Old 03-16-2016, 09:44 PM   #3691
Default 4.0 conversion
Guys I have done the basic conversion, well I would say the reason I did the conversion was for the battery location option and motor orientation option. I have a race meet this weekend and will share my findings on the change. I can confirm you will need the battery tray, which is the same as the 3.0 truggy. The chassis, motor mounts which comes in a set (0 and 4,4 deg) and the body. Everything else is a nice to have. The only other parts I will recommend is the front spindles and carriers, next on my list. There is no need for a new motor mount, if you study the exploded diagram the only difference between the 3.0 and 4.0 motor mounts is the alum. bit that gets attached to the motor, mine (3.0) went on just fine.
The other parts I have done to date prior to the 4.0 change above is the bearing spacer (sleeve) that goes inside the fr and rr diffs. Other than that its as simple as the above, no other parts needed unless you want to go the full 4.0 route I suggest buy the 4.0 kit rather. See attached completed pic.
rcdreamer is offline   Reply With Quote
Old 03-17-2016, 03:20 PM   #3692
platgof's Avatar
Lol!! I bought the 3.0 to save money over the 4.0! I plan to use the saved money for battery and motor, if I go to a 4s system for outdoors.
DESC10 Tekin RX8 w/ T8 1900
Losi 8 E 3.0 Tekin RX8 w/ T8 1900
DESC210R Tekin RS G2
If your not spitten clay,
you ain't racing either
platgof is offline   Reply With Quote
Old 03-17-2016, 05:27 PM   #3693
Now time to figure out how to make the stock body fit over my batteries until my tlf and concepts bodies get in!!
Yay for invisible wires! Gotta love wire sleeves.
rotor head33 is offline   Reply With Quote
Old 03-17-2016, 06:47 PM   #3694
Trader Rating: 15 (100%+)
Very nice. I think that's a good way to go, I would have done the same but needed the parts from my 3.0 to upgrade my truggy to a 3.0. imo your not missing a think not having 4.0 spindles and carriers...mine binded up bad so I used my 3.0 spindles. I'm sure they could have been massaged but my 3.0 ones were already perfect.
Looks clean man.
Tommygun1 is offline   Reply With Quote
Old 03-17-2016, 07:07 PM   #3695
maddog9's Avatar
Trader Rating: 29 (100%+)
Looks good. I cut the little down box completely out and put a sticker over it. I would recommend the tlr cab forward body
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 03-17-2016, 07:24 PM   #3696
Originally Posted by Tommygun1 View Post
Looks clean man.
thanks bro.
that's what im going to do so that I can at least run until my new bodies come in. I contemplated the tlr cab forward but got a great deal on the jconcepts silencer and the lfr assassin body (which was specifically designed for batt forward). ill cut them both out, see which fits better and keep the other for backup. hell I may like the stocker with a sticker! lol
Old 03-18-2016, 03:50 AM   #3697
maddog9's Avatar
thanks bro.
I have not tested the lfr body so i do not know anything about that. I have tested the jcon and tlr cab forward back to back. I had more steering and faster laps with the TLR cab forward body. Both bodies did have more steering and faster laps over the stock body. Hope that helps!
Old 03-18-2016, 11:42 AM   #3698
Haven't really considered Losi for a 1/8 buggy, but now that they are on sale I am considering it. I don't know a lot about the Losi's. Is there any thing I need to know about the kit before I buy? Issues, tips, upgrades etc?
Any input would be appreciated
Horby32 is offline   Reply With Quote
Old 03-18-2016, 05:06 PM   #3699
No issues, all the upgrades needed supposedly are a metal servo saver top and metal spur gear. Other than that it's one of the easiest builds around.
Old 03-18-2016, 05:55 PM   #3700
pballer2777's Avatar
Trader Rating: 27 (100%+)
picked up a set of rear dog bones. what do you guys think of them? whats the advantage?
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 03-18-2016, 06:02 PM   #3701
Used for real rough tracks
pmd
pat dillon is offline   Reply With Quote
Old 03-18-2016, 06:16 PM   #3702
fast-ho-cars's Avatar
i see TLR has front and center diffs called smart diffs, are those for E and N versions? anyone used them on E's?
fast-ho-cars is offline   Reply With Quote
Old 03-18-2016, 06:25 PM   #3703
platgof's Avatar
I used tooth paste on the cups to work them down, and it worked, but took a lot of time. I had to cut the head off a long 2 mm screw and run flanged nuts on it to hold the ball. I then put the screw in a drill and ran it for a couple of minutes. After that I cleaned out the tooth paste and added lithium grease. Now they are very smooth and move freely. I finished my diffs and don't really know how to install the rear plastic inserts for the hinge pin, is it 0* in the front, or the other ? And how are they oriented??? I had to stop there for now.
Old 03-18-2016, 06:31 PM   #3704
maddog9's Avatar
Meant for nitro. Do not use them period.
Old 03-18-2016, 06:34 PM   #3705
maddog9's Avatar
Antisquat do 1 pills up for 3 degree on the 8e 3.0 and 0 pills for toe to give 3 degrees toe.
Tags
e-buggy, eight 3.0, losi, spur gear
