Old 03-23-2015, 04:58 PM   #3061
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Thanks!
Blitzrockey is offline   Reply With Quote
Old 03-23-2015, 06:37 PM   #3062
Hinch45's Avatar
Is it necessary to drill holes in the body for ventilation? I installed a tekin rx8 gen2 and don't want it to overheat, but don't want to drill holes in a new body if I don't have to.
Hinch45 is offline   Reply With Quote
Old 03-23-2015, 06:39 PM   #3063
Brian C.'s Avatar
I never did...
Brian C. is offline   Reply With Quote
Old 03-23-2015, 09:53 PM   #3064
Originally Posted by towertsk View Post
I'm assuming your referring to the servo saver build. You can use alcohol to clean any oil or grease on it. The cleaning will help the thread lock to bond.
Hello. Im such a newbie! Yes I am referring to the servo saver build. So I can use alcohol? Alcohol I have laying around. Does that motor degreaser spray work better? Or will alcohol do just fine? I put building it on hold for now until I am sure what I can use as a replacement for the motor spray. Any other tips or suggestions with the rest of the build? Can I use Carborator cleaner or throttle body/intake cleaner thats used for normal 1:1 cars? Thanks!
c00lguy is offline   Reply With Quote
Old 03-23-2015, 10:00 PM   #3065
RockinTheCasbah's Avatar
Originally Posted by Blitzrockey View Post
Who here locks there servo saver right down pretty well when using a high end servo? I did with my old serpent 811be last year and didn't have a issue. I would assume I would be fine?
I run mine very tight no problems
RockinTheCasbah is offline   Reply With Quote
Old 03-24-2015, 04:30 AM   #3066
Mikeand22's Avatar
Trader Rating: 24 (100%+)
What's the benefit of running the servo saver really tight when you have a high end servo? I run High Voltage servos in mine and I've never heard of this. Thanks
Mikeand22 is offline   Reply With Quote
Old 03-24-2015, 06:58 AM   #3067
Anything that will clean residue from metal will be sufficient.
They just want the threads to be clean of debris and grime because you are going to loc-tite it.
Something like rubbing alcohol and a microfiber cloth would be just fine. I'm sure carb cleaner would work too.
22 3.0 // 22-4 2.0 // 22T // 22SCT 3.0 // MBX7R Eco
TRCR
Christophoclese is offline   Reply With Quote
Old 03-24-2015, 07:01 AM   #3068
The benefit of a tight servo saver is more precise steering inputs, more of the time. With the saver loosened up, you may notice the front wheels not holding a steady angle under heavy cornering loads. This happens to me when I bring my e-buggy inside onto high-bite clay.
TRCR
Old 03-24-2015, 06:40 PM   #3069
jag5508's Avatar
Trader Rating: 14 (100%+)
Kinda lazy sorry probably been answered a bunch of times but what size 4cell battery fits this good ? I just ordered car and speedo today also any upgrades that are absolutely necessary ?
TOYZ 4 BOYZ
jag5508 is offline   Reply With Quote
Old 03-25-2015, 03:57 PM   #3070
jag5508's Avatar
Does the kit come with any pinions at all anyone ?
TOYZ 4 BOYZ
Old 03-25-2015, 03:58 PM   #3071
InARush's Avatar
It does not.
Keep up or keepoff I'm in a rush!!
InARush is offline   Reply With Quote
Old 03-25-2015, 04:05 PM   #3072
jag5508's Avatar
Originally Posted by InARush View Post
It does not.
Thanks any idea about diff oil ?
TOYZ 4 BOYZ
Old 03-25-2015, 05:49 PM   #3073
comes with that...5k all around
NickTheGreek is offline   Reply With Quote
Old 03-25-2015, 05:58 PM   #3074
jag5508's Avatar
Thanks I been trying to see what comes in the kit but haven't really been able to find much on it . Like I'm not sure what shock springs it comes with either . Theres so many pages everywhere but I can't find anything .
TOYZ 4 BOYZ
Old 03-25-2015, 06:58 PM   #3075
jag5508's Avatar
Anyone know what tires Proline fit the rims that come with it too ?
TOYZ 4 BOYZ
Tags
e-buggy, eight 3.0, losi, spur gear
