Old 08-17-2015, 08:10 AM   #3436
Thanks for the reply Maddog. I kinda figured he was lying to me about the rear shock tower. He has a nitro 3.0. I'll bet the farm its on his nitro kit.
I'll look into those x rings as well. Thanks for taking the time to post those links.
Planning to make an amain order. What rear pistons should I look to buy to have some tuning options? Seems like no one runs the stock rear pistions. What does a split piston mean? Sorry for the newb questions.
Thanks again.
Pincrawler is offline   Reply With Quote
Old 08-17-2015, 09:17 AM   #3437
maddog9's Avatar
Trader Rating: 29 (100%+)
Thanks again.
Front
http://www.amain.com/rc-cars/team-lo...243011/p251270
Rear
http://www.amain.com/rc-cars/team-lo...243012/p251271
Splits which go in the rear are 8 hole pistons 4 of which are 1.2mm diameter holes and 4 of which are 1.3 mm diameter holes.
And no problem glad i can help!
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 08-17-2015, 05:50 PM   #3438
stock springs with those pistons ?thanks for the help guys
ScottZ is offline   Reply With Quote
Old 08-18-2015, 05:10 AM   #3439
maddog9's Avatar
I would do green springs all around!
Old 08-18-2015, 05:50 AM   #3440
Would you recommend this for a reasonable bumpy, blown out track?
Old 08-18-2015, 10:08 AM   #3441
maddog9's Avatar
Yep
Old 09-01-2015, 10:09 AM   #3442
dtr
dtr's Avatar
Default TLR electric clutch
http://www.tlracing.com/Products/Def...odID=TLR342003
How much maintenance would this require?
dtr is offline   Reply With Quote
Old 09-02-2015, 12:26 AM   #3443
Can't seem to find any pictures how that electric clutch go on?
[Losi XXL - Trackstar esc & 2100kv] [Losi 8ight 2.0 - Trackstar esc & 1900kv] [Mini 8ight] [Kyosho ZX5 - Tekin rs pro esc & 5.5T] [Yokomo Bmax 4 iii Factory - Trackstar esc & 4T]
Vinno is offline   Reply With Quote
Old 09-04-2015, 09:06 PM   #3444
Bwadd2002's Avatar
Trader Rating: 8 (90%+)
Send a message via Yahoo to Bwadd2002
Originally Posted by skrichter View Post
What shock towers is he running?
Bwadd2002 is offline   Reply With Quote
Old 09-05-2015, 06:20 AM   #3445
Trader Rating: 20 (100%+)
Those are JConcepts carbon towers.
Randy
RandyJones is offline   Reply With Quote
Old 09-05-2015, 08:09 PM   #3446
Default esc
Originally Posted by truggynut View Post
I am very new to the racing world of rc buggys. I would like to know what esc and motor combo would be a good one to start out with. I have a 1/8 scale losi 8ight 3.0 buggy. Also what servo would go great with that combo also. Thanks for the help.
I would go with Hobbywing 120amp esc and 1900kv motor also hobbywing. Hi-tech 7955 tg
traxxx is offline   Reply With Quote
Old 09-08-2015, 12:04 PM   #3447
Wondering what y'all's thoughts on the clutch are? What r gonna be the shoes and springs to run and also what kind of hearing is going to be best?
Farmboy24 is offline   Reply With Quote
Old 09-10-2015, 04:00 AM   #3448
damang999's Avatar
Trader Rating: 15 (100%+)
probably already been answerd many times
which way do i install the tapered pistons?
taper topside or bottom side
damang999 is offline   Reply With Quote
Old 09-14-2015, 08:00 AM   #3449
RENOV8R's Avatar
Searched the thread but couldn't find an answer. What is the width of the chassis? 5 1/2 inches?
RENOV8R is offline   Reply With Quote
Old 09-14-2015, 04:39 PM   #3450
Trader Rating: 2 (75%+)
98% of the time
taper Down
Also this is the fastest way to free up your turnbuckle ends I did it one time and everything is Perfect.
http://www.amazon.com/gp/product/B00...ilpage_o02_s00
Best $6 RC purchase
Barista is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
