Old 04-19-2015, 06:52 AM   #3166
Ok guys, I have a suspension on a Losi 8eight e 3.0 rtr which will not rebound. Press down on the car and it will rebound about 1/2 inch and that is all. I have squeezed the turnbuckle ends after using a hairdryer on them and even dipped them in boiling water atleast 4 times and they will not loosen up. Is my next step reaming them? Or just all around replacing them? Now the hinge pins seem especially stiff to move. Should these move freely? Any help would be great.
sponsored by : Stashko Speed Shop
Everingham Electronics Emporium
Webster RC Parts Warehouse
Anderson Zap Ties
- overkill is a good thing -
buster8787 is offline   Reply With Quote
Old 04-19-2015, 03:20 PM   #3167
Tim Garland's Avatar
Hinge pins should be free, if not get a reamer of the same size and ream out the arms, also use mothers to polish the pins. Don't boil or use a hair drier on the ball cups, simply use a pair of pliers to squeeze the cups with them connected to the ball. Grip the cup with the pliers, over the ball and squeeze the handle several times, 5 or 6, firmly and the cup WILL loosen up. It doesn't matter what brand car it is, this will work every time. If you try and it didnt, you simply didn't squeeze the cup hard enough to stretch it. In the end all that is taking place is a slight stretching of the plastic.
RacePro Hobbies
RadioActive RC Raceway
Tim Garland is offline   Reply With Quote
Old 04-19-2015, 03:53 PM   #3168
It's definitely the hinge pins then. thanx for the reply
Anderson Zap Ties
Old 04-19-2015, 04:04 PM   #3169
No problem, if you can't twist the turnbuckle by hand just get rough with the pliers haha
RacePro Hobbies
Old 04-19-2015, 04:47 PM   #3170
Also can be shock shaft, dirty shock oil, and sway bar to tight. You can disconnect all to isolate the problem.
RacePro Hobbies
Old 04-19-2015, 06:07 PM   #3171
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Regarding the truggy caster blocks, where is the best place to shim them? In the center?
What is the best shims to get for this. Thanks
Also will this mod give me more off power steering ? Just looking for s little bit more. Thanks.
Blitzrockey is offline   Reply With Quote
Old 04-19-2015, 07:16 PM   #3172
I was twisting so hard last night that the metal was popping out
Anderson Zap Ties
Old 04-19-2015, 08:37 PM   #3173
What nut driver have you found that works with the 4-40 nut on the shock cap? All the ones I have are to large of a diameter to fit between the cap and the nut.
Race Cars:
On Road: 2 Xray T3 2012, Serpent S100, 3Racing F113
Off Road: Tekno ET48, Tekno SCT410, Losi 8 Buggy E 3.0, Losi 22 sct, Losi 22 2.0 buggy, HB D413
seanhawk is offline   Reply With Quote
Old 04-19-2015, 10:16 PM   #3174
I use dynamite nut driver set for this, it has two nut drivers I can use in its 5pc set, one for all the 40-4 nuts and one for those who holds shock mounts.
janisdaubergs is offline   Reply With Quote
Old 04-20-2015, 02:11 AM   #3175
Hi folks,
Last time out with my 8ight-E 3.0 RTR, I cranked the AVC up & at low speed, i.e. not even walking pace, the servo would pull full tilt to the left, with no steering input from me.
This spooked me enough to not attempt to drive with AVC sensitivity beyond minimum, as I didn't want this randomly happening at speed.
So my question is, is this normal AVC operation for low speed use?
I know the benefits are most felt at high speed, but is this sounding like a fault, or nothing to worry about.
The car's fantastic with AVC turned right down, so won't miss it terribly..
Cheers
K
kaktis is offline   Reply With Quote
Old 04-20-2015, 08:01 AM   #3176
maddog9's Avatar
Trader Rating: 29 (100%+)
Shim it all the way forward. I put a bearing from the SCTE rack in behind the caster. Switch the screws, put the long screw through the back of the caster. I would add about 2-3mm of droop as it puts the axle at a different height. Check your ride height as well. Indoors it seemed to give more overall steering. I can't tell outdoors if it will be the way to go or not.
Auer Ace Hardware|Kustomized Innovations|Performance 8ight Racing (Best Built 8ight Kits)
Patrick Maddog Dillon Jr.|2016 Stateline Raceway King of Kings E-Truggy Winner
Past Winning Kits: Losi 8ight 1.0, Losi 8ight 2.0, Serpent 811 BE 2.0, TLR 8ight-E 3.0, TLR 8ight-E 4.0, TLR 8ight 4.0, TLR 8ight 4.0 2017, Losi LST 2.0, Kyosho ST-RR, Losi 8ight-T 2.0, TLR 8ight-T 3.0, TLR SCTE 1.0, TLR SCTE 2.0
maddog9 is offline   Reply With Quote
Old 04-20-2015, 06:27 PM   #3177
Originally Posted by kaktis View Post
Hi folks,
Cheers
K
I haven't had this problem. I generally turn everything on and let it sit for a few seconds so the AVC can calibrate.
Anderson Zap Ties
Old 04-20-2015, 07:01 PM   #3178
Oops.. yep, that could well be the problem.. thanks for that, much appreciated!
Old 04-20-2015, 08:41 PM   #3179
Ill see how she works, thanks for the info. I actualy took it out today again, just getting used to the car as I had a serpent before. This has a lot of corner speed. And I just have to drive it a bit different. Once I did that it started to handle a lot better and actualy had a lot of steering on and off power. I have the weight kit coming also and will try that. Im running the drake outdoor setup with diffs at 5-5-3. Any other tips to maybe get a bit more steering? I think the weights may help?
Old 04-21-2015, 04:12 AM   #3180
maddog9's Avatar
I run the 40 gram weight, battery and esc flipped (so battery up front), green springs all around, and i run a trinity 6950 4s. I like the car heavy about 8.2lbs roughly.
Tags
e-buggy, eight 3.0, losi, spur gear
