Old 07-24-2013, 09:32 AM   #271
bigbadbasher's Avatar
Like i said in another thread, when a product is good, nobody is online complaining about it, they are out running them and enjoying them!
Not many tips from me, get it, build it and run it!
I would maybe go 37.5 up front with your shocks, other than that, your going to love this buggy..
bigbadbasher is offline   Reply With Quote
Old 07-24-2013, 11:47 AM   #272
JasonR/C's Avatar
I'm running 5-7-3 diffs, 32fr 30rr oil. Silver springs. 3 rear toe and 2 squat. 1 up 1 down in the front. Car is pretty dialed. I too have a 2.0 scte and love it a lot. This car is a little different but just as drive able if not more then the truck.
Leisure Hours Hobbies and Raceway, Joliet, Illinois
JasonR/C is offline   Reply With Quote
Old 07-24-2013, 11:56 AM   #273
Setup will depend on his track.. But yea, your actually driving the 3.0..
Old 07-24-2013, 12:40 PM   #274
XXXDad's Avatar
Trader Rating: 195 (100%+)
Thumbs up Drive it!
Originally Posted by JasonR/C View Post
And my motor mount comes loose also. I can't run the brace in the back. My motor can is too big. I used a very tiny dab of thread lok. Do not use a lot I stripped my head out and had to dremel a slit and had no choice but to cut a little of the chassis on a new car.
I found, if you go to longer screws through the chasi and thred lock the ones into Alu. it holds well.
Originally Posted by bigbadbasher View Post
Even if your can would fit, dont run that motor brace in the rear, it kicks the motor up when the chassis flexes and can cause the spur to strip..
I had to do some dremmling once to Luckily for me, im like a surgeon with tools, didnt take any chassis with it lol..
Hes right never ever run the small shim brace under the rear of motor. When the chasi flexes it pushes the motor out of alignment like hitting it with a Hammer.
Sucks when things strip out
Originally Posted by Blown up View Post
Wow, surprised there's not alot more guy's talking about this rig on here...
I've been running the Tekno for a couple months but my scte 2.0 is so easy for me to drive fast that I just picked up a E-converted 3.0 to try. Any tips would be appreciated.
I used the Drake setup to the tee. Workes great. Good starting point, then tune to your track. I needed more tighter turning. So i moved the rear hub foward. I turn under evryone now and can power out of the turns with no fear. Run it, its a blast to drive fast.
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 07-24-2013, 05:58 PM   #275
Forgot about adding the part about longer screws, i do that by default but i own many Losi's so i do it without thinking about it lol..
Old 07-24-2013, 10:19 PM   #276
JasonR/C's Avatar
I'll try the longer screws thanks! Club race tonight 9 ebuggies I came in 3rd. No video this time though! 3.0 is ripping it up!
Old 07-25-2013, 02:03 PM   #277
Carbon Fiber Towers..
http://www.xtremercracing.com/Produc...10836&pID=1573
http://www.xtremercracing.com/Produc...10835&pID=1572
Old 07-26-2013, 09:03 AM   #278
Just wondering what are the main differences between the 2.0 and 3.0? They look very similar from the pics I've seen.
jha07 is offline   Reply With Quote
Old 07-26-2013, 09:35 AM   #279
ChrisWolfson's Avatar
Send a message via AIM to ChrisWolfson Send a message via Yahoo to ChrisWolfson Send a message via Skype™ to ChrisWolfson
3.0 has 16mm shocks with new progressive springs. Driveline is now dogbones. Change to front end geometry. More droop. All in all, makes for a very different driving car than the 2.0.
TLR / Horizon Hobby / Spektrum / Tekin / JConcepts / MIP / B-Fast RC / UpGrade RC
ChrisWolfson is offline   Reply With Quote
Old 07-26-2013, 10:13 AM   #280
There are a lot of little differences that really add up.
The front end spindles and carriers got an overhaul giving more steering throw and placing the dogbone in a different spot as well as the steering arm. There are new front arms that allow for this more steering.
The front and rear shock towers are new due to the large and longer bog bore shocks. The shocks got some serious work with all machined parts so they are SUPER smooth now. There are new springs as well that are tapered.
The driveline got dogbones which frees things up an helps with wear as well.
The rear wing got a gurney flap
The chassis has more flex for more overall traction and ease of drive.
You get all the goodies you want to use in the box now.
the ackerman arm has ball bearings now.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 07-26-2013, 10:47 AM   #281
JasonR/C's Avatar
Car is dialed!
Old 07-26-2013, 01:44 PM   #282
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Dialed!
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 07-26-2013, 02:05 PM   #283
XXXDad's Avatar
There is a Rear shock tower Mod, Lowering the Rear Link. I will try and find the Pic of Drakes car with the mod. From what I understand you get a 2.0 rear tower. and using it as a template drill new lower link holes. Below is the link to some pic... find the rear of the car and clic the pic to make bigger. Same Mod on Pheds car..... I'm doing it tonight. I will just measure and drill.Try it out this weekend.
http://www.neobuggy.net/2013/06/19/u...-adam-drake-2/
Old 07-27-2013, 11:24 AM   #284
Brian C.'s Avatar
I decided to change my suspension package are and I got my hand on some of my old O'Donnell springs. Since they taper the same I tried them out and the were WAY better than the TLR ones, so if anyone has them I recommend them.
T&L BOYZ
Trains and Lanes Racing
Team Kyosho
Brian C. is offline   Reply With Quote
Old 07-28-2013, 02:43 PM   #285
XXXDad's Avatar
Car was diled today , tried the rear lowered link Mod was nice. It locked the rear in even more yet let it rotate. Started 3rd in the A but ended up 4th... it was a hack fest. I'll get them next time.
Tags
e-buggy, eight 3.0, losi, spur gear
