Old 01-23-2015, 08:55 AM   #2851
Integra's Avatar
Yes 100% feel thing.
Old 01-23-2015, 09:58 AM   #2852
Trader Rating: 138 (100%+)
On our new layout which is much tighter and twisty then before I am noticing my car had a reluctance to roll causing on and off power push and a loss of traction in the corners. Forward bite is also suffering on the straights. Looking for a simple setup changes to make. Thinking of keeping the stock Pistons, nut dropping from 35/35 to 32,5/32.5 and going to silver springs over the green used on Drakes setup. Is there anything else I could try to gain back the lost steering and side traction I need? Tires could be a very big factor. Running half worn bar codes at the moment as it is the tire of course for the guys running Mugens who are not having here issues.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, B64D (Temporqary 4 wheel), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
Old 01-23-2015, 10:12 AM   #2853
MasiisaM's Avatar
Yea running at OCRC?
TLR 22 2.0 - TLR 8E 3.0 - HB D413
Thanks to:
Tekin - www.teamtekin.com
Thunder Designs - www.thunderdesigns.net
MasiisaM is offline   Reply With Quote
Old 01-23-2015, 12:00 PM   #2854
LRH.
Old 01-23-2015, 01:46 PM   #2855
MasiisaM's Avatar
LRH.
that is a tight track...
I did find much better luck when i went from the bar codes to the dirt webs..
Thanks to:
Old 01-24-2015, 12:39 PM   #2856
Yeah. I have typos and electrons. Will soften up the suspension and change out tires. I think the issue is the car is too light with shorty packs using such stiff suspension.
Old 01-25-2015, 07:16 AM   #2857
Also going to try a full sized 4spack as well. No light stuff anymore.
Old 01-26-2015, 05:25 PM   #2858
DesJardins's Avatar
Finally ready for the dirt
DesJardins is offline   Reply With Quote
Old 01-26-2015, 07:21 PM   #2859
Dietz's Avatar
try 1.5f /37.5 and 1.4r/32.5
Team Losi Racing, Horizon Hobby, Spektrum, AKA
Dietz is offline   Reply With Quote
Old 01-26-2015, 08:35 PM   #2860
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up This might help
LRH.
Might I recommend two things.... Shorter camber Links and go to 2000 rear dif oil. Run Super soft tires and yes if they are worn try some new ones.
I run the short steering link also. Your shock package sounds fine. Sounds like your overpowering the rear end some you can tame down the ESC and run #2 profile also. Good luck
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 01-29-2015, 05:16 PM   #2861
GRIMREAPER's Avatar
Send a message via AIM to GRIMREAPER
Hey guys i wanted to know if anyone can explain to me how to install the avid wing buttons on a 8ight t. I couldnt find any info on it
TEAM 213 /Clodzilla Crawler/AX-10/SCXC10/8ight T e 2.0 MM2/Tekno 8ight 2.0/TT01-E/100mph Rustler/RC8e
GRIMREAPER is offline   Reply With Quote
Old 01-29-2015, 06:31 PM   #2862
So I took a lot of the suggestions here and it made the car better. The biggest difference was indeed the battery. Talked to Jake Thayer about steering and he said to use the Truggy caster blocks spaced forward. I have a set of 3.0 non-inclined truggy caster blocks. Thing is when I put them on my car it seems that no shimming is required? fits as snug as the buggy blocks. Did I get the wrong thing? Totally confused...
Old 01-29-2015, 09:02 PM   #2863
losialltheway1's Avatar
Trader Rating: 17 (100%+)
Ok so I posted this question in a different thread and didn't find anything on this thread. So here goes. So I'm thinking about buying a Tekno elektri-clutch for my 3.0 buggy. I run on a pretty slick track and wanted to know the pros and cons. I have never used an e buggy or truggy with a clutch setup on it. Just wanted to get some feedback. I've heard great things from other people, but wanted to see if any of you have had any luck. Thanks.
Mugen Seiki
losialltheway1 is offline   Reply With Quote
Old 01-30-2015, 07:22 AM   #2864
Casper's Avatar
Trader Rating: 33 (100%+)
Not sure about slick conditions but I now the guys that run that the most are on blown out outdoor tracks as the clutch acts a bit like a slipper clutch at that point. I have not tried one personally.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22SCT 3.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 01-31-2015, 11:51 AM   #2865
Trader Rating: 37 (97%+)
I need to make a decision of what buggy I am going to get. I am stuck on the 8ight e 3.0 or the mugen mbx7r eco. I've had most every brand but serpent I'm the past along with the losi 2.0, the mbx7 eco and mbx6r eco. Also drove an mp9 tki3 e for a while. How does the 8ight e 3.0 compare to the mbx7r eco? Or Mp9? Thanks.
TLR 22 2.0
TLR 8IGHT E 3.0
charlesandstuff is offline   Reply With Quote
Tags
e-buggy, eight 3.0, losi, spur gear
