TLR 8IGHT E 3.0 THREAD
#3241
Normal (baring any bind in rod ends), Pushing it down isn't the way to check the Ride height tho, Dropping from 8-10" in a "Consistent" manner is however.
#3242
So nobody knows of anything else other than what has the Losi name on it that will work? I guess I'll take a look at the 2.0 stuff on line and order something.
Yesterday after working on this problem most of the previous night I got to the track and the suspension was great. Made a few laps with no trouble in warm up. Went out for the race and 3 or 4 laps in I had 1/2 inch clearance. I have been racing for almost 5 years and this is my first buggy and second Losi. I have had 4 different people try to help me on this. They say squeeze them. I say I have many times. I tell them to try and they do. And then they return to sticking again. I tried using hot water and dunking them in cold after so they will not return to the original shape. They do. Used a heat gun on them, putting them in cold water after squeezing them. Same thing. I'm getting fed up with this. So I left the track yesterday during a weekend long race and went to the sort of Hobby shop nearby and picked up something that I thought might work. It didn't.
Does anybody in the aftermarket make anything that might solve this ?
#3243
make sure when the links are mounted on the car they aren't hitting the gearbox. I had to grind down the box to get it to clear. I thought something else was binding but that was it.
#3244
PS I have also reamed the arms, changed and polished the pins
#3245
No not normal, should return to the ride height you set. Squeeze the plastic rod ends like has been being talked about to free it up, 9 out of 10 times that is the issue with a new kit. TLR, love the buggy but sure seem's alot of folks having binding issues. Easy fix for guys in the know but big problem for those that are not. I'll bet a bunch of ill handling 8ights out there with guys scratching there heads.
Little confused about what you're asking. What DanJ said is correct. But "normal" ride height is actually where the buggy settles when pushed down on or dropped on the table from 6" or so. Are you talking about just setting the buggy down, then pushing on i? If that's the case it probably won't come back to the same height it started at. wherever it settles after you push on it should be normal ride height, and it should come back to the same height every time. If it doesn't then you might have a binding issue.
Cool, thanks for that folks!
#3246
I ended up taking them off (i.e. unmounting the ball), put some rag over them and with a set of pliers squeezed the crap out of them (i.e. Giving as much force with standard pliers as I could), starting at one point and moving around.
They have consistently moved freely since and handles like it's on rails....
#3247
It would take a little measuring but any end link that can thread on the Losi links should be fine. I would look for x ray plastic bits , they were the best parts I ever owned. OR ... Try polishing the ball inserts themselves . Put them on a screw and put it in a drill press and spin it . Start with 1200 grit paper and end with rubbing compound . A few thousandths off those ball inserts will probably get you what you want
#3248
Well are starting with shocks full extended with full drop? If so normal, it should be returning at least 27 mm from the ground.
#3249
#3251
I went through the exact same.
#3253
http://www.harborfreight.com/1-2-hal...ress-3551.html
This is what I used for the ends. Kinda overkill, but I had it. Also makes snapping in and out the links super easy.
I also had to ream the Front and ream Arms (Just used a drill bit) to get them and now the suspension is super free and no binding at all.
#3255
im having no luck freeing up the front myself....Its gotten annoying.
