Old 06-30-2015, 04:10 AM   #3376
Originally Posted by FGomez50 View Post
thanks for your advice and this esc has no problem running 4s lipos?
None at all . No worries . Sorry I didn't respond sooner .
Losi57 is offline   Reply With Quote
Old 06-30-2015, 11:00 AM   #3377
Casper's Avatar
Trader Rating: 34 (100%+)
can you show a picture of your wiring setup when you use two shorties
http://www.petitrc.com/setup/losi/se...ctronicsSetup/
You have to run a long jumper across the batteries.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 3.0 (laydown), TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-30-2015, 08:07 PM   #3378
Wonder how long it'll be before there's a new eight from TLR.
I'm looking to get s new e-buggy. I was thinking TLR but the new Tekno has got my interest. The eight e 3.0 has been out for 2 years now. It might not be good timing to buy into something that's going to be replaced soon...any rumours?
Biffff is offline   Reply With Quote
Old 07-02-2015, 08:18 AM   #3379
memyselfandI's Avatar
heya Guys,
Our club is just introducing a new Class and thats is 2 cell 1/8th e buddy, I was thinking about getting a new car but am worried about the weight of these things, any ideas on weight saving???
Carisma Racing Australia
Modelflight.com.au
Team AKA
Ryper Hobbies
memyselfandI is offline   Reply With Quote
Old 07-02-2015, 11:23 AM   #3380
Casper's Avatar
Originally Posted by memyselfandI View Post
heya Guys,
You can do this with an 8ight but this class is more intended for converted SCT like the MIP conversion or the Tekno light buggy (again using the SCT platform components). Losi had the 810 but never got it in a electric version as it was apparently before it's time.
Putting a lighter 2S battery and using a setup like the Tekin T8i motor and then looking at some other things to lighten up the buggy you could get it not too far off. TLR sells some alum drive shaft stuff and you can scrounge up a titanium screw kit to try and save some weight there and other little things but I think you are better off getting a used SCTE and converting it with some MIP stuff and going that route if you want to run this class
Old 07-02-2015, 08:39 PM   #3381
Oh ok is that buggy any good? I thought it looked a little bit adhock..
Modelflight.com.au
Team AKA
Ryper Hobbies
Old 07-03-2015, 10:44 AM   #3382
Originally Posted by chihengxuan View Post
is any one know how to convert 2.0 to 3.0?
Step 1:
List your 2.0 in a classified.
Step 2: take $$ and purchase a 3.0.
To convert to a true e3.0 you'll be changing most of the parts.
Old 07-03-2015, 02:40 PM   #3383
The 3.0 does everything better.
Austin's dad is offline   Reply With Quote
Old 07-03-2015, 04:25 PM   #3384
thanks, some people say that the the rear diff on 3.0 is weak. is that ture?
Nope.
You only have to shim it correct:-)
JQ-Racing
REDS
AKA
Savox
Magnus F is offline   Reply With Quote
Old 07-04-2015, 01:54 AM   #3385
stanson's Avatar
Is there a replacement for driiveshaft pins? Driveshafts are not cheap and my front ones pin is about 50% worn... a part number would be great.
stanson is offline   Reply With Quote
Old 07-04-2015, 02:13 AM   #3386
dtr
dtr's Avatar
Yes, LOSA3518.
dtr is offline   Reply With Quote
Old 07-04-2015, 02:41 PM   #3387
stanson's Avatar
Today I made this drive shaft pin replacement tool, saved a few bucks!
how to print screen on pc
Old 07-05-2015, 01:06 PM   #3388
stanson's Avatar
Today I crashed really hard, after a very fast and long jump I hit the fence and buggy almost broke into 2 pieces... finished with broke broke spindle carrier. Now don't know I should just replace it, forget it or make a tunning option with alu TLR344001 part?
Is this a known weak point of 3.0e or that is just my bad driving?
[IMG]
post a picture[/IMG]
Old 07-07-2015, 09:59 PM   #3389
Default Smallest Mah battery
What do you think would be the smallest Mah battery one could use in a 10Min race with a tekin 1900KV and tekin gen 2 esc for this car? I was thinking 3700 - 4000Mah at a min to get 10Min?
cheers
Pegger
pegger is offline   Reply With Quote
Old 07-07-2015, 11:41 PM   #3390
cheers
Pegger
15/45 Tekin gen2 - I can get 12 mins with CS 40C 4000mah, C211018; Could get bit more, but after those 12 I still have 3.7 per cell and that seems to be on safe side;
Trying to be gentle on gas to do it, as my tracks are slippery outdoor 45sec laps;
And that weight - they are about 100 grams lighter than 6000 or 7000 batteries.
janisdaubergs is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
