Old 04-26-2015, 11:54 PM   #3196
idswass's Avatar
I had someone at the track tell me that the aluminum top plate is a must have upgrade. What your guy's option on that? What failure is it supposed to fix?
idswass is offline   Reply With Quote
Old 04-27-2015, 06:52 AM   #3197
Integra's Avatar
Lol false.
Old 04-27-2015, 09:29 AM   #3198
Originally Posted by Integra View Post
Lol false.
Yes sir the plate is not necessary or needed at all.
dynamiteracer is offline   Reply With Quote
Old 04-27-2015, 09:53 AM   #3199
Brian C.'s Avatar
Yeah that is definitely not needed at all. I see of it as more of a being factor than an upgrade.
Brian C. is offline   Reply With Quote
Old 04-27-2015, 10:53 AM   #3200
stanson's Avatar
The only must have upgrade for this kit is alu top servo arm in my opinion.
stanson is offline   Reply With Quote
Old 04-27-2015, 03:07 PM   #3201
Integra's Avatar
IF you like to hit thing's on a regular basis, sure it'll help. But " Must have " is Not the case.
Old 04-27-2015, 03:22 PM   #3202
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Has anyone tried the silver springs up front to get a bit more steering? Right now im using the drake outdoor setup with 5-5-3 for diffs, works really good just could use a tad more overall steering. Its pretty good but could use a bit more on and off power steering. I had 5-7-3 in the diffs and it that gave it a bit more on power steering but made the rear a tad loose for my driving. The 5-5-3 gave it a bit more locked down feel as well as a tad bit more off power steering. I removed the wing spacers last night as well as added a bit more front weight as I had 25 grams and just added some to make 40. Will see how that makes it work at this point. If not I may try the silver front springs to get a bit more overall steering if anyone things that may work? Thanks.
Blitzrockey is offline   Reply With Quote
Old 04-27-2015, 04:07 PM   #3203
Definitely a must have upgrade.....Very important.
It doesnt fix any failure. You just gotta pimp the sumbich out.
NickTheGreek is offline   Reply With Quote
Old 04-28-2015, 01:27 AM   #3204
stanson's Avatar
I do not like - but crashes happen sometimes. I prefer to be always sure to finish the race.
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
Old 04-28-2015, 08:22 AM   #3205
Brian C.'s Avatar
Its definitely not a must my stock one lasted 2 seasons, but it is probably the only "upgrade" that would be considered a truly beneficial "upgrade". In my humble opinion.
T&L BOYZ
Trains and Lanes Racing
Team Kyosho
Old 04-28-2015, 11:59 AM   #3206
stanson's Avatar
Somewhere in this thread a guy from Canada wrote that he races in low temps and it's a common thing on their track that guys break this servo arm.
Old 04-28-2015, 12:15 PM   #3207
Integra's Avatar
Im Also canada and do Frequently race in sub par temps, If you take that big of Hit the Upper Aluminum saver wont be the Life saver you think it is, All that will happen is the Lower Saver portion will fail instead. Been there and Done that,
Old 04-28-2015, 01:12 PM   #3208
Originally Posted by janisdaubergs View Post
Anyone have any setup suggestions for grass track?
We have opening in Estonia with track out on grass with jumps made from wooden trampolines, and I did found grass setup for 22-4, but not for 3.0E.
Just run thicker front diff oil if it is too aggressive. Only change that I have to make.
Matthew Bailey is offline   Reply With Quote
Old 04-28-2015, 02:30 PM   #3209
Im from Canada as well. Out in B.C. I have the aluminum top saver portion but its pretty warm here right now so no worries.
Anyone on the question I had a bit above on this page lol ?
Old 04-29-2015, 02:49 AM   #3210
Trugga's Avatar
What are you running now...
I went from the greens on the front to black (my track can get pretty rough) and ended up going back to green....
If your track is fairly smooth, you may find a bit of improvement.
I ran the blacks up front through 1 pack and swapped back as I lost a lot of feel and poor roll through on fast-ish corners. (i.e. 90 degree right hander at the end of our straight)
Not a lot of difference in rate but a fair difference in handling.
Not a great expense to try out anyway....
Trugga is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
