Old 07-15-2015, 05:14 PM   #3406
ChrisWolfson's Avatar
Send a message via AIM to ChrisWolfson Send a message via Yahoo to ChrisWolfson Send a message via Skype™ to ChrisWolfson
Originally Posted by buster8787 View Post
That's up to you. You might strengthen a weak point (spur) and find another weak point like a diff or something, that's all I'm saying.
Is your motor and pinion gear thread locked? I stripped one out a few weeks ago because I forgot to thread lock the motor and a 12 foot high jump usually gets some good chassis slap.....lol
I always run a steel spur gear on my car. losa3552
TLR / Horizon Hobby / Spektrum / Tekin / JConcepts / MIP / B-Fast RC / UpGrade RC
ChrisWolfson is offline   Reply With Quote
Old 07-19-2015, 06:36 AM   #3407
maddog9's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Tom-sct View Post
Hey guys.
I have an 8ight E 2.0
Couldn't find the thread for this particular vehicle.
Hopefully I can get some info here.
I have the +2MM chassis.
It has pads on the droop screw area.
I thought I read somewhere to grind these pads off for more ride height?
The 8ight E 3.0 I noticed doesn't have the pads on the chassis.
Is this an up grade I can do for more ride height or are my shocks not long enough to get any more travel? Maybe have to go to the 16 MM shocks?
Thanks.
Tom
Better off getting a nice used 3.0 for 300 bucks. By the time you buy shocks an towers you have and easy 140 into it.
maddog9 is offline   Reply With Quote
Old 07-20-2015, 03:02 AM   #3408
DiaRh34's Avatar
Send a message via AIM to DiaRh34
I read a while back on the 8ight group on facebook that you can use the 3.0 e chassis guards on the 2.0 e and run the 3.0 e bodies. Is this true? Please only answer if you have first hand experience.
Taco
Bullet Town raceway Milan, Tn
TLR 8b - Tekin - SMC
DiaRh34 is offline   Reply With Quote
Old 07-26-2015, 12:07 AM   #3409
Hello, hope this is in the right place as its an odd question. I have a couple of Losi 2.0 EU converted to brushless. I know that some3.0 E parts can be used on the 2.0 however I'm not sure about the drive train. Is it possible to put the entire 3.0 drive train - diffs, front and rear centre drive shafts and front and rear CV shafts and axles onto a 2.0 without changing anything else?
mondog is offline   Reply With Quote
Old 07-26-2015, 05:29 AM   #3410
DWT74's Avatar
I recently got a 3.0 nitro car and I am gonna convert it with the Losi e-conversion kit. I put my 3.0E buggy bodies on the 3.0 buggy but the bodies are narrower. What bodies fit a converted 3.0 and mud guards?
THOMASON RACING
KYOSHO MP9E
MugenSeiki MBX7R ECO
Dalton RC
DWT74 is offline   Reply With Quote
Old 07-26-2015, 05:45 AM   #3411
Too his??? He ask what do they drive like to a true e buggy
coombes is offline   Reply With Quote
Old 07-26-2015, 07:53 AM   #3412
DiaRh34's Avatar
someone can asnwer for sure it was asked recently but I can't remember. Something about jc bodies, also maybe a nitro body uncut?
Taco
Old 07-26-2015, 10:04 PM   #3413
RockinTheCasbah's Avatar
All the 2.0 bodies will fit.
RockinTheCasbah is offline   Reply With Quote
Old 07-27-2015, 05:56 PM   #3414
Trader Rating: 15 (100%+)
Ever since I built my 3.0, the front diff has felt like it had lighter oil in it than the rear. Maybe I didn't put enough in? Anyways...what effect will heavier oil have? I would think it would tighten up the car, which I don't really want. Also what would less droop in the front do? I think I know but figured I'd ask.
Wish A-Main would hurry up and get the lap-in-a-can back in stock.
Tommygun1 is offline   Reply With Quote
Old 07-27-2015, 06:13 PM   #3415
Trader Rating: 22 (100%+)
Default Need help with suspension setup on losi 8 e 2.0
Hey guys i recently got my self a losi 8 buggy that im trying to get bash ready. I have 50wt n the rear blue kyosho springs and 45wt n the front with stock springs. To me it feels really soft for my liking. Im thinking just some new springs and ill be good but dont know how to determine the stiffness of the springs by ratio. Any suggestions are welcome. Thanks
Monski is offline   Reply With Quote
Old 07-27-2015, 08:42 PM   #3416
Jerm13's Avatar
Trader Rating: 36 (100%+)
Well, usually the higher the number, the stiffer the spring. So a 8 would be stiffer than a 7 which would be stiffer than a 6 and so on.....
Best thing you could do is start fresh with new springs, pistons and oil. Go with what the book says to run. If you feel its to light, then go up in oil weight. The designers and test guys put a lot of time into the suspension to find out what works best in many situations. Let them do the hard work for you
Since you plan on bashing mostly, you might want to go one spring rate stiffer and 10 higher in oil weight, both front and rear, for those big air landings...and adjust to your liking
Serpent Cobra-TE RCR Nova P5 / Serpent SRX8 Werks B7ProKE
AE SC10.2/////AE B5M CE/////AKA/////Serpent America/////Desoto Racing
Spektrum Radios and Servos, Tekin Speedo's and Motors, SMC Batteries
RC Pro Racing VA, Awesome Hobbies(RIP), Debbies RC World VA, Thunder Alley Raceway NC
Jerm13 is offline   Reply With Quote
Old 07-27-2015, 09:17 PM   #3417
Suspended
TLR 8IGHT E 3.0 THREAD
On the first page, didn't even have to dig.
IBtL
Mantis Toboggan is offline   Reply With Quote
Old 07-28-2015, 04:20 PM   #3418
I am really hoping to get some help on this.
Are there any other setups from team drivers not on the TLR site? I would like to see some low traction setups.
Old 07-28-2015, 06:21 PM   #3419
I have one each of the SCTE 1.0 & 2.0 chassis and was hoping to convert one into an 8ight buggy. Do they use the same chassis and what other parts do they share?
Thanks in advance
HECO is offline   Reply With Quote
Old 07-28-2015, 06:39 PM   #3420
ta_man's Avatar
Trader Rating: 151 (100%+)
Thanks in advance
Many of the screws and a few of the bearings are the same...
At least I think a few of the bearings might be them same. Then again, maybe not.
ta_man is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
