Old 05-05-2015, 08:01 PM   #3271
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Did you add more droop? or just change ride height?
Blitzrockey is offline   Reply With Quote
Old 05-05-2015, 08:10 PM   #3272
jag5508's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Blitzrockey View Post
Im in the same boat. I run weight up front and the car seems to work really well lots of steering. I will try the truggy caster blocks this weekend to see if its makes it any different.
Any part # on those so I don't order the wrong ones ?
TOYZ 4 BOYZ
jag5508 is offline   Reply With Quote
Old 05-05-2015, 08:15 PM   #3273
For the truggy ones? They are just the 3.0 truggy ones, I belive there is only one kind.
Old 05-05-2015, 08:23 PM   #3274
jag5508's Avatar
Is it just the 3.0 truggy . Is there a difference between the 2.0 or 3.0 ?
TOYZ 4 BOYZ
Old 05-05-2015, 08:31 PM   #3275
symmetricon's Avatar
Trader Rating: 27 (100%+)
Truggy 3.0 caster blocks, not 2.0...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
symmetricon is offline   Reply With Quote
Old 05-05-2015, 08:36 PM   #3276
symmetricon
Old 05-07-2015, 04:48 AM   #3277
Trader Rating: 20 (100%+)
What screws do the RTR 8E plastic shock caps take for the bleeder hole?
Randy
RandyJones is offline   Reply With Quote
Old 05-08-2015, 03:11 AM   #3278
stanson's Avatar
This is what happened during my last race weekend. Both front shafs are gone. Don't get how could this happen, I didn't crash hard, it was just one of the many (high) jumps during the race weekend. Any ideas what could go wrong?
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 05-08-2015, 03:17 AM   #3279
Can be done if landed while braking or landed more on one wheel after high jumps.
When I was still just learning, I also bent few shock sharfts, but always there was some explanation - I saw when it could happen.
janisdaubergs is offline   Reply With Quote
Old 05-08-2015, 04:07 PM   #3280
Originally Posted by wittyname View Post
If anyone is on the fence about moving the battery and esc around , go for it ! I actually like my car now . Difference was / is amazing . 2 screw holes line right up , drilled and tapped a 3rd at the right front corner . Awesome .
Can you post some photos?
I was looking at it this morning....it doesn't look like it fits?????
Did you have to dremel the battery tray?
Mo info please.
mini 8, mini 8t, SCTE3, SCBE, and several RC Surfers
OopsDidIDoThat is offline   Reply With Quote
Old 05-09-2015, 09:04 AM   #3281
Mo info please.
Not sure when Sym will be back on, but I saw him Wednesday and looked at his car. Battery tray comes forward to the stock ESC location basically. From what he said, some of the holes on battery tray line up already. We looked at it and he'd had to drill 2 additional, but it looked like you could just drill the two additional holes after you mounted the tray. Yes, he had Dremeled just a small area off the right front of battery tray. shouldn't be a hard mod. Soon as I finish building my new Yokomo I'm going to do it to a friend's car.
Who the ^&@$#()! Is Jason Branham!?
cjtamu is offline   Reply With Quote
Old 05-09-2015, 09:19 AM   #3282
symmetricon
To be honest I don't exactly remember, I think I removed a little bit of droop though. I'll try to get a setup posted...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 05-09-2015, 09:35 AM   #3283
Send me a txt if you still have my #, I'm ready to deal...
XRAY / RCAMERICA
JCONCEPTS
RCSHOX
Mikes Hobby Shop
Old 05-09-2015, 10:21 AM   #3284
Thanks symm
Old 05-09-2015, 10:34 AM   #3285
wittyname's Avatar
Mo info please.
You do have make room in the bottom of the tray to clear two screws . 2 holes line right up , the right rear and the left middle. I drilled and tapped a right front hole. I won't be able to upload a picture until Monday . if you take your tray out and move it around some , you will see it line up. Its solid enough without the new holes to test it . if you want to make it permanent , you should add new holes.
wittyname is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
