Old 05-09-2015, 01:52 PM   #3286
Originally Posted by symmetricon View Post
Send me a txt if you still have my #, I'm ready to deal...
Ha ha ha. Will do.
Who the ^&@$#()! Is Jason Branham!?
cjtamu is offline   Reply With Quote
Old 05-09-2015, 08:09 PM   #3287
rosko's Avatar
5 hole stk pistons or 8 hole pistons with the splits n rear what can I expect....running on indoor clay decent size jumps...does one have more traction, jumps better etc etc...
rosko is offline   Reply With Quote
Old 05-10-2015, 06:35 AM   #3288
I have the RTR version. Will battery forward make a big difference for it? I find that the rtr tends to land nose first over jumps anyways. But if that battery forward helps overall handling, I'll probably try it.
sponsored by : Stashko Speed Shop
Everingham Electronics Emporium
Webster RC Parts Warehouse
Anderson Zap Ties
- overkill is a good thing -
buster8787 is offline   Reply With Quote
Old 05-10-2015, 08:32 AM   #3289
jmkalt's Avatar
Do the dome wheels that come with this kit have a different offset than, say, aka evo wheels? I notice that there seems to be a deeper recess for the wheel nut, but wondering if other wheels are just as compatible.
jmkalt is offline   Reply With Quote
Old 05-10-2015, 08:53 AM   #3290
Integra's Avatar
1/8 buggy wheels are 1/8 buggy wheels, Everything is compatible within reason. 99% of rims have similar if not Identical offset.
Old 05-10-2015, 10:02 PM   #3291
Hellbound's Avatar
Trader Rating: 37 (100%+)
Originally Posted by stanson View Post
This is what happened during my last race weekend. Both front shafs are gone. Don't get how could this happen, I didn't crash hard, it was just one of the many (high) jumps during the race weekend. Any ideas what could go wrong?
I did a similar thing yesterday but i only ripped the shock shaft out of the ball cup and bent the drive shaft, the shock shaft is still fine. It was all my fault due to showing off by clearing a quad of jumps in one go and landing badly. The nitro boys take the quad as a double double
Kyosho MP9e TKI3 - Tekin - Hobbywing - Savox - Futaba
Hellbound is offline   Reply With Quote
Old 05-11-2015, 09:02 PM   #3292
patrick lsp's Avatar
Trader Rating: 176 (100%+)
Default Diffs?
5 7 3 in diffs. Last indoor race. Front tires wearing twice as fast. First outdoor race on loose track I switched to 5 5 3. Same result different tires. Fronts still wearing faster. Lots of wheel spin. Each qualifier I turned down punch. Any suggestions for more even wear.
Eb48.4
Nb48.4
Nt48.3
Reds racing USA.
patrick lsp is offline   Reply With Quote
Old 05-12-2015, 08:23 AM   #3293
wittyname's Avatar
All the weight is in the back .... Put 10 in center and give it a shot . You may be wearing the fronts coming out of the corners , a stiffer rear set up may help keep some of the weight from transferring to the rear.
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 05-18-2015, 08:12 AM   #3294
Hinch45's Avatar
What is the fastest and quickest way to change diff fluids, front, center and rear?
I recently bought a used 8ight e 3.0 for my first 1/8 scale car. Unfortunately I did not put it together so I don't know the car as well as I should. I would like to change the diff fluids before taking it to a race. To access the front diff is in necessary to remove the entire front clip; shocks, arms and all or is there a short cut or quicker way? Same thing with the rear. Do I remove the entire rear clip, ? I was hoping to find video that would walk me through getting to the diffs, but couldn't find one.
Hinch45 is offline   Reply With Quote
Old 05-18-2015, 10:32 AM   #3295
I always remove the clips it provides me with the ability to check hinge pins for free movement and at the same time I clean and regrease the CV joints. It seems like a lot to get to the diff's but goes rather quickly after doing it a few times.
dynamiteracer is offline   Reply With Quote
Old 05-18-2015, 11:13 AM   #3296
stanson's Avatar
It's paint in the ass to access front and rear diffs in 8ight 3.0. Maaaany screws to remove. Don't know other buggies, but with RC8.2e or MBX7 it's like 4 time less time consuming. Not to mention new Dex8...
And fitting the rear diff in with bearing inserts + shims is something that requries a lot of patience...
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 05-18-2015, 01:58 PM   #3297
Ryobi 4V drill amongst the best $30 I ever spent on RC. Slow enough that it doesn't strip screws going into plastic, adjustable torque.
Old 05-18-2015, 08:09 PM   #3298
That's one nice thing abut the Durangos.....the easy diff access....
They've had that for years.....I just picked up a dex408 and that's definitely one of its best ,if not best feature....It also looks pretty damn good....
.....but so does the 8e 3.0
Took the Durango out for its first spin earlier today...I love it....but...it ain't a 8e 3.0...
These 3.0's are freakin' awesome.
A lil snapshot of the two gangstas....
NickTheGreek is offline   Reply With Quote
Old 05-20-2015, 01:08 PM   #3299
jmkalt's Avatar
Thanks.
So no clearance issues at all using AKA Evo Wheels with this car?
Old 05-21-2015, 05:30 AM   #3300
Stubbs's Avatar
Trader Rating: 57 (100%+)
Thanks.
Nope....I use AKA EVO wheels all the time on my 3.0 nitro and electric.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
