Old 04-07-2015, 09:33 AM   #3136
Thx for the reply. Just ordered my kit.
What combo woud you guys recommend for this baby. I will run on 4s
Kind of like the castle because it's waterproof. I'm always worried about water lol
dodgeboy8888 is offline   Reply With Quote
Old 04-07-2015, 10:23 AM   #3137
SUPERLOOPER's Avatar
Originally Posted by Blitzrockey View Post
What's the best diff fluid setup for a outdoor med to low bite track that can get bumpy. Right now I built it with 5-7-3. wondering if that should work fine ? Thanks
I prefer 5/5/3 myself. The 7 in the middle will give a more direct feel.
2017 Sponsors:
Team SOARSEIKI * AKA * Reds * Sanwa * Nitro Pro fuel * LFR * On point graphics * Xpert * M2C * Daytona RC paint
Brian Looper
SUPERLOOPER is offline   Reply With Quote
Old 04-07-2015, 11:18 AM   #3138
Sworkz
T-PRO
Sanwa
Nosram
mwrccars.at
Magnus F is offline   Reply With Quote
Old 04-07-2015, 01:16 PM   #3139
My track is med to low bite. I run 5-7-3 and I think that is the best setup.
Halert71 is offline   Reply With Quote
Old 04-07-2015, 01:38 PM   #3140
stanson's Avatar
5-7-5 works best for me, like said before, it depends of your driving style.
Tekno EB48.3 | Xerun 4068 2250kv | Xerun 150A | Hitec 7985MG
Tekno ET48.3 | LRP 2000kv | Xerun XR8 Plus| Hitec 7945TH
Schumacher KAT K1 Aero | Xerun 6.5T 5340KV V10| Toro TS120A Pro | Hitec 8330SH
stanson is offline   Reply With Quote
Old 04-07-2015, 07:36 PM   #3141
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Thanks guys. Ya I drive smooth and like to roll the corner. But when I get back on it I want it to steer where I point it not push. So 7 should work the best I'm thinking.
Blitzrockey is offline   Reply With Quote
Old 04-07-2015, 09:32 PM   #3142
jag5508's Avatar
Trader Rating: 14 (100%+)
I just Built mine and thats what I put in mine . I haven't driven in a few years so this Sunday ought to be interesting lol .
TOYZ 4 BOYZ
jag5508 is offline   Reply With Quote
Old 04-08-2015, 02:14 AM   #3143
Trugga's Avatar
I'm running a sensored 2200kv Hobbywing Xerun kit on 4s.
2200kv is a bit of overkill, BUT...... It fly's....
I've programmed back the throttle and it's still a rocket.
Beauty of the Hobbywing kit is that you get the program card included, and it's sensored.
(Power wise it craps on my HPI Trophy Flux Truggy.)
Trugga is offline   Reply With Quote
Old 04-08-2015, 08:28 AM   #3144
allan42r's Avatar
Originally Posted by Mikeand22 View Post
I'm having temp issues with my Tekin 1900Kv motor in my 8ight E 3.0. The drivetrain appears to spin freely, no binding and it's easy to spin. I went down a tooth on the pinion last weekend and temps went up. Went from a 16T to a 15T pinion. Temp outside was about the same both weekends. I'm running my current limiter at 40. The track is normally very loose because of dust. Any ideas?
I was running warm also but I use a lot of brake and pump the brake on the radio like an anti lock brake. I removed the radio box and used the servo mount like the scte 2.0 . The receiver and transponder mount to the side and that will give you room to mount a fan. It fits between the front diff upright and mudguard, just need a little shoe glue. Also trim the back of the body to let more air flow thru. The fan blows air under, down the side and across the top.
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Old 04-08-2015, 08:31 AM   #3145
allan42r's Avatar
And I run no timing 35 current with a 16 pinion but adjust the EPA to 95 most of the time
Old 04-08-2015, 10:45 AM   #3146
Mikeand22's Avatar
Trader Rating: 24 (100%+)
Thanks for the advice. Tekin recommended going up a few teeth on the pinion because of my track conditions. My body is cut out already. If going up on the pinion doesn't work, I'll try your suggestion. Thanks again for the advice.
Mikeand22 is offline   Reply With Quote
Old 04-08-2015, 10:52 AM   #3147
mxnickj's Avatar
Trader Rating: 51 (100%+)
Would going up in pinion size make the motor run cooler, or hotter?
mxnickj is offline   Reply With Quote
Old 04-08-2015, 11:01 AM   #3148
Mikeand22's Avatar
Typically hotter. However, because my track is very loose, I'm getting too much wheel spin. This is why my motor temps are too hot. By going up on the pinion gear under these conditions I'm hoping to lessen the wheel spin and therefore bring the temps down.
Old 04-08-2015, 11:40 AM   #3149
Kind of a newbie but I think if you go for a bigger pinion you will actually have more wheel spin.
I am looking for a combo for my 8ight-e. Anybody tried the tenshock x802v2 2100kv ?
Old 04-08-2015, 12:04 PM   #3150
stanson's Avatar
smaller pinion = more torque = more wheel spin
bigger pinion = less torque = less wheel spin
Tags
e-buggy, eight 3.0, losi, spur gear
