Old 02-04-2015, 06:27 PM   #2881
maddog9's Avatar
Trader Rating: 29 (100%+)
Originally Posted by RobEmm View Post
Reducing caster gives more off-power steering and less chance for traction roll. Great for tight indoor smooth tracks!
Its still 15 degrees of casters, just the axle is roughly 3-4mm higher. On a high traction track it made my car extremely loose on exit, on lower bight track it seemed to make the car push off power.
maddog9 is offline   Reply With Quote
Old 02-06-2015, 06:20 AM   #2882
mlbright's Avatar
So this question was asked to me from another Losi driver. Anyone running the Orion motors, how do you mount the motor up to the E 3.0 since the Orion motors use a bigger screw and the motor mount is setup for a smaller screw? I run Tekin so I don't have this issue, I didn't know it existed.
Marlowe Bright
Sponsors: Reds Racing USA, A-Main, Protek RC
mlbright is offline   Reply With Quote
Old 02-06-2015, 08:34 AM   #2883
Trader Rating: 138 (100%+)
Originally Posted by dtgolfing View Post
Well, dropping the rear diff oil down to 3k and standing up the rear shocks really helped. Was able to make the tight turns and slide out the rear end more.
Did the same, and the car is night and day. Can whip it around turns where as before it would just push into the pipe on the other side of the track. Great setup idea, helped me millions.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporary 4 wheel) YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 02-06-2015, 05:39 PM   #2884
KOULLIT's Avatar
Hi mlbright,
I had the same problem with a Neu motor on my RC8.
I don't think there are so many cars (Serpent, JQ...) with 3mm and 4 mm motor mount screws.
Maybe, you can try an Losi 2.0 motor mount ? I don't know if it can fit the 3.0, but you can find losa9199 and losa9198, and I think you will have 4mm motor screw holes.
If not, I think there's enough space to drill the original 3.0 motor mount.
Bye !
SYLVERIS RC - Option Racing Parts
LOSI 8IGHT-E 3.0 - Tekin RX8 GEN2 - Tekin T8 - Futaba 3GR 2.4Ghz
1/8 Off-Road Electric - Belt drive conversion : http://www.rctech.net/forum/electric-off-road/665377-1-8-offroad-electric-belt-drive-conversion-6.html
The French forum : RCMAG.COM
KOULLIT is offline   Reply With Quote
Old 02-06-2015, 08:15 PM   #2885
Just drill the holes a bit bigger. That's what a few guys I run with have done.
Proudly Sponsored By
Maclan Racing.
TLR 22 2.0 (x2) / TLR 4.0
Jamie James is offline   Reply With Quote
Old 02-06-2015, 08:47 PM   #2886
Dan.J's Avatar
Trader Rating: 21 (100%+)
I have the Orion Vst2 pro 1900KV in mine, as others stated just mod the mount.
Tekno EB48.3/Tekno EB48SL/Tekno SCT410.3
Dan.J is offline   Reply With Quote
Old 02-09-2015, 10:09 PM   #2887
I'm considering converting my Losi 8ght 3.0 to electric. I understand Losi has a kit for this but it seems that it was released prior to the 3.0 version (I may be wrong about this). Will the conversion kit work on the 3.0 buggy? Also, what body will I need to run to clear the battery on the buggy once converted? Finally, I noticed that the conversion has the battery positioned toward the front of the chassis unlike the 3.0 e-buggy which puts the battery on the back of the chassis. Is this a disadvantage or does it lie in the realm of different distribution of weight vs. the 3.0 e-version? I see drivers wanting to move the battery forward on their 3.0 8ight-e's which makes me wonder if the preferred route isn't a nitro buggy with the e-conversion. If there are any other equipment/setup variations that the nitro to e-conversion require over the OEM e-buggy, please let me know. I have an 8ght 3.0 e buggy as well so doing this may leave me with two e-buggies with different weight distribution. Thanks in advance.
achtung6 is offline   Reply With Quote
Old 02-10-2015, 04:46 PM   #2888
Trader Rating: 20 (100%+)
Have any of you ever tried these tires? Which compound is softer clay or soft?
I'm running on a indoor hard packed dirt track.
http://www.panthertires.com/store/in...product_id=108
TLR 22 3.0
TLR 22-4
Cooper Motorsports
R.Fenstermacher is offline   Reply With Quote
Old 02-10-2015, 08:34 PM   #2889
Brian C.'s Avatar
The conversion, will work, but the setup of the car will have to be different due due to the different chassis and chassis layout of the 3.0 e car... I ran a converted nitro went it first came out it worked great, but eventually I did convert it to a real 3.0 e, they both worked great!
Brian C. is offline   Reply With Quote
Old 02-10-2015, 08:51 PM   #2890
Cool, glad it worked for you too. Lorenzo has LRH setup with so many tight turns right now, I needed all the turning I could get.
Losi Mini 8t
Associated B5m
Tekno Short Course
Losi 8ight 3.0
Ping i20 Driver & Callaway X-Tours irons
dtgolfing is offline   Reply With Quote
Old 02-10-2015, 09:36 PM   #2891
Thank you. Are you sure the conversion kit will work on the 3.0? I just asked a vendor who replied saying the conversion kit will not work on the 3.0 because it was intended for the 8ght and 8ght T but not the new car. Which Losi 8ght did you convert to electric power?
Tony
Old 02-10-2015, 09:41 PM   #2892
Trader Rating: 198 (100%+)
They are the same. The Losi conversion from the 2.0 will work on the 3.0. I did this when the 3.0 came out and personally prefer this setup over the 3.0 Ebuggy. I do have both cars still.
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 02-10-2015, 09:43 PM   #2893
This is wonderful information. Thank you so much for clarifying this for me. Do you happen to know what all changed when the 3.0 car was introduced?
Also, which body will work well with a converted 3.0 buggy? Thanks again!
Tony
Old 02-11-2015, 05:20 AM   #2894
Trader Rating: 37 (97%+)
So, to do the forward battery mod or not to do the forward battery mod? How do you do it anyways?
TLR 22 2.0
TLR 8IGHT E 3.0
charlesandstuff is offline   Reply With Quote
Old 02-11-2015, 09:50 AM   #2895
Brian C.'s Avatar
I used the E conversion on the 8ight 3.0 Nitro
Tags
e-buggy, eight 3.0, losi, spur gear
