Razorbelly's Avatar
Originally Posted by Kaputttroniker View Post
Thank you so much for the "TLR Tuning Tips" link. Itīs so much help, but I donīt understand the diffeence between on-power steering and off-power steering. At which part of the turn does it occure? When you enter the turn, in the middle or at the exit? Lets say you have a narrow U-Turn kind of curve. Can you compare it to over- or understeering when you are pushing the throttle or not? Does it apply to the front or to the rear part of the car, or the car in general?
Another question I was wondering about: Letīs say you just built your kit with the exact same setup as in the manual. You go out on the track for the first time and you find, that the set-up of your car is not the way you like it. What do you change first? What has the biggest effect? Iīd probably go with ride height, or springs, camber, droop... too many options.
__________________________________________________ _______
Just run it for 6 weekend races and break it in and then see...
Razorbelly is offline   Reply With Quote
Old 04-02-2016, 11:06 AM   #3774
Razorbelly's Avatar
Originally Posted by Tcrox View Post
Got my first ever kit, the 3.0 E! Got through the last 50 pages of this thread, and it sounds like everyone enjoys (And will never go back from) the "battery forward" mod.
The cost drop of the 3.0 kit was impossible to pass up! Time to read the other 200+ pages.
I ordered a 46T pinion gear (LOSA3551) but once it was installed it was flush against the chassis and the housing, way too big! I'll see how the stock gear holds up through testing. I hope to find the part number in this thread somewhere for a metal 45T or 46T that fits.
Thanks for all the helpful info!
Yeah that medal spur is for the truggy, order the 45T for buggy .Losa3552
Old 04-02-2016, 11:11 AM   #3775
Razorbelly's Avatar
The higher KV,the higher top end it will have and lower torque motor it will be.
*1900KV = Pinion gears 15T or 16T
* 2100KV = Pinion gears 13T or 14T on safe starting points
So, no... the higher kv the less power. Because it have less torque. If that's what u mean about more power.
Old 04-02-2016, 12:33 PM   #3776
Ok, so higher KV = less torque, more top end.
Lower KV = more torque, less top end.
Now Ima go out on a limb here, so bear with me. I'm not a racer. Am I really gonna notice a difference between 2200 and 2650?
The dude that's building it (yeah I'm that lazy ) suggested to go with Castle MM2 2650 over a Tekin 2 2200 setup as the CC is waterproof and Ima be bashin, not racing.
Not driving through lakes either, just maybe out in the light rain, as all it does in Massachusetts is f*****g rain every other day. It's worse than Seattle.
Old 04-02-2016, 07:07 PM   #3777
platgof's Avatar
If your bashing and want to do back flips, go for the higher KV!
Old 04-02-2016, 07:09 PM   #3778
I never understood people who buy a race specific and designed buggy to bash with...
Old 04-02-2016, 07:24 PM   #3779
for bashing,you cant go wrong with the MM2650....More than enough torque and FAST. Mega fun motor in the 8.
NickTheGreek is offline   Reply With Quote
Old 04-02-2016, 08:59 PM   #3780
Default lipo options
Hey guys, just picked up a TLR 8Eight 3.0 Roller looking for lipo options for racing what are you guys running?
amjaone is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
