Old 01-30-2016, 12:43 PM   #3571
I have made a thread for the new car:
Official TLR 8IGHT-E 4.0 Kit Thread!
Sworkz
T-PRO
Sanwa
Nosram
mwrccars.at
Magnus F is online now   Reply With Quote
Old 01-30-2016, 04:31 PM   #3572
Default Losi 8ight 3.0 e buggy help
Hi everyone .. I'am a complete noob here with some questions. I just bought the Losi 8ight 3.0 buggy kit and need to know all tools needed to build this buggy ? And the best motor, esc and servo that you guys suggest. So far I am thinking to get a Tekin 2200kv motor and a rx8 gen 2 esc, not sure on the servo yet. Plus what tires do you guys recommend for your typical outdoor dirt track ? And battery you use to race ?
Thanks in advance.
Jordan.
Jgreen2323 is offline   Reply With Quote
Old 01-31-2016, 10:30 PM   #3573
Hey guys, looking to get more on power steering mid corner to exit, running 10,10,3 diff oils with stock setup apart from moving the rear outer camber link in by one hole as per all the setup sheets suggest. What else can I do?. Move battery forward?, go down on the sway bar in the front from stock to 2,3 as per setup sheets as well?.
rcdreamer is offline   Reply With Quote
Old 02-01-2016, 08:19 PM   #3574
anyone??
Old 02-02-2016, 09:08 AM   #3575
maddog9's Avatar
Trader Rating: 29 (100%+)
anyone??
Have you tried 5-7-3 for the diffs? or 5-10-3?
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 02-02-2016, 10:18 AM   #3576
anyone??
Try taking some anti squat out of the rear. Mine turns like crazy with 2* of anti squat
TLR SCTE 2.0 - Tekin RX8, Pro4 4600, Hitec 7940TH
TLR 22-4 - Tekin RSX, Tekin 5.5, Hitec 7940TH
TLR 8ight E 3.0 - Tekin RX8, Tekin 1900kv, Hitec 7954SH
Spektrum DX4R Pro
87MagnumII is offline   Reply With Quote
Old 02-02-2016, 08:44 PM   #3577
That would take some steering away no doubt as there will be less weight transfer?. Thats my understanding of anti-squat, the more A/S the more weight transfer to the front and vice versa for less A/S. Either way I'll give a try, cant hurt.
["Have you tried 5-7-3 for the diffs? or 5-10-3?"] << I will give the 7,10,3 a go, Most are running what I have been too (10,10,3).
Old 02-03-2016, 03:37 AM   #3578
maddog9's Avatar
I tried 7-10-3 before and it made my car push for indoors. I switched to 5-7-3 and solved my issues. I also ran the battery upfront.
Old 02-03-2016, 04:23 PM   #3579
try 10/7/3, new setup and i love it!
akshayp14 is offline   Reply With Quote
Old 02-03-2016, 07:57 PM   #3580
Hey Ashkay, I think 7k in the centre works well with low KV motors, mines ballooning down the staright with 10K. Will give it a try nevertheless and see if I can catch you next time out. Thanks for the awesome race btw!.
Old 02-08-2016, 03:17 PM   #3581
Hi guys.... with the stock 43 tooth spur gear, what is a range of pinion gears I could try?
Running the Castle Sidewinder 8 combo kit. 2200 motor, 4s packs.
Will be bashing mostly, but may hit the local tracks for fun. I searched this post for answers, and found a few, but a lot of the pinion recommendations are for the 45 tooth spur gear, and ours came with the 43 tooth spur.
Thanks.
pdxrealtor is offline   Reply With Quote
Old 02-08-2016, 06:26 PM   #3582
maddog9's Avatar
Thanks.
14/43 or 15/45
Old 02-08-2016, 06:26 PM   #3583
Originally Posted by maddog9 View Post
14/43 or 15/45
Thanks. Is there a range so I can tune it in how I like? So, say, a 13, 14, and 15 ?
Old 02-08-2016, 06:41 PM   #3584
maddog9's Avatar
The 13 won't mesh tight enough. I would stick with 14-15.
Old 02-08-2016, 06:42 PM   #3585
Would moving up to the 45 tooth spur give me more options?
Tags
e-buggy, eight 3.0, losi, spur gear
