Old 03-14-2016, 08:01 PM   #3676
Originally Posted by pballer2777 View Post
anyone running the battery forward mod only using 2 screws in the battery tray? seems pretty solid. i dont have a tap to make new holes.
I just drilled the holes and tapped it with a stock bolt and some wd40. Worked like a champ.
rotor head33 is offline   Reply With Quote
Old 03-14-2016, 08:11 PM   #3677
pballer2777's Avatar
Trader Rating: 27 (100%+)
what size drill bit did u use?
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 03-14-2016, 08:17 PM   #3678
platgof's Avatar
The work has begun. I am taking my time with this to hopefully avoid problems.
DESC10 Tekin RX8 G2 & T8I 2700
Losi 8 E 3.0 Tekin RX8 G3 & T8 1900
DESC210R & Tekin RS G2
Sanwa M12S
If your not spitten clay,you ain't racing either
platgof is offline   Reply With Quote
Old 03-14-2016, 09:16 PM   #3679
Originally Posted by Casper View Post
Did you take the sun gears out and check the outdrives and pins.
It is pretty odd to have a failure like this and not see anything broken and have it go back together and work for a short period again. With the power we put through these things, stuff usually either works or its broken.
Yes, disassembled all the way down to taking out the rubber o-rings.
It's kind of why we are scratching our heads here. It doesn't seem like there is anything in the box that could 'come loose' unless it plain broke.
pdxrealtor is offline   Reply With Quote
Old 03-14-2016, 11:45 PM   #3680
What's a good diff oil setup for bashing around in the grass and loose dirt and bark dust?
45 tooth Spur/17t pinion on 4s batteries and a Hobbywing 2250 motor / SCT Pro esc.
Right now we have the 5,5,5 setup from the kit. When I switched to the 17t pinion I can pull wheelies but there's a method to it. That's fine.
What I want is better hookup, but not so much that I will pull wheelies if I pin it from any speed. I want to keep that front end planted.... and, a bit of addition to the on power steering would be nice too!
Old 03-15-2016, 12:43 AM   #3681
With that much power only way keeping front wheels on the ground add brick to front of car.
pmd
pat dillon is offline   Reply With Quote
Old 03-15-2016, 01:11 AM   #3682
It's really not that bad right now, and was impossible on the 15t pinion.
I read thicker center diff fluid keeps the front wheels planted, but then others said thicker fluid gives the ability for instant wheelies.
Old 03-15-2016, 04:55 AM   #3683
damang999's Avatar
Trader Rating: 15 (100%+)
I have done probably 12 race meets like this and never a problem..its probably not ideal but it works.
damang999 is offline   Reply With Quote
Old 03-15-2016, 12:21 PM   #3684
I'll look when I get home and let you know.
Old 03-15-2016, 03:48 PM   #3685
#39 drill
pmd
Old 03-15-2016, 07:51 PM   #3686
platgof's Avatar
Built the front diffs and they are butter. I have never seen diffs this smooth, very impressed.I am almost through kit B, no hurry. There is a race in two weeks that would be nice to run this in. 8th buggy is huge there, at least two mains.
Sanwa M12S
Old 03-16-2016, 09:05 AM   #3687
It took me 7 hours, taking my time and using the included tools in the kit so you should be able to blow through it.
Old 03-16-2016, 10:05 AM   #3688
Hinch45's Avatar
Default Converting a 3.0 to 4.0
Has anyone successfully converted a 3.0 to a 4.0? My 3.0 is in good condition and I would rather buy the updated parts piece by piece over time then spent over $500 on a new kit. I already coverted the shocks. Besides the chassis and the motor mounts what else is involved? Thanks
Hinch45 is offline   Reply With Quote
Old 03-16-2016, 10:13 AM   #3689
maddog9's Avatar
Trader Rating: 29 (100%+)
0 and 4.4 degree center plates, new body, new battery tray, new casters and spindles, new hubs, new towers, new stub axles with boots, new adjustable rear hinge pins, over 360-400 plus to update the car. Might as well sell the 3.0 and get a new fresh kit.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 03-16-2016, 07:17 PM   #3690
I personally would just do the chassis and motor/center diff parts. That's the main thing I would like to have.
Tags
e-buggy, eight 3.0, losi, spur gear
