TLR 8IGHT E 3.0 THREAD >
Like Tree1Likes
Old 03-05-2015, 10:05 AM
  #2986
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
About how long of motor wire do I need to reach a tekin t8 motor? I have about 265mm on my esc right now and was wondering if I have to get some longer wire, As I have not gotten the car yet to check. Thanks!
Blitzrockey is offline
Old 03-05-2015, 01:35 PM
  #2987
Casper's Avatar
Trader Rating: 34 (100%+)
265 should be plenty
Casper is offline
Old 03-05-2015, 02:08 PM
  #2988
wvrcracer's Avatar
What are the advantages/disadvantages of using the rear axle dogbones
wvrcracer is offline
Old 03-05-2015, 04:25 PM
  #2989
Thanks Casper.
Old 03-05-2015, 05:53 PM
  #2990
Brian C.'s Avatar
That's should be plenty!
Brian C. is offline
Old 03-07-2015, 04:41 AM
  #2991
I've set my 8ight-e 3.0 up as per manual
I put 5000wt oil in the Front/Centre/Rear diffs but when i'm flat out my front wheels start to balloon a lot,
seems like my front wheels are spinning a lot more then the rear.
Feels like 70%front and 30%rear
So put 7000wt in the centre and it didn't make much of a difference still feels like its 65%front and 35%rear
What weight oil should put in the front to try and get it closer to 50%rear/50%front
rotachoc is offline
Old 03-07-2015, 06:58 AM
  #2992
Integra's Avatar
Nothing will prevent the tires from ballooning unless you use 50-100K oil which then renders the center diff moot. Im going to guess by the ESC and Motor combo, that your not racing this thing are you ? Why do you want it 50/50 ?
Integra is offline
Old 03-07-2015, 10:05 AM
  #2993
Trader Rating: 126 (98%+)
I wanna purchase shorty or 4s packs and how many do i need for a race series weekend? 2-3? What size shorty packs are you guys using? And what size 4s packs are you guys using? Im running on normal size outside 1/8 scale track and 10 min mains.
toepush is offline
Old 03-07-2015, 10:06 AM
  #2994
Hello all. I want to get a 8ight-e RTR setup. Is the RTR also based on the 3.0 platform -meaning will I be able to use 3.0 upgrades on the RTR parts interchangeable? I was also wondering if you guys recommend this RTR. I will mainly be bashing with this and maybe occasional track practice once a month if anything -mostly bash though in my backyard or in the street. Is this RTR durable? I was also looking into the Kyosho MP9e RTR. How does this compare that?
Thanks guys for the help! Any advice would be appreciated
c00lguy is offline
Old 03-07-2015, 01:21 PM
  #2995
xyzracer's Avatar
If u r running whats in your sig (2200kv w/19t on 4s/6s) I would assume u r not racing and just mainly bashing. I would try 10k f/r and 20 k center to keep everything locked down. U r putting down a lot of power running that motor/gearing/voltage...
xyzracer is offline
Old 03-08-2015, 05:26 AM
  #2996
I am just "mainly bashing" and the occasional speed run,
It is heaps of power and have trouble keeping tires from ripping straight off the rims
(Grp's are the only tire/rim that can handle the full power and any brand rubber/form tire just get ripped off the rim)
What would you recommend for the rear diff???
The Losi 8ight-E 3.0 is the best rc Ive ever driven hands down
rotachoc is offline
Old 03-08-2015, 06:27 AM
  #2997
How are your temps with that 19t pinion on 6s??
...Thats some ridiculous power right there.
I have the mm2/2650 in there with a 17t and on 4s its ridiculous....
im curious to know about what weight diff oils are recommended as well....
im just waiting for this snow to go away (which is probably gonna be a while) to ride the thing. Only have taken it it out twice....
I agree ...the buggy is simply awesome.
NickTheGreek is offline
Old 03-08-2015, 04:01 PM
  #2998
My set up I'm running the Futaba 4pls with Telemetry for Temperature on the motor so I can keep a close eye on rising temps
I'm also running a Yeah Racing Tornado Cooling Fan it has Ultra High Speed, zip tired to the motor and helps so much with temps
My everyday setup is 19t pinion and 43t spur SPC Battery Pack 6500mAh 65C 4S and my temps don't go over 66*c
My speed run setup is 21t pinion (23t pinion done only 3 passes ever with this pinion) 43t spur and temps were about 83*c after 6-10 passes and with the 23t spur it got to 84*c after 2-3 passes so I stopped didn't want to push my luck using a 2x SPC LiPo Battery Packs 6500mAh 65C 3S 11.1V
Straight out of the kit they have 5000wt oil F/C/R diffs thats a good start atm I have 5000wt oil in F/R and the centre diff I 7000wt oil but it still balloons the front wheels way to much and trying to work out what oils I need in all (F/C/R) diffs
rotachoc is offline
Old 03-09-2015, 10:40 AM
  #2999
maddog9's Avatar
Trader Rating: 30 (100%+)
If you are bashing put 100k or 1 Million K. Don't need a diff to break loose in a straight line.
maddog9 is offline
Old 03-09-2015, 01:36 PM
  #3000
patrick lsp's Avatar
Trader Rating: 191 (100%+)
Looking for clean low use 8ight e 3.0. Anyone have one they want to part with?
patrick lsp is offline
