Old 02-11-2015, 02:33 PM   #2896
Trader Rating: 20 (100%+)
Originally Posted by R.Fenstermacher View Post
Have any of you ever tried these tires? Which compound is softer clay or soft?
I'm running on a indoor hard packed dirt track.
http://www.panthertires.com/store/in...product_id=108
Since no one replied I'm assuming no one is familiar with these tires or Panthers compounds. So what tires do you guys run on hard packed high bite tracks?
TLR 22 3.0
TLR 22-4
Cooper Motorsports
R.Fenstermacher is offline   Reply With Quote
Old 02-11-2015, 03:04 PM   #2897
We have found that MC Electrons from Pro-Line work the best.
dynamiteracer is offline   Reply With Quote
Old 02-11-2015, 03:52 PM   #2898
Casper's Avatar
Trader Rating: 33 (100%+)
I have run slicks on high bite sticky clay. I have never really found where they work outdoor to be honest. I run Soft or MS rattlers on high bite clay but you don't get great life out of them.
A larger pin tire will be a little squirly at first but get better as the tire wears.
Slicks work with no dust so you have to stay in the groove or it can get loose quite quick. Damp clay I have had them work quite well
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-12-2015, 03:44 PM   #2899
JourneyMan's Avatar
Trader Rating: 89 (100%+)
All we run - we were grinding down our own tires for a while but like casper said, indoor wet clay. They are hooked, but stay in the groove. Give them a little LW before you run.
You can buy now buy Dirt Webs in 1/8 also, I run them on a very hard packed indoor dirt track that you would almost assume is clay... IRCR.
Thanks to - Jconcepts | Team Trinity/Revtech | Kal-gard
JourneyMan is offline   Reply With Quote
Old 02-14-2015, 05:52 AM   #2900
trutledge83's Avatar
I just picked up a 3.0 kit super excited to get it. Does anyone have any pictures of using 2 2s lipos ? I need some wiring ideas.
Airtronics - TLR - Orion - LRP - Reedy
trutledge83 is offline   Reply With Quote
Old 02-15-2015, 06:48 PM   #2901
Thanks for all the tire advice!
TLR 22 3.0
TLR 22-4
Cooper Motorsports
Old 02-15-2015, 10:29 PM   #2902
Default Best Neu Motor to use????
Hello, I just got a Losi 8ight-E 3.0 and will be starting to build it soon. I would like to use a Neu Motor in it but I'm not 100% sure which one to use. I'm thinking the 1515 1Y, does anyone else have experience with these motors in this buggy? I will probably start racing with it but that's not all I will be using it for. I want it to be crazy fast but have good pick up as well. Honestly I will probably end up getting one that's good in both areas and then one that will be just super fast as well. Are there any other motors that would be better than the Neu's? I have a discount code that only lasts for the next 48 hours so I need to decide fast lol
Gaboon is offline   Reply With Quote
Old 02-16-2015, 08:53 AM   #2903
Casper's Avatar
http://www.petitrc.com/setup/losi/se...ctronicsSetup/
May not be the best picture but this is how I run my dual shorties.
You run a jumper from one pack to the other (+ to -) and then run wires from the ESC to plug it in.
The eight 3.0 comes with a neat brace to do this easy with shorties but same thing goes for full packs.
Old 02-16-2015, 01:50 PM   #2904
mxnickj's Avatar
Trader Rating: 51 (100%+)
Hey guys, I'll be getting a 8ight e 3.0 in a few weeks and have been looking at setups but I have a quick question. When I see setups saying battery forward, does that mean all the way front in front of the ESC, or just forward in the battery tray? I'm confused because I'm seeing a lot of pictures with the battery in the front and ESC to the rear. How/why is that being switched?
mxnickj is offline   Reply With Quote
Old 02-16-2015, 02:04 PM   #2905
Brian C.'s Avatar
I'm pretty sure that they meant move the battery forward in the tray...
Brian C. is offline   Reply With Quote
Old 02-16-2015, 03:19 PM   #2906
Any updates on the body Drake was running back in October?
Reference Post 2579
TLR 8IGHT E 3.0 THREAD
fievel is offline   Reply With Quote
Old 02-17-2015, 03:27 PM   #2907
Trader Rating: 55 (100%+)
What's a good starting pinion with 45 spur on a medium to large size outdoor track? Any help appreciated
Jamison R is offline   Reply With Quote
Old 02-17-2015, 05:24 PM   #2908
Bivens's Avatar
That depends on your motor KV...
Team 3D Hobbyshop
www.3dhobbyshop.com
Bivens is offline   Reply With Quote
Old 02-17-2015, 05:58 PM   #2909
Stubbs's Avatar
Trader Rating: 57 (100%+)
Reference Post 2579
That looks like a version of the stock 3.0 body, minus the rear fin.
Maybe they were trying some stuff out, and didn't like it enough to bring it to production.....
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 02-18-2015, 01:11 AM   #2910
Hi guys!
Our track is starting a new class this season, e-buggy light.
Setup is based on sc motors and 2s lipos. I need some input on battery choice with weight bias in mind. I allready made the battery foreward mod.
This way i want be bying new packs twice
losi8_79 is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
