TLR 8IGHT E 3.0 THREAD
#3361
I know most of you guys are from the US but in Eastern Europe we use Nvision Lipos, they come from Germany. Don't know about taxes, but if it's possible for you to buy them - they're worth it! Guys that race here have them for 3-4 years without any issues. 6500mAh + 90C - tons of punch and run time. Absolutelly top quality.
Brain Energy lipos are also top quality and a little cheaper, they're 45c and 5200mAh - enough for 12 minutes race. Never had any problems with them, can't even compare with Turnigy, Nano Techs, Venoms or GensAce (had them all).
#3363
Love the Tekin stuff and Spectrum
#3364
I would suggest CS-Electronics, have been using their batteries for 3 seassons, and still using same packs.
No issues, only got them bit puffed when my motor almost died:
Motor temp was 170 degrees celsius when stopped and whole car almost burned down, but they are still great and internal resistance and balancing is as if they would be new.
Using 2x2S 75/150C 7200. They are also a bit lighter than others.
#3365
SMC if you're in the US, super impressed with them over the years
Been running the 6500mAh 60C packs this season so far and kind of wish I would have gone for the 5000s for less weight since I hardly use the pack during a race. You can't beat paying 60USD for a 5000 50c or 70USD for the 6500 60c. They go on back order some but they get them in fast and QC them and ship super fast to your door.
#3366
for the price and ratings i went with two smc lipos i am going to give a chance
#3367
how do you guys feel about the hobbywing 150 amp esc being used in the 8e, anyone have any problems with it
#3368
is the 150 amp hobbywing just as reliable?
#3370
sct pro
thanks for your advice and this esc has no problem running 4s lipos?
#3372
I have opposite experience. Hw150a has never failed and 2 of my sct pro died. I race 2nd season on the same hw150 and never had a single issue with it.
Sct pro is rated 120a, kinda low.
#3373
Rear end binding
anyone else rear of car stay up when u gently set car on table? I have been thru most possibilities. Gone thru shocks twice. Shafts had slightest wobble, I have ran much worse, I replaced shafts and Pistons. They feel about same as fronts when I rebuilt them. camber links free hinge pins not binding. Arms free when shocks are off. Something is binding. When rear stays up I push it down slightly and I can feel it break free then settle. Any help is appreciated. Doesn't seem to squat In rear on power like old car did. I'm running split Pistons with 32.5 oil.
#3374
So I jam everything I can into the Losi 8ight receiver box: airtronics 471rx, transponder, Novak Glitchbuster because I run a Savox Servo, I threw a little foam in there for some protection. It's a tight fit in there with all the wires and connectors, but it works. Ran 5 separate race days with out a problem. Yesterday, I went to switch it on and the RX will not bind with radio.
My question is, has anyone had issues with the wires in the receiver box pressing on the bind button?
#3375
shorty setup
can you show a picture of your wiring setup when you use two shorties
