Old 03-12-2016, 10:57 AM   #3646
how is everyone shimming their rear diff? I did 2 .1s on the ring side and 2 x .25 and a .1 on the opposite side. the mesh is buttery smooth but with all 6 shims I ABSOLUTELY couldn't get the diff back in its case. I haven't run the buggy yet so want to ask and see what everyone else is running.
rotor head33 is offline   Reply With Quote
Old 03-12-2016, 09:49 PM   #3647
maddog9's Avatar
Trader Rating: 29 (100%+)
http://youtu.be/jtrdY_gOTkQ
Anyone on the fence about the 4.0 watch my amain run i started on the pole. I will post my setup monday as well as our excellent 8e 3.0 setup!
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 03-13-2016, 01:16 AM   #3648
Default Pinion options for Losi 8ight 3.0-E
I have a Novak SS17.5..which has a .125" or 1/8" shaft. I want to use this motor for my Losi 8ight 3.0-E kit...I just want to know what my pinion options are since I cant seem to find a pinion for a mod 1 pitch which is what the LOSA3560 spur uses.
Any help would be appreciated.
Thanks,
Ryan
reickmey is offline   Reply With Quote
Old 03-13-2016, 03:01 AM   #3649
Seems like a 5mm to 3.17mm bore reducer is my only option..thoughts?
Old 03-13-2016, 03:19 AM   #3650
damang999's Avatar
Trader Rating: 15 (100%+)
Is it new ? 6 shims seems like alot... Mine only took 1 shim when built from new and added 1 more after it was broken in ..
I like to have mine set so it feels a little nothchy when new and find they settle in nicely
damang999 is offline   Reply With Quote
Old 03-13-2016, 03:43 AM   #3651
brand new. just got it from amain on Tuesday. its not notchy at all. its smooth as glass.
Old 03-13-2016, 03:49 AM   #3652
please post up the 3.0 setup!!!
on a side note, is there anything wrong with running 5k in all 3 diffs as per the manual? I noticed the shock oil isn't really different than the maifield and drake setups but the diff oil is a little light compared to the 10/7/3 that I see the pros running. iv only seen one setup sheet with 5/7/3 and figured that was the closest to my 5/5/5 setup...
Old 03-13-2016, 03:56 AM   #3653
damang999's Avatar
As long as its not loose to start with it will be fine . It should have a little bit of backlash ...
I started with 5/5/5 and adjusted from there to end up at 5 5 1 but it all depends on what the driver wants out of it
Old 03-13-2016, 05:25 AM   #3654
ok cool cool. thank you sir
Old 03-13-2016, 07:29 AM   #3655
That motor is too small. It's made for 1/10th scales. It will be slow and you will probably burn it up within a couple packs. You need something like this http://www.amainhobbies.com/rc-cars-...tt2357/p263925
or this http://www.smc-racing.net/index.php?...y&path=112_125
Tommygun1 is offline   Reply With Quote
Old 03-13-2016, 09:42 AM   #3656
maddog9's Avatar
Here is the setup. Battery tray put up front. Tlr cab forward body. This is Performance 8ight Racing setup, i drove the car after my race and had exactly the same lap times!
Old 03-13-2016, 10:07 AM   #3657
awesome! thanks! so the only real difference between my setup is the center and rear diff fluid, pinion and rear camber arms are in A. not bad not bad. I may consider this after I run mine and see which I like better.
Old 03-13-2016, 10:39 AM   #3658
maddog9's Avatar
Check out the springs (black up front and green rear) and shock locations (inside on the arms) too as well as droop.
Old 03-13-2016, 11:19 AM   #3659
shock positions I had already however springs you are right. I have green rears but silver up front. ill order some blacks. as far as droop im waiting on my hudy setup station so ill measure that then.
Old 03-13-2016, 12:26 PM   #3660
platgof's Avatar
Maddog9 thanks for the setup. My friend ate the side of a battery with the battery forward. Is there a safe, secure, way to mount it?
DESC10 Tekin RX8 G2 & T8I 2700
Losi 8 E 3.0 Tekin RX8 G3 & T8 1900
DESC210R & Tekin RS G2
Sanwa M12S
If your not spitten clay,you ain't racing either
platgof is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
