Old 01-19-2016, 03:04 PM   #3556
fifi's Avatar
I lost one piece of the suspension tool. Anyone has a part number ?
fifi is offline   Reply With Quote
Old 01-19-2016, 04:23 PM   #3557
shakespear's Avatar
Is the 3.0 kit the newest ebuggy? Is there a new one around the corner?
https://www.youtube.com/user/achancesw
shakespear is offline   Reply With Quote
Old 01-19-2016, 08:18 PM   #3558
I believe there is no turnbuckle binding issues on thr 4.0. Does anyone know what has changed, I havent checked out the part numbers to see if they are the same as the 3.0. Maybe one way to solve this issue on the 3.0?
rcdreamer is offline   Reply With Quote
Old 01-20-2016, 05:24 AM   #3559
pballer2777's Avatar
Trader Rating: 27 (100%+)
i've just built a 4.0 nitro buggy and the turnbuckles are good. no binding
tlr 8 4.0 /rex engine/aka
tlr 8e 3.0/tekin/aka
pballer2777 is offline   Reply With Quote
Old 01-20-2016, 08:04 PM   #3560
Just finished assembling the rear clip, when I shimmed the diff and screwed the case together it felt great, after I got the clip installed it got really tight and even to where I couldn't rotate the outdrive by hand in one spot, loosened up some of the case screws and it got better, question is- is this normal or do I need to open it up and re-shim it? I shimmed per manual instructions
rjkotzur is offline   Reply With Quote
Old 01-20-2016, 10:45 PM   #3561
There is sometimes a high spot in the ring gear and it will even out when u run it- in your case if u can't even turn the outdrive in one spot I would personally re-shim it- it should be just a hair notchy when shimmed right but still smooth and you'll be able to rotate the outdrive by hand- bottom line- every gear and gearbox always don't have the exact same tolerances in my experience, so manuals aren't always "spot on" but close- make sure u lube the ring gear also - I personally use eureka gear grease, kyosho ring gear grease and Casper extreme grease- hope this helps
Rich D is offline   Reply With Quote
Old 01-22-2016, 10:30 AM   #3562
Brian C.'s Avatar
Anything about a 4.0 e car? With the price drop Id think, so just wanted to know if anybody new more.
T&L BOYZ
Trains and Lanes Racing
Team Kyosho
Brian C. is offline   Reply With Quote
Old 01-26-2016, 04:35 AM   #3563
TraumaChaser's Avatar
I haven't heard or seen anything specific to the 4.0e just the nitro :-(
TLR 8IGHT E 3.0, 2WD SLASH
AXIAL WRAITH, AXIAL SCX10, TAMIYA CC-01
DJI PHANTOM PRO 3
TraumaChaser is offline   Reply With Quote
Old 01-27-2016, 01:26 AM   #3564
Exclamation
http://www.tlracing.com/Products/Def...rodId=TLR04004
TRiN is offline   Reply With Quote
Old 01-27-2016, 04:07 AM   #3565
yeah its out, had a look at and will admit I'm not jumping out of my seat. Will convert my current 3.0 on the various revised parts for durability. Wont worry with the chassis and drivetrain from the 4.0
Old 01-27-2016, 05:47 AM   #3566
waffleNchicken's Avatar
I feel the same way right now....maybe it'll change after driving one, but from here, it doesn't look like $600 worth of improvements to me. I think I'll just update parts on 3.0 as well.
waffleNchicken is offline   Reply With Quote
Old 01-27-2016, 06:16 AM   #3567
DeathWish9's Avatar
I'm interested in the Losi 8ight-E RTR buggy. Would that be considered the 3.0 ? Although I'm hoping they make the 8ight-T truggy in RTR form.
DeathWish9 is offline   Reply With Quote
Old 01-27-2016, 08:58 AM   #3568
Good that 4.0e finaly is here
I was waiting while new car comes out as it was decided to swich from jq to tlr for upcoming season.
could somebody tell when battery forward position is better and when esc forward setup is better?
hardijs is offline   Reply With Quote
Old 01-27-2016, 09:25 AM   #3569
Souk's Avatar
Trader Rating: 22 (100%+)
Far as I know it is the 3.0 version just some parts are on the cheaper side. And there is no rtr electric truggy version. The truggy only comes in a gas version rtr.
Souk is offline   Reply With Quote
Old 01-30-2016, 12:37 PM   #3570
ta_man's Avatar
Trader Rating: 151 (100%+)
This is very interesting but if they were going to offer the option of reduced angle on the front driveshaft it makes no sense that that they didn't move the diff closer to the battery to get some of that angle reduction instead of moving the rear part of the center diff away from the battery.
ta_man is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
